help!!!!
Discussion in 'General Hardware' started by guyferic, Mar 9, 2007.
  1. guyferic
    guyferic Newbie
    My PC keeps restarting by itself(every 5-10mins) especially while watching videos using kmplayer(same prob with other players), sometimes theres a blue screen, driver not less or equal/irql nor less or equal. sometimes, it jus restart(no blue screen). i tried playing games but nothing happens even after 1-2hrs but after that i switched to watching videos, it restart again. the videos, kmplayer have no prob when using my bro pc to watch. ad-ware/spyware/virus scanned but showed nothing. i tried leaving the pc on without doing anything and it will hang ard 45-1hr later. winxp had been reinstalled and the prob is not solved. can it be that the processor is spoilt? what can i do?
    my mobo specs
    pcchips m955g
    p4 2.66ghz 735 RAM
    Most likely a driver issue. What graphics card are you using? Or are you using an integrated Intel graphics chip?
  3. guyferic
    guyferic Newbie
    i'm using integrated graphic card
  4. empire23
    empire23 BRB. Attacking Russia
    Obviously a hardware/driver issue, IRQ_less_or_not_equal means that something has failed to respond to an Interrupt Request.
    Best you can do is to update your drivers to the latest ones by the manufacturer, and flash your BIOS to the newest release. But i do suspect it is hardware issue.
    If updating doesn't help
    1. Check the temps of your PC (proc core, northbridge, vrms and stuff) make sure none goes above 60c.
    2. Check all the connections, take out your RAM and reinsert it firmly, do the same for all other motherboard components.
    3. Clear your PC of dust and gunk.
    The above usually clears up 90 percent of my premature BSOD cases.
  5. guyferic
    guyferic Newbie
    but from what i know, if BIOS is updated wrongly, it can cause system failure. i'm not so confidence in doing it. is it really needed to use floppy disk for bios update as indicated by the mobo website?
  6. Adrian Wong
    Well, anything NOT done properly will always lead to trouble, right? :D
    It depends on your motherboard. Some motherboards have Windows-based utilities to flash the BIOS. But even if given the option, I prefer to use the floppy drive.
  7. guyferic
    guyferic Newbie
    if system fails to start up after updating bios, is there a way to change back to the original bios?
  8. Adrian Wong
    If you make sure you are flashing the RIGHT BIOS, it's unlikely to fail unless there's a power failure. In any case, there are workarounds for BIOS failures.
    You might want to read our motherboard BIOS flashing guide and Hot Flashing Guide before you try it out.
    I would recommend updating the Intel Extreme Graphics driver first though. See if the driver is the problem.
  9. Chai
    I highly suspect RAM failure.
  10. Adrian Wong
    Hmm.. Possible, but a bit unlikely since it only occurs during video playback.
  11. guyferic
    guyferic Newbie
    i cant find the version of my drivers, how do i know whether if it needs to to updated? I installed the testmyhardware and it states that my sys bios ver is AMI-080010 but the ver on the mobo website states 050413S, so is it the latest ver? I cant find the bios id on cpu startup...
    sorry for asking so much because I need to know more b4 I even try doing anything to my pc ini case it dies down...
  12. guyferic
    guyferic Newbie
    every tim after it restart, there this msg.
    BCCode : 9c BCP1 : 00000000 BCP2 : 8054D370 BCP3 : A2000000
    BCP4 : 84010400 OSVer : 5_1_2600 SP : 2_0 Product : 768_1
  13. Trinity
    What are source you watching videos from? dvd rom, dvd burner, HDD?
    Does it make a difference?
    I had to buy a newer burner lately because my old dvd rom just could not handle the disks my friend had burnt for me lately.
    New drive prob solved.
    Just a thought.
  14. guyferic
    guyferic Newbie
    i'm not sure if i found the prob but from the computer info status taken from the help and support center, i found that the memory(RAM) detected is 16MB but the minimum requirement is 64MB. What can I do? I have 2 RAM, 512 & 256.
  15. Trinity
    Try to reseat the ram. And take one stick out and see if that works, If not try just the other stick.
    Be sure to use the primary ram slot.
    Might help.
    Might have a bad ram.:think:
  16. Bestia(ry)
    Bestia(ry) Mac'ster
    Onboard graphics?
    Video hangs?
    Max out your shared memory for onboard graph to 32MB
    (or higher if possible) and set AGP aperture to 128MB.
    Then try again.
  17. guyferic
    guyferic Newbie
    pls help!
    D:\Program Files\Support Tools>dumpchk C:\WINDOWS\Minidump\Mini031007-02.dmp
    Loading dump file C:\WINDOWS\Minidump\Mini031007-02.dmp
    ----- 32 bit Kernel Mini Dump Analysis
    DUMP_HEADER32:
    MajorVersion 0000000f
    MinorVersion 00000a28
    DirectoryTableBase 00039000
    PfnDataBase 81053000
    PsLoadedModuleList 8055a420
    PsActiveProcessHead 805604d8
    MachineImageType 0000014c
    NumberProcessors 00000001
    BugCheckCode 00000024
    BugCheckParameter1 001902fe
    BugCheckParameter2 f82d6ac0
    BugCheckParameter3 f82d67bc
    BugCheckParameter4 f7c16361
    PaeEnabled 00000000
    KdDebuggerDataBlock 8054c060
    MiniDumpFields 00000dff
    TRIAGE_DUMP32:
    ServicePackBuild 00000200
    SizeOfDump 00010000
    ValidOffset 0000fffc
    ContextOffset 00000320
    ExceptionOffset 000007d0
    MmOffset 00001068
    UnloadedDriversOffset 000010a0
    PrcbOffset 00001878
    ProcessOffset 000024c8
    ThreadOffset 00002728
    CallStackOffset 00002980
    SizeOfCallStack 00000acc
    DriverListOffset 000036e0
    DriverCount 00000080
    StringPoolOffset 00005ce0
    StringPoolSize 00001198
    BrokenDriverOffset 00000000
    TriageOptions 00000041
    TopOfStack f82d6534
    DebuggerDataOffset 00003450
    DebuggerDataSize 00000290
    DataBlocksOffset 00006e78
    DataBlocksCount 00000006
    Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
    Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420
    Debug session time: Sat Mar 10 01:49:09 2007
    System Uptime: 0 days 0:27:30
    start end module name
    804d7000 806eb100 nt Checksum: 002198AF Timestamp: Wed Mar 02 08:
    59:37 2005 (42250FF9)
    Unloaded modules:
    f1b52000 f1b5b000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f1765000 f1768000 hidusb.sys Timestamp: unavailable (00000000)
    f1b02000 f1b05000 mouhid.sys Timestamp: unavailable (00000000)
    f18b7000 f18c0000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f1996000 f1999000 hidusb.sys Timestamp: unavailable (00000000)
    f1279000 f127c000 mouhid.sys Timestamp: unavailable (00000000)
    f156f000 f1578000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f1618000 f161b000 hidusb.sys Timestamp: unavailable (00000000)
    f133d000 f1340000 mouhid.sys Timestamp: unavailable (00000000)
    f7f33000 f7f3c000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f1c6a000 f1c6d000 hidusb.sys Timestamp: unavailable (00000000)
    f172c000 f172f000 mouhid.sys Timestamp: unavailable (00000000)
    f1065000 f106e000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f0ef1000 f0ef4000 hidusb.sys Timestamp: unavailable (00000000)
    f14bd000 f14c0000 mouhid.sys Timestamp: unavailable (00000000)
    f18e7000 f18f0000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f1099000 f109c000 hidusb.sys Timestamp: unavailable (00000000)
    f6500000 f6503000 mouhid.sys Timestamp: unavailable (00000000)
    f14b9000 f14bc000 hidusb.sys Timestamp: unavailable (00000000)
    f0eed000 f0ef0000 mouhid.sys Timestamp: unavailable (00000000)
    f0eb2000 f0edd000 kmixer.sys Timestamp: unavailable (00000000)
    f1887000 f1890000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f14b5000 f14b8000 hidusb.sys Timestamp: unavailable (00000000)
    f1b2e000 f1b31000 mouhid.sys Timestamp: unavailable (00000000)
    f0fbd000 f0fc6000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f12a1000 f12a4000 hidusb.sys Timestamp: unavailable (00000000)
    f1d9c000 f1d9f000 mouhid.sys Timestamp: unavailable (00000000)
    f8113000 f811c000 HIDCLASS.SYS Timestamp: unavailable (00000000)
    f64fc000 f64ff000 hidusb.sys Timestamp: unavailable (00000000)
    f64f8000 f64fb000 mouhid.sys Timestamp: unavailable (00000000)
    f1917000 f1942000 kmixer.sys Timestamp: unavailable (00000000)
    f8531000 f8532000 drmkaud.sys Timestamp: unavailable (00000000)
    f1bb2000 f1bbf000 DMusic.sys Timestamp: unavailable (00000000)
    f75d0000 f75de000 swmidi.sys Timestamp: unavailable (00000000)
    f1942000 f1965000 aec.sys Timestamp: unavailable (00000000)
    f83db000 f83dd000 splitter.sys Timestamp: unavailable (00000000)
    f81b3000 f81b8000 Cdaudio.SYS Timestamp: unavailable (00000000)
    f7b55000 f7b58000 Sfloppy.SYS Timestamp: unavailable (00000000)
    Finished dump check
  18. Chai
  19. guyferic
    guyferic Newbie
  20. guyferic
    guyferic Newbie
