i wonder what could it be....the father, the son and the holy spirit??? btw...i tot we werent suppose to be talking bout piracy stuff here...??
i would recommend Azureus over ABC dashken n psykhotik(sp?). the last version of ABC that was truly stable was 2.6.1 and btw, Azureus eats much less resources then ABC and yes i want a ARP dc++ hub
Azurues sucks because you have to install Java runtime, and I think that consume quite some amount of resources... ABC 2.68 rocks! Works extremely well.
nope, right now i'm seeding 1 file and last time i used ABC, it took around ~30mb this is what task manager shows me now
there's no java VM process there......the only process with the word java is javaw.exe.......nothing else pic's been resized due to the original 1024 x 768 is over the 150kb limit edit: and i'm seeding a *ahem*400+ mb ISO file*ahem*
did a check.......when i closed azureus and opened azereus again.....the commit charge jumped by 54mb...... and btw, how do we check for virtual memory usage?
Told ya there are always compromises...Virtual Machine normally takes up a lot of resources, and I was right. I don't want to install VM unless it's necessary. I run DF, so every MB counts. ABC rocks!
2.6.5 was very unstable. I didn't even tried it though. I was using 2.6.1 until tracker support problem, so I upgraded to 2.6.8. Rocks! So your arguement about Azureus using less resources is wrong.
