wah.....toyota..so fast ar??? hahahaha.... like cham lo.....thats the problem these days... people..... hahhhahaha... so should i say my handphone is ancient??? hahaha
my hp konging(dying) the sim card part of the phone is not sensitive already... any1 wanna suggest a phone??
erm...below 1.5k ....the sgh d600 looks good though...but the slide mechanism is like longgar longgar... looking for a : 2megapixel camera external memory card non candybar 262k screen fast software simple sms interface as i type a lot maybe mp3 lots to ask for actually
new looks old this thread...haha...neway..i ve already bought a hp SEk750i...upgraded to 1gb MS pro DUO...not bad...only sumtimes it resets.. .
I've never experienced any restart/reset in my K750i when i owned it last time. Only experienced such issues with my K800i.
marc:really? k800i looks big though chai:which firmware? mine is R1BC002...i dint update coz got review say the sound abit softer.... Ps:seems theres a spyware on my pc....do ignore the link bout jokes if it appears..sori!
R1DB001 Probably the best firmware used. I modded the firmware to reduce the hissing noise when listening to MP3.
Yeah, last time I actually like the size of K750. But after using for 2 years, I think it's too small to handle, easy to slip off my hand, dropped a few times because of that.
chai: u modded ur own? so far i dun have problem with the mp3...odd ,,.. marc: yea..its a bit small though...but ince i pit the clear case..it feels just right if ever there was a abuse helpline for phone...mine would be their first case .
If you have changed the stock earphone with hpm-70 or better headphones, you will hear the hissing noise on any MP3 easily. I have very sensitive ears. The mod is easy to perform. There are many guides on that.
