Removing the fan from Intel stock cooler?
Discussion in 'Overclocking, Cooling & Modding' started by Zenphic, Dec 29, 2008.
  1. Zenphic
    Zenphic Newbie
  2. Lacus
    Lacus Newbie
    hmm, tried using a small painting brush and a small vacumm cleaner? thats what i used to do with my stock heatsink :D...
  3. zy
    zy zynine.com Staff Member
    brute force :mrgreen:
    its held on by tabs at the side right? maybe you can remove it that way. usually i would use compressed air to clean the heatsink
  4. Max_87
    Max_87 huehuehue
    I wash all my fans/heatsinks :mrgreen:
  5. lee_what2004
    lee_what2004 Just Started
    rinse it with water then let it dry :D
  6. kayFX
    kayFX Newbie
    quite hard to remove the fan without removing the heat sink.. the clip holding the fan is very hard.. my hand hurts..
  7. g0tanks
    g0tanks Newbie
    Compressed air works great, I used to use it for cleaning my PSU.
  8. DarKSeeD
    DarKSeeD BOG Translator
    You can't miss with compressed air. Works great and the whole cleaning operation takes only a few minutes without too much trouble!
  9. belikethat
    belikethat Just Started
    do not use vacummn cleaner :naughty:
    I read before it will spoil the pc by releasing static charges or something like that. which the hardware is very prone to. that why when u buy hardware , they are seal in a anti static plastic. correct me if i am wrong
  10. g0tanks
    g0tanks Newbie
    Really? I clean my PC with a vacuum cleaner all the time..
  11. Chai
    I use vacumm cleaner too sometimes, but on the casing usually.
  12. Zenphic
    Zenphic Newbie
    Awww... compressed air it is. Why couldn't Intel make something easier with screws instead of tabs? :doh:
  13. Trinity
    Vacumm cleaner then compressed air ftw.;)
  14. Lacus
    Lacus Newbie
    well, those mini vacuum cleaner :/
  15. Adrian Wong
    I don't think that is true, because a vacuum cleaner sucks air and dust from a surface. I don't see how it can deposit static on the cooler. To be safe though, you can remove the cooler before using the vacuum cleaner on it.
    Personally, I prefer to wash the heatsink and fan... and then dry them in the sun. :mrgreen:
  16. Zenphic
    Zenphic Newbie
    Really? Didn't know it was okay to wet a fan lol
  17. Chai
    Actually it's not recommended because it may damage the motor or bearing.
  18. Lacus
    Lacus Newbie
    well, a normal brush might work..to clean the dust o.o
  19. Chai
    Brush is OK, but not as effective as water. Maybe a damp cloth would be good.
  20. generalRage1982hrv
    well now i use somthing smarter ehehhehe
    1. i remove cooler
    2. than remove the fan
    3. and last thing is i gave cooler to my wife to wash it hahahahha
    much easyer solution
