Received yet another stupid hoax mail from a relative. Check it out : Needless to say, all that is UTTER NONSENSE. I replied to my relative :
So water content was 6%? That means she was a stiff. According to wikipedia , lowest figure is 45% when combined with obesity. 60% is normal and 75% is reached only by newborns (who lose it in the first 10 years). Also, I'm don't believe he managed to measure the bloodflow so quickly. The other 2 symptoms (salt and potasium) I don't know what are the correct numbers, but I'm sure if these numbers were true, the person would NOT be living......Although I can't say anything for zombies / undead. I don't think anyone has managed to get close enough to make such analysis. PS:no, I'm not a MMORPG player, but I did play some games and see some movies, but I prefer sci-fi myself.
LOL! You are so right. I didn't bother with most of the pseudoscience mumbo-jumbo because the first 2 paragraphs were bad enough. The rest was "indigestible"!
For the most part, the various grades of salt are all the same; chemically most are greater than 99% sodium chloride, but the structure varies widely. Simple table salt consists of small, compact cubic grains, while kosher salt has a much more irregular structure and a larger surface area. Popcorn salt is ground salt that dissolves very quickly. Rock salt is just that, large chunks of sodium chloride. These differences in structure can cause a significant change in the perceived flavor of the salt and its usefulness for particular recipes. The speed with which it dissolves is also very important, with finer salts such as pickling salt even dissolving readily in cold liquid. Table salt also contains anti-caking agents to allow it to flow freely, and sometimes contains very small amounts of iodine. Sea salt, which is made from evaporating seawater, also varies considerably. Because there are impurities in the water, each sea salt has a unique taste and is prized in different cuisines or for different applications. Sea salts often tend to cost considerably more than other kinds of salt; however, in areas with large seawater evaporation industries the "table salt" in local stores may actually be sea salt.
