Apacer’s First Industrial-Grade 16 GB MicroSDHC Memory Card
Discussion in 'News' started by Adrian Wong, Apr 12, 2012.
  1. Adrian Wong
    Milpitas, CA, USA – Apacer Technology, expert in memory storage solutions, introduces their very first industrial-grade MicroSDHC memory card for best reliability and longevity even in extreme environments for mission-critical applications.
    The shock-resistant industrial-grade MicroSDHC memory card comes in capacities of 4GB, 8GB and 16GB. One of the highlights is its firmware and major components that can be fixed right after customer’s recognition and validation. This reduces the risk of out-of-stock and compatibility issues by providing customers stable supply and high reliability.
    Apacer’s industrial-grade MicroSDHC memory card is compliant with the SD 3.0 Specification and supports Class 10 high-speed transmissions with sequential read/write speeds reaching up to 20 and 14 MB/sec respectively while fulfilling the requirements for high-capacity and high-speed data storage.
    Since Apacer particularly stresses "stability" as the primary concern for industrial devices, the greatest difference between this industrial-grade MicroSDHC memory card and other consumer memory cards on the market lies in its firmware version and major components that can be fixed.
    Furthermore Apacer’s clients can benefit from the stable, long term supply commitment to warrant for a stable supply chain and prevent out-of-stock risks. This is turn significantly reduces compatibility issues caused by frequent product component changes. Time and money spent on product verification can also be saved.
    To ensure that data stays correct in the transmission, the Apacer industrial MicroSDHC memory card supports ECC functionality, which can effectively minimize potential errors led by frequent data access while ensuring the integrity of data in transmission. The Global Wear leveling also helps deliver a phenomenally prolonged lifespan, as well as safer data storage.
    Apacer’s new industrial-grade MicroSDHC memory card features industrial-standard stability. In addition to portable devices, it can also be applied to handheld or automotive devices, as well as other industrial, communications, surveillance, and medical devices, rendering it to be the most professional storage solution. Samples are now available for customers to run tests. Boasting excellent quality and complete services, Apacer is your best choice.
    Part Numbers
    AP-MSD04GCS4P-TM : 4 GB
    AP-MSD08GCD4P-TM : 8 GB
    AP-MSD16GCH4P-TM : 16 GB
