P4P800 SE - startup problem
Discussion in 'General Hardware' started by alfor, Oct 26, 2005.
  1. alfor
    alfor Newbie
    Hi all.
    I have the following system :
    P4 3.2 Ghz - 2 GM RAM - 3 HDD (2 SATA + 1 EIDE) -
    500 W PSU - ASUS P4P800 SE as MOBO BIOS 1.009
    system WIN/XP PRO SP2 full updated.
    My problem is : when I turon on my pc often happen that the system does not load bios, I have to press the "HW RESET BUTTON" to start it.
    Any idea ?
    I have just changed my PSU from 300 W to 500 W.
    Some says it may depend from DRAM timing setting but I have no idea about this.
    Thanks
    Alberto
    All you did was change the power supply? Did you change the memory module(s) or change any BIOS settings? :think:
  3. alfor
    alfor Newbie
    I never chenged RAM modules because of cost ...
    I have ryed to change some setting but none was usefull
  4. Adrian Wong
    Hmm.. Why don't you tell us exactly what BIOS settings you changed? :think:
    Or better still, get screenshots of your BIOS screens and post them here. Then we can see what you set in your BIOS.
