Huntkey Launches GS Series Power Supply
Discussion in 'News' started by Adrian Wong, Nov 25, 2015.
  1. Adrian Wong
    SHENZHEN, CHINA, November 24th, 2015 - Huntkey Enterprise Group, a global professional power supply provider, has unleashed its new GS series power supply, the GS500 and GS600. Suitable for gamers, Huntkey's next-generation power supply system is a series of cost effective power supplies capable of high efficiency.
    The advantages of the new GS series power supply can be summarized as follows: using an 80% more efficient smart fan design, which also reduces fan speed and lowers noise, the GS series generates less heat in the user’s computer, thus saving money from electricity bills.
    With powerful Dual +12V rails, the highly stable power supply supports high end graphics cards and PC systems, meaning that even for non-gamers, Huntkey's new GS series has a broad range of use.
    Huntkey GS600 Specifications
    Model Name: GS600
    Max. Output: 600W
    Rated Output: 500W
    Active PFC
    Efficiency: 80% at typical load
    Supports back cable management
    Connectors: 20+4pin
    (4+4)pin for CPU
    4*SATA
    1* 4pin for HDD/ODD
    PCI-Express: 2* 6+2pin
    Safety Certification: CB, CE
    Huntkey GS500 Specifications
    Model Name: GS500
    Max. Output: 500W
    Rated Output: 400W
    Active PFC
    Connectors: 20+4pin
    (4+4)pin for CPU
    4*SATA
    1* 4pin for HDD/ODD
    PCI-Express: 2*8pin
