The Somewhat Complete AMD 64 Overclocking Guide. This guide offers a few more definitions, and a more detailed "How To" A Little bit more tedious approach to overclocking, but my results with this method have been very good so far. Since we are constantly inundated with requests on how to Overclock ones A64 System, I Figured I'd take a stab at a guide. I've been Overclocking Computers for about 4 years, so when I built an A64 rig about 8 Months ago, I figured it would be the same as always.... (I'm now on my 3rd A64 Rig.....) I was wrong.... Critical Overclocking Programs you’ll need: CPU-Z: General System Monitor and report. ClockGen: Make sure your get the version for your Chipset. This program allows you to Overclock from within windows. Not always as reliable as physically changing BIOS settings, but gives you an easy way to play with your settings without dozens of reboots. Memtest86: You'll need to run this from a Floppy or Bootable CD. This basic program is still considered the best for testing your RAM SuperPi: Intensive mathematical program that stresses CPU/Memory pretty extensively. I like this program because it gives you a good indication of your overclock in under a minute’s time. Critical Components for a Quality Overclock POWER SUPPLY Power Supplies are missed so often when it comes to figure out why your system isnt overclockig the way it should. DONT SKIMP HERE! Get yourself a quality Power Supply and you'll never regret it. The Power Supply that comes with most cases is garbage. If budget is tight, Go with an ANTEC or ENERMAX case. These usually come with a pretty decent supply. RAM A64s LOVE TCCD based ram. There are several more factors that go into a quality and Stable A64 Overclock, that there are with Older XP and Intel based systems. A few of the factors we need to take into Consideration are CPU Multiplier CPU Voltage HTT Frequency HTT Multiplier Memory Divider (There is ALWAYS a memory Divider with a A64 system) Memory Voltage Ram Timings Chipset Voltage AGP/PCI Lock COOL N' QUIET Finding the right combination of these settings is the only way to get the most out of your A64 CPU Multiplier All A64s are at least Half Locked. This means that you can set the CPU Multiplier Lower than stock, but not Higher. This is a Good thing. Very rarely with A64's would you ever need to raise the CPU Multiplier over the Factory setting. The exception to this are the FX chips, they are fully unlocked. CPU Voltage Most A64s have a default voltage of 1.4v to 1.6V. A64s are extremely efficient and usually can only take about 1.7v before they just start producing excess heat. I've run my Mobile up to 1.9v but found it did NOT help my overclocks and simply caused the CPU to produce enormous amounts of heat. These are NOT XP-M chips! While I doubt that running voltages between 1.75 and 1.9 will cause any permanent damage, it certainly has not shown to be beneficial in any tests I’ve seen so far. HTT Frequency A64s don’t use a traditional Front system Bus. Instead they use a HyperTransport. I can only assume its abbreviated "HTT" to differentiate between Intel’s "HT" and Hyper-Threading Technology. They are VERY different. The HyperTransport is what controls the base frequency for communications and CPU speed in our A64 System. The CPU Speed is controlled by the HTT Multiplied by the CPU Multiplier, The HyperTransport or Memory controller is controlled by the HTT Multiplied by the HTT Multiplier, and Memory speed is controlled by the HTT Frequency, Multiplied by the CPU Multiplier and then DIVIDED by the Memory Divider. That’s a bit confusing for most folks. And it took me a while to grasp the concept as well. HTT Multiplier Most AMD Motherboards are designed to handle an 800-1000 MHz Hyper Transport bus. Factory Default on Most CPUs is 800 MHz (A 4X Multiplier) this is a Critical part of Overclocking an A64 to the Max. Pushing the HyperTransport past 1Ghz can cause all kinds of system instability that is commonly misconceived as "I maxed out my CPU" or "My Ram is holding me back" Memory Divider This is one of the most Confusing aspects of A64 Overclocking. There is ALWAYS a memory divider. Setting the Memory to 1:1 means that the HTT bus is multiplied by the CPU Multiplier and then Divided by the CPU Multiplier to set the Memory speed. This means that it is OK to run your Memory at its peak efficiency and still go higher with your HTT bus if your CPU can take it. Take note that I said its "OK" not advisable. There are still sufficient tests out there showing that running a 1:1 ratio will garner you the best overall performance. I plan on adding a few test results in the next week or so showing the difference in performance using a higher memory divider than CPU Multiplier. Since A64's use an On chip memory controller, the Ratio must be calculated a bit differently than old. 5:6 is NOT always 5:6. See that chart at the end of this post for a prety darn close representation of what each divieder is doing. Thanks to Oskar from DFI for the chart. Memory Voltage Most motherboards offer a degree of memory voltage options. The memory of choice lately has been Samsung TCCD Based modules with Brainpower PCB's. These Modules run at 2.6v stock voltage, and can usually do no better with voltage up to about 2.8-2.9 volts. There have been a few reports of better settings with voltages over 3v, but these seem to be pretty rare situations. Most other memory can benefit from having additional voltage run through it. The king of this is the elusive Winbond BH-5 based memory modules. If you’re lucky enough to have some of these, you may want to invest in an OCZ Memory Voltage Booster if your motherboard is compatible as these can run some very impressive timings with a lot of voltage.... Speaking of Timings... Memory Timings There are 5 Numbers in our Timings that we need to worry about a lot. Personally, I would like to learn more about the other numbers, but as of this writing, I'm pretty much in the dark there. What we do need to worry about are CAS Latency, RAS to CAS Delay, RAS Precharge, and Cycle Time(Tras), and CPC (command Per Clock) Ideally, we want these timings to be 2-2-2-5 1T. Most TCCD based module does this at 200 MHz (DDR400) and can usually go up to 215-220 with a Bump in Voltage to 2.7, and then we need to loosen them to go higher. 2.5-3-3-7 is still considered reasonable memory timings for an A64 system, and some people even go out to 3-4-4-8, but I would personally advise against using timings that high with an A64 System. We ALWAYS want to use CPC (1T) this means the Command per Clock interface is enabled. 2T performs extremely poorly on A64 systems. But since our memory controller is on the CPU, the Double Sided memory problem that plagues XP Motherboards is not evident. Give AMD a WOOT for that one..... Chipset Voltage Usually just a small bump in Chipset Voltage will stabilize a flakey HTT bus. 1.6 is Stock on most motherboards, but 1.7 to 1.8 is acceptable as long as you have decent cooling on your Northbridge chip. Many A64 Motherboards use Passive heatsinks on these chips so before you install your dandy new A64 system, take off your NB Cooler and replace the Factory thermal past with some AS-5. This is usually enough to keep the MB Cool enough to run the extra voltage. Placing Ram Sinks on your Southbridge and any other heat producing chip is never a bad idea either. AGP/PCI Lock The AGP and PCI Bus' are tied together on all motherboards that I know of. They are also derived from the FSB (Or HTT in the case of AMD) frequency by a divider. NVidia NForce chipsets have whats called a PCI/AGP Lock. This keeps your PCI and AGP Bus at a constant speed no matter what your HTT bus is. This is CRITICAL. If y our PCI bus is too fast, you WILL corrupt hard drive data. If your AGP Bus is too fast, you WILL have Video problems. Via Chipsts have been known to have Faulty PCI locks. This appears to be corrected in the KT800 Pro Chipset, but KT800 and below SHOW a PCI Lock in most bios's but it doesnt do much... This is a Primary reason why overclockers stay away from these boards. On your Nforce or Via KT800Pro board you want this setting at 33Mhz if its listed as a PCI lock, or 66-67Mhz if its listed as a AGP Lock. Pushing this offers absolutely no benefit as the bandwidth provided by these frequencies is more than todays Hard Drives or AGP Video cards can use. COOL N' QUIET Disable this. This is a feature that will automatically UNDERCLOCK your system if it feels it doesnt need to run so fast.... WHo are "They" to tell us how fast out CPU should run? Now.... What do we do with all this Information??? Start Overclocking of course..... First Thing First... Let’s see how fast our Processor can go. Set your Memory Divider at its lowest setting. (Usually 100 or 133) This will give us a LOT of headroom to push out CPU. Next, Drop your HTT Multiplier to 3x and your CPU Multiplier 1 Notch (If you have a 2 GHz CPU, drop your Multiplier down to 9x) with these settings most AMD systems will boot and run at a 230HTT so go there first. Once you get into Windows, Run a 1Million run of SuperPi, and then a Prim95 Max heat test for about 10 Minutes. If it passes both of those, its time to go further. Go 5 MHz at a Time and Repeat. During this we'll want to raise the VCore of our Processor to maintain stability. Once SuperPi and/or Prime95 fail, raise your VCore .05 Volts and Try again. Once you get to 1.7V and still Errors, Drop down 3 MHz and Try again. Finally, if that fails, drop back down the 2 MHz we had left and call it a day. This is a Slow Time Consuming process, so have a few Mountain Dews and some chocolate bars handy. Once your push your HTT bus back over 800 MHz (267HTT Bus) raise your Chipset Voltage up to 1.7 with any luck, you'll hit 260-280HTT Depending on your CPU. Write this info down and then we move on to testing out Memory. CPU TEMPS ADDDENDUM As stated above, A64s are VERY efficient, there have been reports of outrageous overclocks using the stock AMD Heatsink. But I would still recommend a high quality Swiftech or Thermalright Unit. (Dee DavidHammocks HSF Guide for specifics) Anyway, Standard Desktop chips should be kept under 55c in ALL cases. It should NOT be hard to keep then under 45-48c with good quality cooling. Running higher than that is a good indication that you have misapplied your HSF and/or AS-5 Remount. Mobile chips are rated a bit higher, but there is still no reason to ever see temps higher than 55c. The lack of an IHS provides better contact with the Heatsink and it’s very possible to keep temps at 45 and lower with quality cooling. Even with high overclocks. Torture your Memory Next Memory is usually the Culprit in holding back overclocks. Finding out the capabilities of what our memory can do is critical. Drop your HTT bus back down to 200, and reset your Memory Divider to 1:1 (Usually "AUTO") Leave your CPU Multiplier at 9x (For a 10 Stock Multi) and let start out at 215 at Stock Timings, Bump VDimm up to 2.7v(Or +.1Volt) The 2 tests you want to do here are SuperPi 1 Million and Memtest86 You'll need a Floppy disc or Bootable CD to run Memtest86 (Or if you have a DFI UT, there is a Modded BIOS available with Memtest built in) Run 5 Passes of Memtest86, then boot into Windows and Run SuperPi. You won’t be fast, but SuperPi 1Million runs a LOT of numbers through your Memory. If all goes well, go up 5 MHz at a time until one starts to error. That’s where we need to start loosening the timings. Go up .5 on Cast Latency, 1 on RAS to CAS Delay, 1 on RAS Precharge, and 2 on Cycle Time (Tras) and Repeat these tests. Depending on your memory, you may want to loosen them more, but I would suggest keeping them under 3-4-4-11 if at all possible. If you’re using Memory Other than TCCD based, don’t be afraid to bump your Memory voltage more. Most modules will take 2.9-3.0 Volts just fine and BH-5 has been known to go as high as 3.3 to 3.5v! Once you've found your Memory’s max speed, this is where we need to do some math. Most likely there’s a sizeable gap between what your CPU can do and what your Memory can do. That’s OK.... That’s why we went down a Notch or 2 on our CPU Multiplier testing. Lets say your CPU went to 260 Stable with a 1x drop in your Multi, Not bad.... a 340Mhz O/C on a stock 2Ghz chip... but your memory only went to 230 before you had to go to slow in your Timings. That’s OK.... Drop the HTT down to 230 and bring your Multiplier back to stock speed (10 xs in our example) you should have a Rock Solid 300Mhz overclock on your hands. If the Gap between your Memory and CPU is so high, you can’t get to your Max CPU Speed with your Stock Multiplier, we may need to run a higher Divider on our Memory. If we're talking 30+ MHz base difference.... You should probably drop your Memory Divider down to 166 and use your Max CPU Speed we figured out. Less than 30 MHz and you'll probably get better performance running 1:1 at your Memory speed. I say this because we'll be losing memory speed at our best settings at that point. Only use a Higher Divider IF your CPU speed will bring your Memory speed to within 2-5 MHz of your MAX Memory Speed. 240HTT X10 = 2400Mhz, Divided By 11 (166) brings out Memory down to 218Mhz If out MAX speed as 236, we're Giving away Memory bandwidth for no reason. However, if your Max CPU bus is 260, then we get this 260x10 = 2600 /11 = 236. See how that works? Now out Memory is maxed AND out CPU is maxed.... This guide was Written Completely on the Fly. Any Similarities to other MD64 Overclocking guides is purely coincidental, I hope there’s enough new and/or important information here for newbie’s and expert alike..... Guide thanks to Impaqt.
Dude, Awsome freakin guide, should be a sticky. Good thing I gave yeah the idea to start makin guides. ha!
Er,,...I've seen this guide at ExtremeForum I think. Did you right this? Did you get the permission from the author to post this? If not, you are just simply plagiarizing, that's wrong...
if ur ram and mobo are compatible i mean they have some issues.as my pair DFI NF4 Ultra-D and Kingston Hynix chip. my mobo refuse to works with this hynix at some frequency. but do at some. So, u can't test ur ram that way also with CPU test using divider also cause instability with my pair.
I don't think you should rip the article just like that. You should give credit to the writer. "- Please give credits to the original author if you are copying from them and post it here! If you don't, you are merely plagiarising other's work." You can read our rules here. http://forums.rojakpot.com/showthread.php?t=2059
uhh i asked the author... and i already have credit at the bottom in red. Unless you think it should be worded differently.
nice guide, maybe I will follow it and try a little bit of oc on my system. I am always a bit hard to try.
so..gonna OC my new rig. this guide still reliable? 1st time OC'er. any thing i should be aware of before i start? specs :- AMD 64 3500+ (2.2Ghz) ASUS A8N-SLI MOBO 512MB DDR400 CORSAIR VS CL2.5 x2 128MB LEADTEK WINFAST 6600GT SLI graphics card Thermalright XP-90C CPU Cooler Delta Focus Flow 92mm fan Acbel 500W PSU
It's a pretty good guide but there's one part I don't agree with... "Drop...your CPU Multiplier 1 Notch (If you have a 2 GHz CPU, drop your Multiplier down to 9x) " Ok I don't have an AMD64 but I really don't see the point of doing this. The CPU multiplier should be adjusted when you're trying to find the optimal CPU/RAM frequencies at the end, but not at the start when you're trying to find your CPU's maximum overclock. Or am I missing something?
Under the Monitor Hardware settings in my BIOS, i notice these :- CPU TEMPERATURE 51'C M/B TEMPERATURE 40'C now i'm assuming M/B refers to the motherboard temperature. when you mentioned the 55c in your post, which are you refering to? also, i can't find the PCI/AGP lock setting in my BIOS. where is it hiding?
It refers to CPU temperature. Why not install Asus PC Probe so you have some temperature monitoring within Windows? Check your motherboard manual for the PCI/AGP lock.
nice..the asus pc probe works great! i've looked through the manual but still can't find anything on PCI/AGP lock. hmm..... also, i'm playing around with AI N.O.S. to see how's the performance difference...
Well thing is, each mobo has it's own tricks. So you might want to look for a guide according your own mobo. some things I want to point out: The guide does not tell you whether it's 754 or 939 based, though I assume it's for 754. the AGP/PCI lock: some boards do that automatically, some have the option hidden it all depends on your mobo. But the guide does not tell you that, it just assumes it's there, now people start to wonder where the hell the option is. Dropping the divider to 100 is pointless, when you start looking for your max OC, just keep it where it's at. like for a 939 3200+ it would be multiplier 10. Start raise your FSB and off you go. There's nothing to be afraid of unless you raise your vcore. Here again there's a difference in stock core voltage for the 754 and 939. In the end dividers is only recommended if your ram is crappy or when you want to squeeze more Mhz out of it. Decent ram = 1:1, if I remember correctly Chai loves 1:1 But as far as I know running with divider isn't as crucial as with older chips like Athlon XP. Cas Latency: normally the lower the better, but with A64 939 you'd rather want more bandwidth over low latency. 2.5-3-3-7 and 3-4-4-8? In fact, you won't feel any difference in daily usage. It will only save you a second or 2 in pifastscore. I would't touch the chipset voltage, this is dangerous. additional cooling won't help much in achieving a higher OC either. I also suggest Speedfan, it reads all the temperatures +voltages and you can even set fanspeeds with it. the guide is just a general guide to OCing, not A64 specific. though I can't blame the author, since probably when he wrote it the 939 wasn't out yet..
I actually know a couple of good guides... This one is a great general guide when you're just starting to learn about overclocking: http://www.rage3d.com/board/showthread.php?t=33772445 And this one is written by a local Aussie RAM and overclocking guru: http://i4memory.com/showthread.php?t=327
Great guides and input! Thanks all! now last thing before i try it out...what are the major things i MUST becareful not to do when OC'ing...well..besides upping the vcore too high?
Watch your temperatures, I guess. But the XP-90C is just about the best heatsink on the market so as long as you've mounted it properly, you shouldn't have to worry about temperatures.
