Simple and cheap fan filter
Discussion in 'Overclocking, Cooling & Modding' started by Mac Daddy, Mar 19, 2008.
  1. Mac Daddy
    Well since installing this Coolermaster RC690 case I have noted the top and front dust filters for the fans and they work well. I have also noticed that the side panel that allows 2 additional case fans has no filter at all. In fact it allows a lot of dust into the case so I made this simple mod (pic1). This isn’t brain surgery its simple and cheap thought I would post it up.
    Tools:
    Phillips Screwdriver
    Glue gun
    Exacto Knife
    Supplies:
    Screen or mesh (I used black screen door screen)
    Remove the side panel and side case fans (pic2). Clean the side panel and case fans.
    On the backside of the side panel lay out the screen or mesh and cut to size with the exacto knife. Making sure the screen or mesh is tight and taunt put it place and seal it in with the glue gun (pic3).
    Before remounting the case fan(s) pick out the mounting holes needed and cut them in an X pattern this will keep the screen or mesh taunt and from binding on the screws for the fan. Remount the fans I chose only to remount 1 of them. The top one I noted was too close to my CPU cooler (pic4)and I needed that Coolermaster fan for a review anyway lol.
    That’s all (pic5) :D
  2. Zenphic
    Zenphic Newbie
    How effective is the mesh at catching dust tho? I say paper towel ftw :D
  3. Dashken
    Dashken Administrator!
    Or put a few layers of the mesh. :think:
  4. Mac Daddy
    Actually was thinking of adding something like speaker grille clothe behind the mesh but not really sure how quickly cloth will deteriorate. I left the top panel for about 2 weeks to see how much dust the mesh that came with the case caught and seems just that works well. So will see :mrgreen:
      File size:
      595.6 KB
      16
  5. Papercut
    Papercut Newbie
    I heard that pantyhose is another good, cheap material to use.
  6. Adrian Wong
    Yeah, nylon pantyhose should work great. :thumb:
    I think paper towels are too resistant to airflow to work well. :think:
  7. Mac Daddy
    Is the pantyhose edible .... oops sorry wrong forum :mrgreen:
    Cheers guys on the feedback but the mesh actually is working quite well will keep ya posted :thumb:
  8. PowerSlide
    PowerSlide Just Started
    im gonna use this
    its from baking equipment where i usually see my mom shake flour into bowl :haha:
    the gap are very small thus its very restrictive id say but im more care to keep the dust out for my top panel fan
  9. Mac Daddy
    Keep us posted Bro :D
  10. Zenphic
    Zenphic Newbie
    Looks like it should work. Hopefully the threads don't start coming off too quickly :)
  11. I have found that a dryer fabric sotner sheet cut to size works very well . When dirty just toss and replace.
  12. zy
    zy zynine.com Staff Member
    your PC is gonna have a real nice smell :thumb:
  13. Zenphic
    Zenphic Newbie
    lulz
    I should try that :thumb:
  14. LOL ...yeah I suppose it would but used ones work just fine :p Also the foam ones are the best as they don't inhibit air-flow as much and stay in place better.
  15. Mac Daddy
    Interesting and thanks for the feedback I guess if it gets bounced around in a dryer heat and the elements won't deteriorate it much :D
  16. PowerSlide
    will keep you guys posted once i get my stacker finish modded :doh:
    another i read is 3M aircond filter thing..but very expensive
  17. Mac Daddy
    Cool keep us posted :D
  18. bslee
    bslee Newbie
    Hey, there's alternative air con or kitchen hood filter sheets that may be put to some use. I'm thinking about it for my next upgrade PC, although I'm not going to change my casing which is currently CM Wavemaster, bought few years ago to suffice at least 3-4 upgrade paths.
  19. generalRage1982hrv
    bro why dident you try with other stuff
  20. Mac Daddy
    The screen is working quite well here :thumb:
