Power Supply, It Doesn`t shut down automatically
Discussion in 'General Hardware' started by delahoz76, Jan 3, 2003.
  1. delahoz76
    delahoz76 Newbie
    :cry: I don´t know what to do, my CPU was working good, i bougth a new power supply unit and a week ago the cpu was attacked by some virus , i had to restore windows XP, it looks good now but it dosen´t shut down automatically, it shows me that message "now you cant turn off your computer safelly", the power supply is atx. A friend told that i must flash the BIOS, i know the version is old but it was working well before the virus. What do you recommend me?
    Please help me out? :roll:
    The BIOS Version is: AMI Bios Simple Setup Utility 1.21.06
    The MainBoard # 62-0415-001131-00101111-071595-M810LR-H-SiS7305
    And i try to attach a Sissoft Sandra Report but the server told me that it doesn´t support txt format so i paste it here. I think i´m desperate.
    ***** Start of Report *****
    <<< General >>>
    Program Name: \sandra.exe
    Program Version: 2001.5.8.11
    Registered User: Cesar De La Hoz Yañez
    Registered Company: Unknown
    Licence Status: Unregistered Shareware Evaluation Copy. FREE for
    personal use.
    Licence Extra: See Ordering Document for information on the
    Professional version.
    Report Done By: Cesar
    Host Name: CDY
    System ID: 1162
    Run ID: 28249
    Report Done On: Viernes, 03 de Enero de 2003
    Report Done At: 01:28:05 a.m.
    <<< System Summary >>>
    <<< Mainboard Information >>>
    Notice N224: SMBIOS/DMI information may be inaccurate.
    Tip T2511: Some memory slots are free so the memory can be easily
    upgraded.
    Warning W2541: FSB exceeds Chipset rated speed. Reduce FSB.
    <<< CPU & BIOS Information >>>
    Tip T201: System BIOS : System BIOS is old. Check for an update.
    Notice N224: System BIOS : SMBIOS/DMI information may be
    inaccurate.
    Tip T212: System BIOS : BIOS can be shadowed so check whether it
    is.
    Tip T211: System BIOS : BIOS is flash-able and socketed so it
    can be upgraded when needed.
    Notice N224: Processor 1 : SMBIOS/DMI information may be
    inaccurate.
    <<< PCI, AGP, CardBus Buses Information >>>
    Warning W1206: Silicon Integrated Systems (SiS) SiS5513 EIDE
    Controller (A,B step) : PCI latency too high. Device
    could hog the bus for too long.
    Tip T1202: Silicon Integrated Systems (SiS) SiS900 10/100
    Ethernet Adapter : Device does not support bus
    mastering.
    Warning W1203: Silicon Integrated Systems (SiS) Virtual PCI to PCI
    Bridge : VGA palette snooping seriously reduces video
    performance. Disable it if you don't need it.
    Tip T1202: Silicon Integrated Systems (SiS) SiS630 GUI
    Accelerator+3D : Device does not support bus
    mastering.
    Warning W1209: Silicon Integrated Systems (SiS) SiS630 GUI
    Accelerator+3D : Video card does not have an interrupt
    assigned.
    <<< Video System Information >>>
    Tip T316: Monitor predeterminado : Use a Energy Star (DPMS)
    power saving monitor.
    Warning W332: Monitor predeterminado : Use a Plug & Play/DDC
    compatible monitor and video adapter.
    Tip T327: SiS 300/305/630/540/730 : Reduce colour depth to
    improve video performance. 16-bit may be enough.
    Tip T319: SiS 300/305/630/540/730 : A refresh rate of at least
    75Hz is recommended. Increase it if possible.
    Tip T323: SiS 300/305/630/540/730 : Remove the desktop wallpaper
    to save memory and improve performance.
    Tip T314: SiS 300/305/630/540/730 : Video BIOS is too old. Check
    for an update.
    Tip T325: SiS 300/305/630/540/730 : Turn off window animation to
    reduce delays.
    Warning W313: SiS 300/305/630/540/730 : Font smoothing reduces video
    performance.
    <<< Windows Memory Information >>>
    <<< Drives Information >>>
    Warning: Removable Disk (A:) : Cannot obtain drive information;
    check that a disk is in the drive and it is correctly
    formatted.
    Warning: CD-ROM/DVD (D:) : Cannot obtain drive information;
    check that a CD-ROM/DVD is in the drive.
    <<< Ports Information >>>
    Warning: Puerto de comunicaciones (COM1) : Could not open port
    (5)
    <<< Keyboard Information >>>
    Tip T900: Uninstall Accessibility Features if you don't use them
    to conserve memory.
    <<< Mouse Information >>>
    Tip T800: Uninstall Accessibility Features if you don't use them
    to conserve memory.
    <<< Sound Card Information >>>
    <<< Printer and Fax Information >>>
    Tip T403: SnagIt 6 : Print to an EMF data type to improve
    printing speed.
    Tip T403: Fax : Print to an EMF data type to improve printing
    speed.
    <<< MCI Devices Information >>>
    <<< Windows Information >>>
    Tip T1300: Enter your company name or "Home" instead of
    "Unknown".
    <<< WinSock Information >>>
    Warning W503: Simple IP services (Echo, DayTime, etc) enabled, check
    this is required.
    Warning W504: Server IP services (FTP, HTTP, etc) enabled, check
    this is required.
    <<< Processes Information >>>
    Tip T1601: Adrian's Rojak Pot :: Post a new topic - Microsoft
    Internet Explorer : Program consumes a large amount of
    memory.
    <<< DirectX Information >>>
    Tip T2212: Controlador de pantalla primaria (display) : No
    hardware stretch support.
    Error: Línea #1 del módem (emulada) (Onda de salida 1) :
    Resources Already Allocated
    Error: Auricular #1 del módem (emulada) (Onda de salida 2) :
    Error: Conexión IPX para DirectPlay Ver 6.00 : Function
    Unavailable
    <<< Font Information >>>
    <<< OpenGL Video Information >>>
    Tip T312: OpenGL support may be required for 3D rendering
    applications or games. Install OpenGL.
    <<< Services Information >>>
    Tip T2130: Servidor : Service may be disabled on Personal/Pro OS
    version.
    Tip T2130: Mensajero : Service may be disabled on Personal/Pro OS
    version.
    Tip T2130: Coordinador de transacciones distribuidas de Microsoft
    : Service may be disabled on Personal/Pro OS version.
    Tip T2130: Proveedor de compatibilidad con seguridad LM de
    Windows NT : Service may be disabled on Personal/Pro
    OS version.
    Tip T2130: Administrador de conexión automática de acceso remoto :
    Tip T2130: Registro remoto : Service may be disabled on Personal/
    Pro OS version.
    Tip T2130: Programador de tareas : Service may be disabled on
    Tip T2130: Inicio de sesión secundario : Service may be disabled
    Tip T2130: Conexión de seguridad a Internet (ICF) / Conexión
    compartida a Internet (ICS) : Service may be disabled
    Tip T2130: Cliente de seguimiento de vinculos distribuidos :
    Tip T2130: Sistema de alimentación ininterrumpida : Service may
    Tip T2130: Horario de Windows : Service may be disabled on
    Tip T2130: Instrumental de administración de Windows : Service
    <<< CMOS Dump >>>
    <<< Hardware IRQ Settings >>>
    <<< I/O Settings >>>
    ***** End of Report *****
  2. zy
    zy zynine.com Staff Member
    bios settings .. always play with them .. :D ...
    i'm using award bios...
    goto Power Management Setup .. or some thing like that ....
    not sure bout AMI bios ...
    find something that has to do with System After AC Back
    change the value to Soft-Off
  3. zy
    you should list down your motherboard make/model next time .. :p
  4. zy
    is it an Amptron M810LR motherboard? :p
  5. Adrian Wong
    Hmm... Check your BIOS for the ACPI Function (not APIC). It should be enabled. If it's disabled, then you have probably installed Windows XP without ACPI support. In that case, your auto-shutdown won't work.
    If that's the case, you will have to enable ACPI in the BIOS (you should enable APIC too!) and reinstall Windows XP. Yes, you have to reinstall Windows XP to get back your ACPI support.
    However, there's no need to worry... Just boot up the installation CD, choose Install (instead of Recovery Console) and then the Windows XP installer will search for and find your Windows XP installation.
    Now, do NOT install a new copy of Windows XP. Just ask the installer to repair the installation. Let it run and then once it's done, you will be able to boot exactly as before, with your settings retained.
    Hope that helps you some! :)
  6. delahoz76
    delahoz76 Newbie
    the ACPI function is enable, so i´m going to install the windows XP again, when i´m done with it i wil reply to the forum, thank you very much. I`m grateful with all the people that responde my S.O.S message. :lol:
