finished water cooling and runing :nuts:
Discussion in 'Overclocking, Cooling & Modding' started by generalRage1982hrv, May 4, 2008.
  1. generalRage1982hrv
    hi guys i have finished water cooling :thumb: and i have tested it on this system
    cpu : intel pentium D 945 3.4
    mbo : Asus P5E
    ddr: 2x1Gb 667 Geil
    gpu: Gigabyte 8800GTS
    [​IMG][​IMG]
    yeah it is ugly but it is working
    on stock speeds
    here some tests of water cooling with overclocking
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    well i was hiting higher oc and normal temps on load but god damnd vista is unstable so no point on making big deal of it
    1 person likes this.
    Cool! What did you use to test stability? Prime 95?
  3. generalRage1982hrv
    yeah
    and occt when i loaded windows
    now i have removed water cooling because i moved pc to living room
    temps are 10°C lower than with Zalman 9500Cu led
    and i cant even start pc with zalman on 287Mhz fsb
  4. Adrian Wong
    10oC cooler? Nice! :thumb:
  5. generalRage1982hrv
    thx bro
    well now i am thinking of making a Cu based water block
    and trying to get a 45nm cpu but that is a dream
  6. Mac Daddy
    Cool stuff Bro :thumb:
    + rep ;)
  7. Chai
    Not too bad at all. 945 is not a cool processor at all. Yes, time to get 45nm! It's a lot cooler, and better for overclocking! And you already have the right motherboard!
  8. generalRage1982hrv
    thx mac
    chai know about mbo and i will see how could i get 45nm cpu but as i have writen it is just a dream
  9. Lacus
    Lacus Newbie
    Wow, not bad the result for a self made WC parts :D Good Job :D Erm btw whats a Cu based water block?
  10. generalRage1982hrv
    thx and
    Cu is copper
  11. g0tanks
    g0tanks Newbie
    Nice OC, too bad the pictures are low quality though.
  12. Max_87
    Max_87 huehuehue
    Not bad, there is still room for improvement, you should try pin matrix based designs on your next block.
