Crysis is GOLD!
Discussion in 'Games' started by ianho, Nov 14, 2007.
  1. Adrian Wong
    Oh, I noted a small improvement on all resolutions - 1280 x 1024 up to 1920 x 1080.
    Crysis has this odd problem with some drivers. It just can't detect the full resolution - 1920 x 1200 for example. Damn irritating.
  2. ianho
    ianho Newbie
    What drivers were u guys using? I was using 169.25.
  3. PsYkHoTiK
    PsYkHoTiK Admin nerd
    Same driver that I use. :o
  4. ianho
    ianho Newbie
    I just checked Nvidia site. Latest Beta 169.28 says more performance for SLI n Tri SLI in Crysis when used with latest Patch 1.1. Hmmmmmmmmmmm..... I will try that n see if I can squeeze out a few more frames.
  5. Adrian Wong
    The fastest driver I found was a hacked 169.21. :think:
    The new 169.28 driver doesn't seem to help single cards, and it has that stupid resolution problem - cannot set 1920 x 1200 in Crysis. :doh:
  6. Adrian Wong
  7. ianho
    ianho Newbie
    What? N they say it's released specifically for use with Patch 1.1 to enhance SLI performance n then cant even select 1920? The only reason ppl go SLI is to play on big momma screens like 1920 n 2560. :(
  8. Adrian Wong
    Well, it's the same problem I had with Catalyst 7.12. Reinstalling the driver didn't help, so I think it's a driver issue. I had no problem with ForceWare 169.21.
    Oh, I think higher resolutions are possible. Just that Crysis doesn't seem to detect 1920x1200.
  9. ianho
    ianho Newbie
    I just downloaded 169.28. Will try n see if I can get it to run at 2560 n 1920.
  10. ZuePhok
    ZuePhok Just Started
    30fps is what i got on a tri-8800GTX rig. using 169.28, patch v1.1@VERY HIGH, on a samsung 1920x1080 F-HD 40incher.
    improvement from 169.25 with patch v1.1 is about 10fps :shock:
  11. ianho
    ianho Newbie
    Wah so high? On my GTX SLI rig, I just tested 168.28 with the GPU test n got an improvement of only 3FPS. Tested at 2560x1600, DX10, Medium.
    Ur running on DX9 or DX10?
  12. Adrian Wong
    How is Crysis at Very High? :D
  13. ZuePhok
    very high = DX10
    actually i don't think the improvement should be that high.
    more like a screw up somewhere in the tri-sli + .25 + patch v1.1 combination. tri is supposed to run using .28 + patch v1.1
    adrian: look pretty on a big lcd tv, once you get the color/contrast/DN configuration right. but frame rate would still drop to 20+ quite often.
  14. ianho
    ianho Newbie
    Dunno y Adrian cudn get it to run at 1920x1200 with 169.28 n Patch 1.1. I tried it and it works.
  15. Chai
    You mean for 8800GTX? I think he has a faulty card.
  16. ianho
    ianho Newbie
    Ya for GTX.
  17. Adrian Wong
    I just reinstalled Windows Vista and the 169.28 driver. Still getting only max 1920 x 1080 on this 24" Dell (max. 1920 x 1200). No problem going 1920 x 1200 when I use 169.25.
  18. Adrian Wong
    Nope. I canned the GTX. In fact, the GTX totally CANNOT run Crysis. It crashes on entering the menu. :doh:
    The tests were done on a GeForce 8800 GTS 512MB.
  19. PsYkHoTiK
    I think that GTX must be busted. GTXs seem to have a lot of issues (I have a friend who had probs crashing in source even :shock: ).
  20. ZuePhok
    i had the same issue as well.
    it happened quite often. initially i thought it was due to patch v1.1
