I am posting a Everest sensor report. Can anybody please tell me if there is any other cooling i should get. I have simple cooler master air cooler which I brought fro 300 Rs and one cabinet air cooler. But the temperatures on my GPU is worrying. Anybody advice me if it is any cause for concern. I can give you any other info about my system if need be.
GPU idle temp and HDD fluctuate between 45 C to 54 C. The temps shown in the report are just five minutes after I started my pc. I was doing nothing but testing the temp. CPU looks fine with cooler master but the summers here in India are pretty bad that is what has me worried.
HDD temp is a bit high, near 60C is not healthy. tried with opening the side panel and see any improvement?
If your case has it (most do) slap a PC Case fan at where the HDDs are if you're worried about them. It needs just a little bit of airflow. I really can't remember what temps are supposed to be at though (haha I enjoy nice cool ambients here).
