Dyno run
Discussion in 'PsYkHoTiK' started by PsYkHoTiK, Jul 2, 2011.
  1. PsYkHoTiK
    PsYkHoTiK Admin nerd
    Corrected: 324 AWHP 309 AWTQ (lb-ft) in 4th gear on Mustang Dyno...
    The transmission would shift at 6800rpm though...
    Temperature was ~79F (fairly "warm" - ~26C)
    Car Specs:
    2011 Audi (B8) S4
    7 speed DSG (dual clutch transmission)
    3.0 V6 Supercharged
    Misc specs:
    Ran in "Dynamic" mode and ASR turned off... (Dynamic mode is the "sport mode" where shifts are done way faster, revs held higher, and throttle/steering is super sensitive/precise) (ASR = Traction Control)
    RS4 19inch wheels with Michelin PS2 (255/35/R19) - if this matters
    Pump gas (92 octane with "up to" 10% ethanol crapola)
    Mods:
    APR 93 Octane ECU Flash
    APR RSC Catback (free flowing 3 inch exhaust - downpipes and back - since the cats are right after the exhaust headers)
    APR Stage II Carbonio Cold Air Intake
    This was done as a "modded" baseline since I'm getting a smaller supercharger pulley installed next week (and accompanying ECU tune).
    Mustang dynos "typically" read lower than the "average" dynojet dynos. Mustang dynos use road resistance and are therefore 10-12% lower than Dynojet readings. Keep in mind, these are WHEEL horsepower. Manufacturers usually quote CRANK horsepower.
    Full res dyno sheet: https://picasaweb.google.com/psykhotik/2011AudiS4#5624611191902111794
    Video (lol why not):
    Comparison with a bone stock B8 S4:
    The "baseline" is my buddy's car (DSG too). Curious on the "lead" he has on me down low. I'm probably guessing due to lighter wheels (he has 18 inch wheels - I have 19s - a good 6 lbs per corner more)
  2. Chai
    Wow, that flat torque curve on the stock.
  3. Adrian Wong
    Wow.. Except at the beginning, there sure is a significant boost to the torque throughout the rest of the range.
  4. Chai
    Despite the rounder torque curve, there's a lot of power gain, and still maintains at higher end. Looks like the mapping is better for track.
  5. PsYkHoTiK
    Yeah, APR developed/tested the tune on their S4 race car. I have no complaints on with it on the track though (309 ft-lb/409Nm). :)
    The baseline is my friend's car (not my stock baseline - regrettably I never did one). It must be his lighter wheels (less "loss" putting power down) that cause the spike down low or something.
    Usually people quote ~15% Drive Train Loss to figure out the crank power when the car is on dynapack/dynojet. 25% on mustang dyno I suppose. IDK. Crank HP to me is quite irrelevant... :p
  6. Chai
    Well, crank HP is good for comparing with the manufacturer's spec. Other than that, you are right.
