i bought the nvidia geforce 6600 graphic card 2 years ago,now it is not working and i donno the reason.when i showed to one of the electricians i know he said it has some chip level problem and he can't help it.so i searched for any nvidia graphic card service centers(though my warranty is over ..only 1 year).i have not found any.i am staying in bangalore and if any body can help,i would be grateful.. thank you....
I had a 6200 that just quit working. It is probably least expensive to just get another card as opposed to servicing it.
Repairing it might cost more, actually. I would advise to either get an identical or equivalent cheap GFX card from the auction stores, or 2nd hand stores. If not, the fastest way is to purchase a new graphics card. Again, it depends on your current system.
The GeForce 6600 is so old, you would be better off getting a much newer and faster "low-end" graphics card like the GeForce GT 240 or GeForce GT 340. Could even be a cheaper solution. Of course, if you need an AGP graphics card, then you are mostly stuck with the GeForce 6 series, unless you can find a GeForce 7800 GS (AGP version).
I don't use the card, but I do use Nvidia GeForce just that it’s a much later version. The card you listed above is included in the minimum requirements to play the game, as to how well it performs I have no idea. I'm guessing that it won’t be super great .. But it will be better than no card or just a chipset.
Even with a new motherboard (nowadays) with integrated graphics solution, it's miles ahead than the 6600. I may be wrong here, but the newer onboard nVidia and the AMD are quite decent for light work.
