My DVR's wana be gateways...
Discussion in 'Internet & Networking' started by mrowcp, Jan 21, 2011.
  1. mrowcp
    mrowcp Newbie
    Hello,
    I have a big problem with my DVR's.They wana take my gateway IP address:
    # arping 192.168.80.1
    ARPING 192.168.80.1
    60 bytes from 00:d0:89:02:63:78 (192.168.80.1): index=0 time=13.956 msec
    60 bytes from 00:d0:89:03:b0:80 (192.168.80.1): index=1 time=15.965 msec
    60 bytes from 00:d0:89:03:b0:08 (192.168.80.1): index=2 time=17.971 msec
    60 bytes from 00:d0:89:03:93:bc (192.168.80.1): index=3 time=19.981 msec
    60 bytes from 00:d0:89:02:63:48 (192.168.80.1): index=4 time=21.988 msec
    60 bytes from 00:d0:89:02:63:7c (192.168.80.1): index=5 time=23.995 msec
    60 bytes from 00:d0:89:02:62:aa (192.168.80.1): index=6 time=26.003 msec
    60 bytes from 00:50:56:9a:75:9f (192.168.80.1): index=7 time=28.013 msec
    60 bytes from 00:d0:89:03:b0:08 (192.168.80.1): index=8 time=13.992 msec
    60 bytes from 00:d0:89:03:b0:80 (192.168.80.1): index=9 time=16.002 msec
    60 bytes from 00:d0:89:03:93:bc (192.168.80.1): index=10 time=18.013 msec
    60 bytes from 00:d0:89:02:63:78 (192.168.80.1): index=11 time=20.018 msec
    60 bytes from 00:d0:89:02:63:7c (192.168.80.1): index=12 time=22.025 msec
    60 bytes from 00:d0:89:02:63:48 (192.168.80.1): index=13 time=24.034 msec
    60 bytes from 00:d0:89:02:62:aa (192.168.80.1): index=14 time=26.042 msec
    60 bytes from 00:50:56:9a:75:9f (192.168.80.1): index=15 time=28.052 msec
    60 bytes from 00:d0:89:02:63:48 (192.168.80.1): index=17 time=16.004 msec
    60 bytes from 00:d0:89:02:62:aa (192.168.80.1): index=20 time=22.029 msec
    60 bytes from 00:d0:89:03:93:bc (192.168.80.1): index=21 time=24.037 msec
    60 bytes from 00:d0:89:02:63:7c (192.168.80.1): index=22 time=26.044 msec
    60 bytes from 00:50:56:9a:75:9f (192.168.80.1): index=23 time=28.052 msec
    60 bytes from 00:d0:89:03:b0:08 (192.168.80.1): index=24 time=13.994 msec
    60 bytes from 00:d0:89:03:b0:80 (192.168.80.1): index=26 time=18.012 msec
    60 bytes from 00:d0:89:02:62:aa (192.168.80.1): index=27 time=20.018 msec
    60 bytes from 00:d0:89:02:63:7c (192.168.80.1): index=28 time=22.026 msec
    60 bytes from 00:d0:89:02:63:48 (192.168.80.1): index=29 time=24.035 msec
    60 bytes from 00:d0:89:02:63:78 (192.168.80.1): index=30 time=26.041 msec
    60 bytes from 00:50:56:9a:75:9f (192.168.80.1): index=31 time=28.054 msec
    60 bytes from 00:d0:89:03:93:bc (192.168.80.1): index=33 time=16.004 msec
    60 bytes from 00:d0:89:02:63:48 (192.168.80.1): index=36 time=22.027 msec
    192.168.80.1 is FreeBSD le1 NIC.
    As you can see, there are 7 dif. MAC addresses:
    1 MAC - 00:d0:89:02:63:78
    2 MAC - 00:d0:89:03:b0:80
    3 MAC - 00:d0:89:03:b0:08
    4 MAC - 00:d0:89:03:93:bc
    5 MAC - 00:d0:89:02:63:48
    6 MAC - 00:d0:89:02:63:7c
    7 MAC - 00:d0:89:02:62:aa
    and
    8 MAC - 00:50:56:9a:75:9f is my FreeBSD le1 MAC.
    When I stop arp on le1:
    ifconfig le1 -arp
    All PC's with Windows 7 and Windows 2008 do not have internet access.
    Also I try to put router:
    DVR1 DVR2 DVR3 DVR4 DVR5 DVR6 DVR7
    switch - router - switch - GW
    But ARP packets still f*cked up my GW, and Windows 7 drop internet connections.
    Why DVR's wana use 192.168.80.1 ?How I can block this packets?
    Thanks
    Does your DVR have a built-in router? If it does, you need to connect to it using a LAN cable and disable the router's DHCP server.
  3. mrowcp
    mrowcp Newbie
    I dont thing so.
    In DVR network setting have only "Network options" from where you can set static IP address ( at the moment they use static IP addresses - 192.168.80.130-137 ) and "DHCP use"
    When I put IP from another network - 192.168.90.131 , FreeBSD le1 continue to recеiving ARP packets from this DVR ( 90.131 ).
    Only when I power off it, packets stop ( or disconnect ).
    P.S. I'm not 100% sure , but I thing DVR's was Dynacolor DG216
  4. Adrian Wong
    Your Dynacolor DG216 DVR does have network routing capabilities. You need to disable its DHCP server.
  5. mrowcp
    mrowcp Newbie
    Thanks, tonight will try to find it.I suppose this options must be somewhere in DVR network config?
  6. Adrian Wong
    Hope it works! :beer:
