Howto Guide: Overclocking C2D/C2Q Processors (v1.6)
Discussion in 'Overclocking, Cooling & Modding' started by graysky, Aug 19, 2007.
  1. graysky
    graysky ARP Reviewer
    Howto Guide: Overclocking C2D/C2Q Processors (v1.7)
    Edited on 08-Jun-2008: Guide is now version 1.7 – added a 2nd example minimizing the vcores on my system.
    Before you continue, I wrote this guide with the newbie in mind, so please don't reply criticizing it for being too simplistic -- it's this way by design. Also know that the steps for overclocking apply to all chips: quads, duals, single-cores, or triple-core processors. You can use the basics taught in this guide with any modern machine.
    I wrote the guide originally using a Q6600/Asus P5B-Deluxe, but recently sold that machine and upgraded to an X3360/DFI LT P35-T2R. I didn’t want to change the first half of the guide, so it’s still based on the Q6600/Asus board. The newly written section about finding a minimum stable CPU and MB vcore section is written based on my actual experience finding stable settings for this newer machine. Again, the steps for overclocking are pretty independent of this subtle change. Finally, I take no responsibility for what you do with the information in this guide. Overclock your hardware at your own risk.
    Overlocking Basics
    Before you start, read your motherboard manual. Know how to reset your BIOS in the event that you are too aggressive in your CPU settings and it doesn't complete a POST (Power On Self Test, that beep when you first turn the machine on and it starts up means you passed the POST). Some motherboards reset automatically if you switch off the power supply for 30 seconds or so. Others require you to move a jumper to reset them.
    The basic formula you need to know for CPU speed is:
    Code:
    CPU Speed = CPUM x FSB
    where CPUM is the CPU Multiplier, and FSB is the front side bus.
    Example: The Q6600 runs at a factory setting of 2.40 GHz. That's the product of a 9x multiplier and a 266 MHz FSB (quad pumped it's 1066 MHz but we're not quad pumping these numbers). So CPU Speed = 9 x 266 which is 2,394 MHz or 2.40 GHz.
    Below is a list of Intel chips. Most of them, including the Q6600, have a "locked" multiplier – meaning it can't go above a certain value (9x in this case). The only way to increase the CPU speed beyond the stock value is by raising the FSB. Other "Extreme" chips like the QX9650 or X6850 have “unlocked" multipliers; you can raise their multipliers above the stock value. These chips are denoted from the standard stock by the letter “X” in their model number.
    For reference, here are all Intel offerings as of May/’08:
    My first quad system was based on a Q6600 at 9x333=3.00 GHz (25 % over factory). I found the max it can go when cooled with air is 9x370=3.33 GHz (39 % over factory), but it just ran too hot for me. Every chip is different... you might be an unlucky owner of a chip that just doesn’t overclock very high at all.
    Overclocking is more complicated than just adjusting two settings in the BIOS, because as you increase the FSB, you'll also need to increase the core voltage (vcore) which is the actual juice going to the processor. As well, you may have to increase the other voltages on the board like: memory, FSB, NB, SB, ICH chipset. There are also parameters controlling your memory that may need tweaking as well. Don't worry about them for now. The board can manage these automatically which is what you should do initially. When you finally decide on an overclock number, you'll want to go back and minimize your voltages to minimize your heat production. We'll get into this later. For now, you want to verify you can successfully POST, and verify that your system can run stable at the settings you've selected.
    Pre-Overclocking Checklist
    Before you think about overclocking your system, you'll need to be sure you're using quality parts that can handle the increased stresses.
    1. Motherboard
    I decided not to maintain a list of motherboards that are known to be good overclockers; keeping the list updated would be too time consuming. I only mention this because if you’re using some generic MB you got free with the purchase of your CPU, you’re probably not going to be able to overclock it.
    2. Cooling
    Cooling is very important since you're asking the system to produce more heat than it's designed to produce. A quad core chip will produce twice the heat of a dual core chip, so if you're using the Intel Stock HSF, you'll probably want to upgrade to something better. Again, I don’t wanna maintain a list. I can tell you that I am using a Thermalright Ultra-120 Extreme and am very happy with it.
    Here is a more recent list of HS’s that have actually been reviewed and ranked based on performance.
    Finally, there is a section at the end of the guide entitled, “Temperature Management” which I would strongly suggest you at least have a look at since it contains some good info. For example, for under $5 you can probably shave off ~10-15 % of your NB (North Bridge) load temps simply by adding a small fan to the heatsink even if it was never designed to have one (attach it with a zip tie):
    3. Memory
    You will need memory that can keep up with your overclocked system. Again, I’m not going to keep a list. You’ll see RAM listed with timings and speeds that I’ll decode for you using the following examples:
    • The first part is self-explanatory (DDR2 memory).
    • The number after it is the data transfer rate. Simply divide it by 2 to get the maximum FSB speed for which the module is rated. Example: 800/2 = 400 MHz. Therefore, DDR2-800 can work on systems with a FSB of up to 400 MHz (anything more and you’re lucky).
    • The PC2-XXXX is designation denoting theoretical bandwidth in MB/s. Some memory manufactures use this instead of the DDR2-xxx designation. You can calculate it for any FSB you want by simply taking the FSB and multiplying by 16 (rounded in some cases). Example using a 400 MHz FSB: 400x16=6400. So you’d need at least PC2-6400 to run on a FSB of 400 MHz.
    The numbers after that are the main timings (clock cycles). In general, the lower these numbers are, the faster the memory. For more on memory timings, see this page.
    • The first part is self-explanatory (DDR3 memory).
    • The number after it is the data transfer rate. Simply divide it by 4 to get the maximum FSB speed for which the module is rated. Example: 1600/4 = 400 MHz. Therefore, DDR3-1600 can work on systems with a FSB of up to 400 MHz (anything more and you’re lucky).
    • The PC3-XXXXX is designation denoting theoretical bandwidth in MB/s. Some memory manufactures use this instead of the DDR3-xxxx designation. You can calculate it for any FSB you want by simply taking the FSB and multiplying by 32 (rounded in some cases). Example using a 400 MHz FSB: 400x32=12800. So you’d need at least PC3-12800 to run on FSB of 400 MHz.
    4. Power Supply
    There are really two major factors to consider when selecting a power supply:
    1) Quality of the PSU
    2) Power output
    I don’t have the expertise to write up this selection of the guide, so I’ll point you to this nice list written by perkam to use as a guide. More recently, TH.com wrote another article you can check out on the topic.
    There is a great article on power consumption over at TH.com that I suggest you read at your leisure. I distilled out some highlights to underscore how much power systems really use:
    Code:
    Component	Best Case	Worst Case
    Power Supply	5-15 W		40-60 W
    Motherboard	10-15 W		30-50 W
    Processor	12-30 W		60-120 W
    RAM		5-15 W		30-50 W
    HDD		3-5 W (2.5")	10-15 W (3.5")
    GFX Card	3-10 W (on MB)	25-180 W (PCI Express)
    Total		38-90 W		195-475 W
    So you can see that depending on the hardware specs, your system power requirements can approach 500 W.
    There are also a number of good online power supply calculators you can use. Find them with google as always. Here is one such example.
    5. Required Software
    Here are few utilities you'll need to continue, all are freeware.
    General System Info
    CPU-Z is a great app to display your current settings including vcore, FSB, multiplier, RAM settings, etc. This one is a must-have.
    CPU Stress Testing
    Prime 95 v25.6 is a great app for stress testing. It is very efficient at generating CPU loads equally across all your cores. There are few other apps that will stress a system as a hard as p95. Alternatively, if you’re using a 64-bit o/s you can download the 64-bit version of prime95 v25.6.
    I like to use version 25.x over the current “production” version 24.x because it [version 25.x] automatically stresses all your cores without having to load up two different instances of the app like you had to do with orthos.
    System Monitoring
    There are several options for processor core temp and system temp monitoring. For a discussion of what is different between the apps I am about to list, see this thread. PLEASE READ THAT THREAD BEFORE ASKING QUESTIONS ABOUT WHY SOME OF THESE READ DIFFERENT TEMPS!
    These first two will give you just the core temperatures (not system temps, voltages, etc.):
    Core Temp (freeware)
    Real Temp (freeware)
    The next three will give you core temps plus many other temps, voltages, fan RPMs, etc.:
    HWMonitor (freeware)
    Speedfan (freeware)
    Everest Ultimate (shareware $$$)
    Memory Testing (optional but can help rule-out bad memory)
    Memtest86+ is a great piece of software that will test your memory. Download the bootable ISO and allow it to test your system for 6-24 h. I ran it on my machine for a little over 6h 17m with no errors:
    Note that you can’t just run the memory tests without first setting up your memory in your BIOS even though they might be auto configured. This usually entails the user to specify the timings, voltage, and fsb:dram divider prior to running the tests since the memory might be stable at one given set of conditions (maybe 5-5-5-15 @ 667 MHz is stable), not unstable under another (maybe 5-5-5-15 @ 1066 MHz gives errors, but you only tested the 667 MHz level)!
    Do NOT trust the temperatures that your motherboard's free temp utility reads. "PC Probe 2" that comes with Asus boards really sucks because it's not measuring your core temps. They are what you really care about.
    There are other temp monitoring programs out there. These are what I recommend.... I'll only mention one other by name with the advice that you do NOT use it: TAT (thermal analysis tool). It's made by Intel and I don't care what anyone else out there thinks: it was NOT designed to read the coretemps of a C2D/C2Q chip. It was written for Pentium M chips. Yes, it will display temps, and yes, sometimes they match up with the values Coretemp/HwMonitor display, but I have found that TAT often reports temps higher than the real values. How do I know this? Read this thread and pay attention to uncleweb's instructions to use crystalcpuid to directly read your DTS (digital temperature sensor) and calculate your core temp yourself if you don't believe me.
    BIOS Settings
    Let's look for some settings in your BIOS. Not all boards are the same. The following terms/pics are taken from my old P5B-Deluxe; other manufactures will likely have their own names for these settings. You're on your own to figure them out (shouldn't be that tough). It goes without saying that your board will have these organized differently as well.
    Lemme apologize upfront for the poor quality images below. I have no idea how to effectively photograph a computer monitor. I just used a cheap p&s camera with the lights off. You can still read them.
    First thing you want to do is change a few settings, I'll take them in order as they appear in the BIOS:
    Modify Ratio Support - disabled, but you can if you want to select a different multiplier. For the Q6600, 9x is the highest as I said. If you enable this, you can select a lower one if you want, some people think a lower multiplier and a higher FSB is better. For example: 9x333 = 3.01 GHz and so does 8x375. In my experience, doing this can lead to faster synthetic benchmark scores, but most real-world applications usually don't go appreciably faster.
    C1E – Intel’s so-called enhanced halt state. Read Anandtech’s blurb about it here for more. Disable initially, enable later on and see if the system remains stable. This is a power savings option.
    Max CPUID value limit – disable unless you’re running an older O/S like Windows NT.
    Vanderpool – disable unless you’re running VMWare or virtualPC; this option enables additional extensions within the processor that yields added acceleration when running multiple O/S’s on the same machine through virtual machines.
    CPU TM function – enable. Option affects CPU protection/throttle management to help you when you don’t realize you’re pushing your chip too hard.
    Execute Disable Bit - enable. XP has a setting to help with virus protection and requires this set to enable.
    PECI – This stands for Platform Environment Control Interface - disable or enable. This affects how your DTS (Digital Thermal Sensors) report the core temps of your CPU. I have mine enabled and have read several posts now that suggest having it enabled does indeed give more accurate core temps. I can’t say if you want it on or off in your system.
    According the Asus P5B-Deluxe FAQ, this setting toggles between two temp modes.
    Note: if you’re using a real core temperature monitoring application such as coretemp (mentioned and linked above), this setting has no effect that I can see.
    SpeedStep - Automatically lowers the multiplier from its max. (9x for the Q6600) to 6x when the machine is idle. The result is less power consumption and heat production. It goes back up to 9x when you start to get a CPU load. Disable initially, enable later on and see if the system remains stable. This is a power savings option.
    Why do you care about power savings? Increased power consumption translates into increased heat production. As well, power costs money and unless generated from a nuclear power plant, creates carbon dioxide gas. It’s true that energy savings will only matter when the machine is idle, but odds are your machine will spend most of its time at idle unless your run an app like [email protected] or [email protected] etc. Let’s assume for the sake of discussion that enabling these saves you 10 cents / day. A few pennies per day will add up over time. Using the dime-per-day as an example for a machine running every day is roughly a savings of $35 per year – not too shabby.
    Tomshardware.com's power savings article reported a savings of 12 full watts by enabling speedstep on their test system.
    Second thing you'll want to do is dial in the manufacture’s specs for your specific memory. Also take care not to exceed the design specs for your memory initially. We want to minimize the number of variables to deal with on a first time overclocking. In other words, if your machine isn't stable, you want to be sure it's due to the CPU settings, NOT the memory timings.
    Where can you get the manufacture’s specs? Try their website or the product packaging.
    Enter in the first four timings (4-4-4-12 in my case) and don’t mess with the default or auto values for the “sub timings” at this time. You can do that after you get a stable overclock.
    The only other setting worth mentioning here is the so-called “memory remap feature.” If you are running with more then 3 gigs of memory, and you want to actually have the BIOS/OS see it, you’ll need to enable this. Also enable this if you’re running a 64-bit operating system.
    Next, find the section where you can control the nuts and bolts of your system. On my P5B-Del I had to switch the AI tuning to "manual" mode to see these options:
    CPU Frequency - This is the FSB in MHz. Set it to whatever you’re planning to multiply by 9x (333 in my case).
    DRAM Frequency - This the speed your RAM will run. Make sure you don’t exceed the amount for which your specific RAM is rated.
    Most good boards will offer several fsb:dram dividers. Some common ones are listed below. Assuming that you’re using a 333 MHz FSB the ratios are:
    Code:
    FSB : DRAM
    1:1 = 333 MHz : 667 MHz
    4:5 = 333 MHz : 833 MHz
    2:3 = 333 MHz : 1,000 MHz
    5:8 = 333 MHz : 1,066 MHz
    3:5 = 333 MHz : 1,111 MHz
    1:2 = 333 MHz : 1,333 MHz
    Now, if you’re running @ a 400 MHz FSB, the ratios become:
    Code:
     FSB : DRAM
    1:1 = 400 MHz : 800 MHz
    4:5 = 400 MHz : 1,000 MHz
    2:3 = 400 MHz : 1,200 MHz
    5:8 = 400 MHz : 1,280 MHz
    3:5 = 400 MHz : 1,333 MHz
    1:2 = 400 MHz : 1,600 MHz
    You can calculate these yourself with this formula:
    Code:
    DRAM Final Clockrate = (2 x FSB)/Divider
    Example, 2/3 divider @ 400 MHz FSB: (2 x 400 MHz)/(2/3) = 1,200 MHz
    Running in 1:1 mode is termed, “synchronous mode.” If you use a higher frequency, you’re running is so-called “asynchronous mode” which offers marginal speed advantages at the price of more heat and power consumption on a C2D/C2D Quad-based system for most users. Depending on your chipset, running in an asynchronous mode may require more vcores to some of your motherboard components such as the NB, IHC, and/or FSB Termination (more on these later).
    PCI Express Frequency – Set this to 100 MHz. If you don’t, I believe the PCIe bus speed will increase proportionally with your FSB which is something you DON’T want to do to your expensive video board.
    PCI Clock Synchronization - Use 33.33 MHz here. Again, if you leave the setting on auto, the PCI clock will creep up proportionally with your FSB which can damage cards you may have there aren't designed to run at higher frequencies.
    Spread Spectrum - disable.
    Memory Voltage - Read the specs for your memory. My DIMMS can use up to 2.2v. You can damage your memory if you overvolt it.
    CPU VCore – THIS IS KEY! This single BIOS setting will have the largest effect on your processor’s operating temperatures! Again, read on to the section entitled, “Stress Testing and Minimizing Your Vcores.”
    It needs to be enough to run stable, but not too much or else you’re just wasting power and creating a ton of heat. This is particularly true with multicore processors!
    In case you’re wondering what Intel recommends for your processor, find your chip on Intel's Processor Finder. The Q6600 is between 0.85 – 1.5V.
    In my experience, a setting of “auto” ALWAYS over-estimates, but for your first boot, just leave it on auto. The next section of this guide covers stress testing whose goal is to verify stability and to minimize your vcore. For example, once you verify that you can run stable for several hours of stress testing, you'll want to come back and minimize this voltage until you become unstable again. Then simply add a little back. As you can see, my system runs stable @ 9x333 using 1.2625v.
    The last four voltages are also required to make a stable system. Leave them on auto for now. On my system, I lowered my chipset temps by about 4 °C by lowering them to the values you see in the pic.
    As I mentioned earlier, if you’re using high memory dividers (a.k.a. running your memory in asynchronous mode), you might have to manually tweak your NBvore and your ICH vcore to get the memory to run stable. For example, my Q6600/P5B-Deluxe system required me to up the NB vcore by +2 steps and the ICH vcore had to be set to the maximum value or else I couldn’t run my PC1066 memory at the higher dividers.
    My X3360/LT P35-T2R system on the other hand, didn’t require nearly that much extra to run in the 5:6 divider.
    In general, the P35 chipset is better than the P965 in this regard. I have read that the X38/X48 are on par or slightly superior to the P35.
    Okay, save your settings and hopefully your machine will complete the POST.
    If it doesn’t, and assuming you set your voltages to Auto, some common reasons are:
    • Memory voltage too low
    • Memory timings too aggressive
    • FSB too aggressive
    If you complete the POST, and make it into windows without a blue screen or reboot that's a good sign. Now on to the testing. Now that you're in Windows, load up CoreTemp or HWMonitor and have a look at your core temps when idle.
    They should be well under 50 °C unless it's REALLY hot in your room, see the end of this document for more on how ambient temps affect your CPU load temps. There are a number of things you can do to bring down your idle and load temps. Again, see the end of this guide for some suggestions.
    Let's stop here and figure out what the red-line for temps should be... for my B3 stepping of the Q6600, I don’t want to exceed a few degrees over Intel's 62 °C limit for any sustained period of time. The G0 stepping chip tolerates 71 °C, so you're probably safe a few degrees above that. You can decide on your own "red line" if you disagree with my admittedly conservative numbers. Here is some information you can use to help: Intel's Processor Finder. Read the Thermal Specification section. Wondering what the deal with the stepping of the chip is? Have a look at this article that will explain it as well as show you some differences between the new G0 stepping quads.
    I may be misunderstanding it, but as I read it, the thermal specs are the upper limit for the "case temp." No C2D or C2D quad processor actually has a sensor for "case temp" as defined by Intel. To measure this, you would need to place a sensor on the top of your IHS right in the center. C2D/quads have INTERNAL sensors (called DTS or Digital Thermal Sensors) but not external sensors. Some software and BIOS's can approximate this "case temp," but without a physical sensor there, you're just guessing.
    The formula for reading core temp from the DTS is:
    Code:
     Core Temp = tjmax – DTS
    Where DTS is the number the DTS is reporting, and tjmax is a constant (which differs with processor model and sometimes within a processor model based on its stepping)
    Note: There is no official communication from Intel as to the magnitude of tjmax for desktop/server C2D/C2Q chips! This makes calculating the “real” core temp tough since people are just guessing.
    For example, a Q6600 (G0) stepping may have a tjmax of either 95 or 105 (again, these are people’s best guesses). If tjmax is 105, then Core Temp = 105 - DTS. THIS DOESN'T MEAN THAT THE LIMIT FOR THE CHIP IS 105 °C! In this example, let’s say the DTS value is 50. Therefore, Coretemp = 105-50 = 55 °C. If tjmax is 95, the math becomes 95-50 = 45 °C. Don’t worry about doing this calculation; all the temp monitoring software will do it for you. I only mention it so you can understand what’s going on.
    I like to keep my core temps under 65 °C. I may be using a conservative number here, but I don't want to replace my chip anytime soon. If you don’t care about the longevity of your chip, you can likely use higher numbers. I have read about people running their chips right up to the factory shutdown/auto throttle down temp. It’s your chip, do what you want.
    Load up CPU-Z to see what your vcore is at idle.
    You’ll notice that the vcore in CPU-Z is different from the value you selected in your BIOS. This is normal and true for all boards. You’ll also notice it drops again when your machine enters a load state: again, this is normal and known as vdroop; some boards/chipsets do it worse than others. If you read at the end of the guide, some boards can be modified to eliminate or greatly reduce vdroop.
    The goal of stress testing is two fold:
    1) To arrive at a stress test stable system (>24 hours with no prime95 errors).
    2) To minimize your vcores and thus minimize heat product both on your CPU but also on your NB/SB and other MB components.
    Prime95 will run and every now and then it will check the values it’s calculating using your processor to its internal standards since its torture testing using known values. Assuming you enable error checking, you’ll be notified if your values differ indicating an instability. This is why it is IMPERATIVE that you enable error checking within Prime95; again, if you don’t enable it, you WILL NOT be notified of errors!
    Do so simply by going to the “Advanced” menu and enabling “Round off Checking.” If the system isn’t stable, it will report an error and stop stressing the core that gave the error.
    Now that you picked your operating condition (i.e. 9x333 or 8.5x400, etc.) let’s stabilize the system through stressing it with prime95. Just so you get an idea what to look for, Coretemp as well as Prime95 (double-check that you enabled round off error checking) and run the Torture Test>Large FFTs. You’ll wanna keep an eye on your system temps to make sure they don’t exceed the redline so the chip doesn’t get throttled (assuming you have thermal management enabled in your BIOS). All your cores should get stressed equally (look in the task manager to verify):
    For your reference, here’s what an error from within prime95 looks like:
    When/if you get an error (and you will), you’ll need to either back off on the operating conditions (FSB or multiplier) or add some voltage to your vcores. Therein lies the challenge. Since you have four different vcores to select from, how do you know which one or which ones to adjust?
    It’s now time to minimize your vcore settings. Reboot and go into the BIOS’ section where you can control your CPU and MB voltages. Remember, different motherboard will call these variables different terms. The pic below is right out of my BIOS so you can see what DFI calls them, and what they mean:
    CPU VID Control – The processor vcore, I’m not sure why DFI calls it “CPU VID Control” but whatever. From here on out, I’m going to call it Vcc since technically, the term VID is an entirely different concept (see this document, page 14 for more if you have an interest).
    DRAM – The memory vcore.
    SBCore – Southbridge vcore (might be called ICH in your board).
    NBCore – Northbridge vcore (might be called MCH in your board).
    VTT – Reference voltage (might be called FSB Termination voltage in your board). It’s used to terminate data lines between the MCH and CPU.
    Some motherboards give the option for GLT reference controls. If you enable this you’re adding three additional variables to the mix and making your life more complicated. Unless you’re an extreme overclocker wanting to squeeze every single MHz out of your system, my advice is not to enable the GLT options. I’d also caution you not to enable this option since there is tons of misinformation out there about these undocumented features.
    If you must, here a few links that might help you understand how it works and give you some starting points, but I won’t be using them in this guide:
    Adjusting [Advanced] Gunning Transceiver Logic (A/GTL+) Voltage Levels for Increased Front Side Bus (FSB) Signaling Margins and Overclocking.
    DFI UT P35-T2R: Tweakers Rejoice!
    Good thread (kinda long) but good info.
    There are several approaches you can use to arrive at a stable, minimized set of vcores. I recommend that you start with lower vcore values and work your way up. Lower values will fail much faster than higher values thus making the process a bit quicker for you.
    To start with, select a set of vcores that are kinda low and see if you can POST. How do you know where to start? Use trial and error at this point unless you know someone else’s settings to use as starting points. When in doubt, I’d recommend that you start near the bottom of the scale. Here are some rough guidelines for setting your VTT:
    1.2-1.3V - for a FSB of ~400 MHz.
    1.4-1.5V – for a FSB of ~420-440 MHz (exceed 1.4V at your own risk with a 45nm chip)!
    1.6V – for a FSB of ~440-475 MHz - use at your own risk with a 45nm chip!
    You should be aware that newer 45nm fab chips are MUCH less tolerant toward high VTT than their 65nm predecessors. Anantech published their experience frying a QX9650 with high VTT’s as an example.
    Vcc – Initially, set within 200-400 mV of where the auto setting used (remember that you need a little more in the BIOS compared to what CPU-Z told you). Remember to consult Intel’s processor finder to know where the upper-end of safety is for your processor (I believe the figures there correspond to the values CPU-Z is displaying, not what you set in the BIOS.).
    DRAM – What ever the RAM manufacture recommends is a good starting point. Unless you’re really overdriving them, they shouldn’t need more.
    SBCore – I’ve always used the lowest setting, but I typically don’t push my systems that hard (20-25 %). You’re on your own here.
    NBCore – Start off low, 1.33 or 1.37 and see if you need more. Also, a little bit can go a long way. My system is unstable @ 1.330V here but stable @ 1.370V which is a difference of only 40 mV (0.04V).
    Here are the levels my Q6600 @ 9x333 uses to run stable:
    Code:
    Memory Voltage=2.100V
    CPU VCore=1.2625V
    FSB Termination=1.200V
    NB Vcore=1.25V
    SB Vcore=1.50V
    ICH Chipset=1.057V
    Here are the levels my X3360 @ 8.5x400 uses to run stable:
    Code:
    Vcc=1.12500V
    SB 1.05V=1.070V
    NB Core=1.370V
    SB Core/CPU PLL=1.550V
    CPU VTT=1.310V
    Here are the levels my X3360 @ 8.5x333 uses to run stable:
    Code:
    CPU Vcc=1.00000V
    SB 1.05V=1.070V
    NB Core=1.330V
    CPU VTT=1.100V
    Note that I haven’t refined these last settings (for 8.5x333) and don’t plan to :) For example, I think it would work with a lower Vcc and NB, but I don’t care enough to test it (these are good enough).
    I show those only to give you an idea, not all hardware is the same, and really, those values are personal to my chip, RAM (and RAM settings), MB, etc.!
    Once you select a baseline set, that will complete a POST, you’ll want to start a more vigorous evaluation by changing the MB vcores one-at-a-time moving forward. If you change too many variables at once, you’ll never be able to arrive at the stable settings. Confused? Don’t be, just read on and after you see the examples, I think the process will seem clearer to you.
    The basic process is to try different Vcc values keeping the other vcores constant. Run p95 at a given Vcc and record what happens after an arbitrary time point (10 to 15 min is good to start with). If Vcc level is stable for 15 min of p95, reboot and lower it a little and repeat. The goal is to find the minimum level that gives errors, then increase it until it’s stable, then extend that time out to say 2-4 h. If it’s still stable, further extend it to 10-14 h. You can probably call it “stable” if you can run p95 for 24 h. If a setting fails after 4 h, increase it one notch or so and repeat until it’s stable out to 24 h. You can then come back knowing this Vcc and try to lower one of the other vcores repeating the process. Yes, it’s time consuming and yes, it’s tedious, and yes, that’s a shitload of rebooting, but it works.
    The key to this process is keeping a detailed record to help you achieve a stable system and troubleshoot which vcore to change – p95 errors are NOT always the fault of a low Vcc! Without these data, you’ll have a tough time. So what do you keep track of here?
    1) The MB vcores you’re using
    2) The Vcc values you’re testing
    3) Which core failed (prime95 tells you) and how long it took to fail
    4) Any observations or comments you want to record for yourself
    Here are two examples minimizing vcores using my X3360/P35-based system. The data presented aren’t fabricated to help illustrate the method; rather, they are the real data I used to arrive at the stable system. Also know that to really really do this right, you’d need to do several runs at the various levels; doing it just once as I am is the quick ‘n dirty approach and can cause you to draw an incorrect conclusion or two as you will see.
    Example 1: 8.5x400
    Hardware specs for your reference:
    I set up my MB vcores and began testing Vcc starting low (I chose 1.12500V somewhat arbitrarily).
    Keeping the motherboard vcores constant, I varied the Vcc starting out low and working up high. You may or may not get a stable system on your first set of iterations (probably not actually). If you do, you’ll probably want to repeat keeping your stable Vcc but optimizing (minimizing) for one of the other vcores such as NB or VTT, etc.
    Code:
    Overclocking log, Iteration Set 1
    Comments: Initial try
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    VTT	1.200V
    Vcc/Prime95 success or failure
    1.12500V	Failed on core 3 ~ 5 min
    1.13750V	Failed on core 0 ~ 28 min
    1.15000V	Failed on core 2 ~1 h 18 min
    1.16250V	Failed on core 1 ~ 4 h 4 min
    Looking at the data, we see there that multiple cores have failed as I increased the Vcc. That’s suggestive of one of the other voltages lacking and thus needing to be increased. There are two likely causes for my instability: NBCore and VTT. In my next Iteration set (below), I chose to raise the NBCore several notches keeping the rest of the MB vcores constant.
    For discussion’s sake, let’s say the same core failed repeatedly. This scenario is likely caused by a low Vcc (although it doesn’t have to be). For you quad core users, cores 0/1 and cores 2/3 should be treated the same, so if you get some core 0 and core 1 failures, treat them like a single core failure as you consider this analysis.
    So, I increased the NBCore a few notches and tried a few higher Vcc settings just to see if it was enough:
    Code:
    Overclocking log, Iteration Set 2
    Comments: Added some NBCore
    DRAM	2.100V
    SBCore	1.55V
    [b]NBCore	1.41V[/b]
    VTT	1.200V
    1.16250V	Failed on core 2 ~2 min
    1.17500V 	Failed on core 1 ~3 min
    Again, I got two quick failures across the entire chip. Ideally, you might want to collect more data points, but I took a hunch that 1.45V should be plenty for 8.5x400, and next added some VTT keeping the newer, higher NBCore constant – remember to only change one of them per iteration set!
    Code:
    Overclocking log, Iteration Set 3
    Comments: Added some VTT and kept the higher NBCore
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.41V
    [b]VTT	1.310V[/b]
    1.17500V	STABLE 15 min
    1.16250V	STABLE 15 min
    1.15000V	STABLE 15 min
    Now, with the higher VTT, I didn’t get a single failure for at least 15 min at the three Vcc values I ran. I concluded that the VTT gave me the stability. To test this hypothesis, I kept the higher VTT, but lowered the NBCore back to 1.37 and repeated in the 4th iteration:
    Code:
    Overclocking log, Iteration Set 4
    Comments: Kept the VTT, lowered the NBCore
    DRAM	2.100V
    SBCore	1.55V
    [b]NBCore	1.37V[/b]
    VTT	1.310V
    1.15000V	STABLE 2 h
    1.13750V	STABLE 30 min
    1.12500V	STABLE 1 h
    1.07500V	crashed p95 (n=2)
    1.09375V	crashed p95 (n=1)
    1.10625V	BSoD after 1+h
    1.11875V	STABLE 11 h
    1.11250V	Failed on core 0 ~ 1 h 8 min
    Now I got some stable runs. After evaluating the data, I was able to nail down both my NB and VTT in only 3 iteration sets, arriving at what I thought was the stable Vcc in the 4th (I was later wrong).
    It’s a little easier to visualize if you sort the Vcc from low to high. If you keep your log in a spreadsheet, you can easily sort them, here are the same data sorted by Vcc:
    Code:
    DRAM	2.100V
    SBCore	1.55V
    [b]NBCore	1.37V[/b]
    VTT	1.310V
    1.07500V	crashed p95-program exited (n=2)
    1.09375V	crashed p95-program exited (n=1)
    1.10625V	BSoD after 1 h
    1.12500V	STABLE 1 h
    1.15000V	STABLE 2 h
    It would seem as though 1.11875V was the winner. I could have stopped right here and repeated extending the time out to 24+ h with these settings, but I elected to further optimize and targeted the VTT since I thought I could do better having jumped from 1.20 to 1.31 and skipping 5 sub levels in the process. This time through, I held the Vcc constant and varied, VTT:
    Code:
    Overclocking log, Iteration Set 5
    Comments: 1.11875V seemed stable, minimizing VTT
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    [b]Vcc	1.11875V[/b]
    VTT/Prime95 success or failure
    1.250V	Failed on core 0 ~ 2 h
    1.260V	Failed on core 2 ~ 1 h 20 min
    1.280V	Failed on core 0 ~ 18 h 22 min
    1.310V	Failed on core 1 ~ 1 h 20 min
    This one is a little puzzling since the 3rd run (VTT=1.280V) lasted for over 18 h, yet the 4th run with a higher VTT died in under 1-1/2 h. My thinking was that VTT wasn’t the problem, and that I had been mislead on the Vcc. I was also getting a little anxious for this to be finished and I broke my own cardinal rule for the next iteration set by upping two variables at once: Vcc to 1.12500V and VTT to 1.310V.
    Code:
    Overclocking log, Iteration Set 6
    Comments: 1.11875V seemed flaky, so upped the Vcc and kept the higher VTT.
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    [b]VTT	1.310V[/b]
    [b]1.125000V[/b]	STABLE 21 h 34 min
    Okay! So maybe it was the Vcc after all since it ran for over 21-1/2 h before I stopped it. You could argue that there’s no difference between 18-1/2 h and 21-1/2 h and you would have a valid argument. This underscores the need to collect multiple data point per level as I mentioned in the beginning of this section (I told you it was quick ‘n dirty)!
    Finally, I set out to essentially repeat my Iteration Set 5 minimizing the VTT with the slightly higher Vcc.
    Code:
    Overclocking log, Iteration Set 7
    Comments: 1.12500V seemed stable, minimizing VTT
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    Vcc	1.12500V
    1.250V	Failed on core 0 ~ 1 h 3 min
    1.280V	Failed on core 1 ~ 1 h 0 min
    1.310V	STABLE 34 h 41 min
    Apparently VTT needs to be 1.310V on this system.
    For example 2, I just wanted a REALLY quick n’ dirty slower setting for my PC that I could use for non-CPU intensive computing since it’s summer now and I wanted a setting that would minimize the heat output for general computing. I’ll reboot into 8.5x400 if I want the faster speed. As such, I didn’t follow my own rule about changing only one variable at a time in the final iteration as you’ll see.
    Example 2: 8.5x333
    Initially, I kept the Vcc from my 8.5x400 run knowing it should be stable for less clock (stock in this case) and wanted to see if I could run a lower VTT. I also chose the lowest NB core.
    Code:
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.30V
    Vcc	1.1250V
    1.170V	Stable 15 min
    1.100V	Stable 15 min
    As you can see, the lowest VTT was stable for 15 min. I went right to the Vcc using these values.
    Code:
    Comments: minimizing vcc
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.30V
    VTT	1.10V
    1.00000V	Stable 15 min
    0.96250V	Stable 15 min
    0.93125V	BSoD (wouldn’t get into Windows)
    0.93750V	“
    0.94375V	“
    0.97500V	Stable 15 min
    So here you can see that 0.97500V ran just fine for 15 min. At this point I figured I would also see if I could drop my memory vcore since 2.1V is required for >1,000 MHz and that 667 MHz should require less. Honestly, I should have let this run for 8-12 h before changing another variable.
    Code:
    Comments: minimizing dram core
    SBCore	1.55V
    NBCore	1.30V
    VTT	1.10V
    Vcc	0.97500
    DRAM Vcore/Prime95 success or failure
    1.91V	Stable 15 min
    1.80V Failed on core1 after 35 min
    As you can see, 1.80V wasn't enough (or it could be that my previous settings weren't enough since I only ran them for 15 min)! I decided again to break my own rule about change more than one variable since I don’t really care to find the absolute minimum set of vcores for the stock setting. I upped the NBCore from 1.30V to 1.33V, and also added back some Vcc from 0.97500V to 1.00000V and kept the 1.91V on the DRAM for the final set:
    Code:
    Comments: changed several things!
    [b]DRAM	1.91V[/b]
    SBCore	1.55V
    NBCore	1.30V
    VTT	1.10V
    1.00000V	Stable 18 h
    I stopped it after 18 h since I won’t be using this setting for CPU-intensive stuff. This stock level is just to have a lower heat/lower energy mode for web browsing/general computing.
    In any case, those examples should serve to illustrate the method you need to use to attack the task.
    To summarize, using a stepwise approach and documenting your runs, you should be able to arrive at a stable system (assuming your hardware can operate at the level you choice). It probably goes without saying that you will need to repeat this process if change your operating conditions (multiplier and FSB).
    An overclocked quad system is often limited by the amount of heat it’s producing, and the ability of the heat sink and fans to dissipate it. If you’re getting high temps, there are a number of things you can do to help. Most of them are hardware related but the first is the single most important non-hardware change you can make:
    • Minimize your vcores first (described in the guide above)!
    • Ensure good contact between the CPU and Heat sink is a must for efficient heat transfer. A major bang-for-the-buck modification in this regard is lapping the surfaces that transfer heat (the base of your heat sink and the top of your CPU). This involves gently moving the surface along wet/dry sand paper in increasing grits on a flat surface such as a piece of glass. I did both the base of my Ultra-120 Extreme and the IHS (Internal Heat Spreader) on my Q6600 and saw some pretty dramatic decreases in load temps.
    It should be noted that lapping your HS and/or CPU will void the warranty. Comparing my stock HS/CPU to my lapped HS/CPU, on average lapping lowered the coolest core by 7 °C and the hottest core by 10 °C. To read more about lapping your heat sink and CPU see these two threads; I have results and pictures of the process:
    Lapping Q6600 IHS
    Lapping the Ultra-120 Extreme
    That said my X3360 did not need to be lapped. I’m not sure if Intel is doing this with all their 45nm chips or just the Xeons, but it came from the factory very flat. When I run prime95, the heat spread between cores is 2-3 °C.
    • If your NB chipset runs too hot, consider adding a small fan. I put a silent 40x40x10mm fan on my NB HS via a zip tie which lowered my NB temps by ~7 °C on load. Pretty amazing effect for $3 fan and free zip tie :)
    • Consider an upgrade to a more efficient heat sink (like the few mentioned in the beginning of the guide). Remember that a quad core chip will produce about 2x the heat compared to a dual core chip. You really do need to consider using an extreme HS if you plan to overclock a quad.
    • Consider an upgrade to the cooling fan on the heat sink to something that has more flow. Most of the larger HS’s will use a 120mm fan. Some have the option for two fans. I think the fastest 120mm fan you can use is around 1600 RPMs. If you have a slower one, you might consider upgrading.
    • Reseat your heat sink and make sure you’re using a quality TIM (thermal interface material) such as AS5. Consider rotating the HS 90 degrees if it is designed to do so. I seem to get better contact with my Ultra-120 Extreme when it’s orientated “North/South” than when it’s orientated “East/West.”
    • Re-evaluate the way you’re applying the TIM/don’t use too much or make sure you’re using enough. Thermal pastes aren’t all created equally. Some are reported to be better than others. I have always used Arctic Silver 5 on my CPUs (and AS3 and AS1 before that). You can find all sorts of posts out there showing one to be better than another. I’ll leave it up to you to pick one. Again, I like AS5. Here is a shot of my q6600 installed in the MB with AS5 right before I added the HS. It shows the right amount in my opinion given a lapped HS and CPU (which is a thicker line than I used before); the red triangle I drew shows where that tag is on the CPU, remember that on quad core chips, the dies are placed in a different located relative to a dual core, see the instructions on AS5's website for more on this.
    • Use good cable management inside your case. Use twist ties or tie downs to bunch cables and keep them out of the way of airflow.
    • Make sure you have adequate airflow inside the case and make sure you’re using a well ventilated case. People often overlook this, but it’s important. Not all cases are designed for good airflow. I have an Antec P182 which is a great design. Make sure you have several exhaust fans and at least one intake fan. 120mm fans move more air than smaller 80mm fans do and also run much more quietly.
    You can see that my CPU load temps will increase/decrease as the ambient temperature fluctuates. Have a look at the following thread for details:
    Effect of room temp on CPU load temps
    Controlling vdroop
    Remember the vdroop you saw earlier? If you have a P5B-Deluxe (I believe this works on any of the boards in the P5B family actually), you can use a pencil to modify your board to minimize or fully remove this idle-to-load vdroop. Read the following thread if you want to do that:
    Get more vcore under load: vdroop pencil mod (pics)
    That's it for the guide. I hope you got some good info out of it and are able to successfully o/c your system as a result!
    1 person likes this.
  2. PsYkHoTiK
    PsYkHoTiK Admin nerd
    In regard to #3.
    It is my understanding that it is platform dependant primarily (as well as application dependant). I know it will affect it regardless to a certain degree. Intel platforms tend to put more weight on bandwith rather than latency. I tend to swing more on total ram speed (bandwith) especially with the huge apps of this period (well games primarily). But once I reach the speed I want, I then try and tighten the timings (like I'm in the process of right now). This would make a great article/discussion though. :)
    Here's a quick dirty test (though in proper benching environments) HERE.
    4 Power Supply
    I can't stress enough how important a good PSU is. Its a fact that people seriously put the least amount of thought to their PSU. The fact of the matter is a good PSU supplies you the juice you need. The fine point a superb PSU makes is that not only does it supply you the juice, but it supplies it well (solid rails, ultra reliable). Some people go with cheapo PSUs saying that its cheap so if need to, they'll buy another. If they want to gamble with their hardware (PSU blows and takes hardware with it) then iits really their choice. Plus for the price of 2 cheapo ones, you could have gotten a really good one. I have an old 350w Enermax that runs to this day solid as ever (5 years old), a OCZ Powerstream 520w that has been running for 3 years now, and I expect my Silverstone OP650 to have many more years of service. Solid rails that don't even flinch under full load.
    5. Required software
    Speedfan = I'm not too big of a fan of speed fan. Temps were off by quite a bit compared to other sources (TAT, Asus monitoring). The fact that it mis read my voltages and screamed out a siren style warning did it for me and I promptly removed it from my computer. I check my 12 & 5 volt rails through my handy dandy multimeter. But if they get your voltage right, its still a reasonable measure (I have to say I am still a fan of MBM5. :( ). But in essence, all of them are software monitoring so its still up in the air I guess. I wish CoreTemp would work on Vista (hurry up! :o ).
    Prime: Orthos small FFTs (as Chai pointed out in a different thread) only tests at 8K. This wont do for stability (unless if you manually set it). I've had 4GHz 12 hour Orthos stable but 12 minutes prime stable (lol BSOD ftw).
    Overclocking:
    C1E and Speedstep. The way to check for stability for these two would be NOT to have any load and let it drop the multi & vcore. Once you load, it will be at full speed (and hence not matter). I think when highly OC'd, its drop in vcore kinda starves high FSB setups and leads to a crash. The design of these two is to provide max power when needed without feeling the 'lag' of the transition.
    Vcore: There should only be two limits to Over Clocking. One is vcore. Stick with a safe vcore. I never do more than +0.3v then stock voltage. The second limit is Load temp. I personally have a lower tolerance for vcore which is 60C. I get uncomfortable as soon as something hits the mid 50s. Between that and this, the sky is the limit. Quads do run quite a bit hotter (understatement). The G0 stepping does help alleviate it to a certain degree but it is still very hot.
    CPU-z: It is from my current understanding that CPU-z DOES NOT properly read vcore at this time.
    Vdroop: It is a problem on the P5B series. Asus has addressed that with the P5K deluxe and Premium (as well as the Blitz Formula) with a Vcore Damper option in BIOS. Vcore is now stable (no vdroop what so ever).
    In essence, great article. I believe you have touched base and emphasized on things that are real important. Good airflow is a must, emphasize on real world (but I am a SuperPi nut), and all the important components. I commend you highly for the time and effort taken for this article. Good job! :arp: :beer: :thumb: :clap:
    For any others wanting to learn how to OC, this is pretty much independant of platform. Voltages may differ but practises are the essentially same.
  3. PsYkHoTiK
    Also, the way I've always OC'd is to keep increasing the FSB at intervals (I do increments of 10) and when it becomes unstable, I simply up the vcore a notch. This is a bit more hardwork, but eliminates having to go back down to find what is the minimum vcore it can run. Of course the upper limits are a 60C load (for me) and +0.3v max.
  4. graysky
    Thanks for the critique and the kind words dude.
    ...when you recommend +300 mV of stock, are you referring to the max specs for the class of chips (for a Q6600 the max vcore Intel recommends is 1.372 V) or are you referring to the VID which can differ per chip? My VID for example is 1.2875V.
  5. PsYkHoTiK
    Well I look at the stock volts of the chip. i.e: if its say 1.3v stock for your chip then I'd go up to 1.6v (gulp). Really dependent on what your chip is rated to do @ stock. Now I typically wont go above 1.6v on C2Ds. Way too much heat.
  6. graysky
    Did a kind of significant update to the guide. Enjoy!
  7. Max_87
    Max_87 huehuehue
    Nice guide :thumb:
  8. Mantrhax
    Mantrhax Newbie
    Sweet, My e6600 is going to be OCed......
    Thanx for the tips
  9. graysky
    How'd it go?
  10. graysky
    Small update preformed.
  11. graysky
    Version is now 1.5.2 (updates in first post)
  12. Trouz0rz
    Trouz0rz Newbie
    ok, well ive got a c2d t7250 with an 800mhz fsb in my laptop, but 2gb of ddr2-667 ram.....
    does this mean my fsb is being limited?
  13. graysky
    No, because the FSB on the T7250 isn't really 800 MHz. That's the "quad pumped" number, so you take 800/4=200 MHz FSB. Your DDR2-667 will do at least 667/2=333 MHz.
  14. Lacus
    Lacus Newbie
    Too bad for Intel platform :(. Any guides for AMD platform?
  15. graysky
    The steps are more or less the same...
  16. Lacus
    Lacus Newbie
    Well, yeah..Almost.. Lucky my proc is a multiplier unlocked. Much easier to oc compare to normal processor :D
  17. graysky
    OK, just got finished upgrading the guide to version 1.6!
    • Added a detailed section to help you find the minimum stable CPU and MB vcore settings. Check it out (near the bottom of the guide entitled, “Stress Testing and Minimizing Your Vcores”)!
    • Updated the CPU table
    • Provided a less than $5 method you can use to shave off some NB load temps (in the thermal management section at the end of the guide).
  18. Mac Daddy
    Thanks for the update man still reading through this its good reference :thumb:
  19. Adrian Wong
    I'll update the title for you. :thumb:
  20. graysky
    Cool man, I noticed it was stuck :)
