If you just want to get rid of a virus.. and basically reinstall everything, it is very simple. 1. Boot up using the Windows 7 boot disc. 2. Use it to delete all partitions. 3. Recreate your partitions and format them. A quick format will do, but if you got nothing better to do, you can opt for the slower full format. 4. Install Windows 7 after that.. and then all your apps. 5. Make sure you install a decent antivirus software like AVG! Alternatively, if you have a desktop handy... 1. Remove the HDD from your laptop 2. Plug the HDD into your desktop as a secondary drive (NOT as a boot drive!) 3. Boot up the desktop and log into Windows 4. Go to Control Panel -> Administrative Tools -> Computer Management -> Disk Management. 5. Look for your mobile HDD in there. 6. Delete and recreate all partitions and format them. 7. Again, a quick format is all you need but if you are really paranoid, do a full format. 8. Once down, shut down the desktop and take out the mobile HDD 9. Now you can install the mobile HDD into your laptop and install Windows!
