Anyways, surprise! A Samsung inside a Seagate... So basically it's a regular drive with a USB 3.0 adapter, and approx. 9.5mm thick so will fit into most laptops (except the ones that require the slim 7mm drives).
One last thing I forgot to mention... the entire enclosure is a snap-fit type so as long as you're careful, you can reassemble the whole drive multiple times as long as you are careful. The aluminum top cover is the most delicate and can bend easily if you apply too much force when trying to pull it open.
Sure, though the formatting is kinda messy lol... The drive itself is still perfectly fine... just replaced by something better, so is now retrenched and jobless...
Actually I wanted atwl77 to test to ensure the permissions are set correctly. Sent from my Nexus 7 using Tapatalk
Okay, seems like there are now extra Edit and Delete buttons. As well as attachments... let's see if I can get all 5 pics in here: (edit: Looks like more than 2 attachments work, though I note that there is a significantly long pause after each upload reaches 100% before the thumbnail is updated and the next one begins. I think if you hit post before the thumbnail is generated, it skips the attachment.)
