pixel arrangement. the problem appears when i use cleartype font setting. either monitor will be blured. depending if which monitor is the primary monitor.
Oh, you are using two monitors at the same time? Then you really have a big problem, as I don't think you can set ClearType for each monitor...
Yes ClearType cant be set seperately for either monitors. So one monitor will be slightly blurred with ClearType enabled. Stupid NEC with the BGR strip.
Yeah, guessed as much. Even in those days, there weren't many BGR panels. I guess your only option would be to sell one of your monitors and pair it with a new monitor using the same type of panel. Getting rid of the BGR monitor would be the obvious choice...
Nah, I'll still use it. Just that ClearType is based on the other monitor. The other monitor isn't that good either. Dell E207WFP i think. It has unevenness lighting and picture quality isnt that good. But at least it is bigger than my current monitor. I use it for watching movies.
