This is the DrivePro Body 10, a what the name suggests, it’s like the Transcend DrivePro series that does recording for record purpose, no pun intended. Unlike the DrivePro that’s for vehicles, the DrivePro Body is for one to mount on the body. The DrivePro Body 10 is light-weight, has shock and water resistant and is able to record even under low-light conditions – this is the perfect solution for people like security guards. Out of the box you’ll see not only the DrivePro Body 10 unit but also a 32GB Transcend MicroSD Card that’s bundled with the kit, and that’s ample space to cater for the DrivePro Body 10 that’s capable of Full HD Video recording. Underneath the main stars of the package are the power connectors, the manual and other printed documents. The DrivePro Body 10 is not a large unit, as you can see it’s pocket sized. Both the weight and the form factor makes it easy to mount on any officer or persons on duty. Despite the small frame, what’s interesting to note is that the DrivePro Body 10 has 160° wide angle camera with F2.8 aperture lens as well as Infrared LED for the use at night time without concerns. By having a 160° wide angle view, this means the DrivePro Body 10 is able to record wide angle of view, useful for information on the surroundings or in cases where one deals with more than 1 individual. With an f/2.8 lens the DrivePro Body 10 is able to capture more light into the sensor, useful when the condition is less optimal for recording. Should the condition be absent of light, the DrivePro Body 10’s infrared LED would kick in, recording the scene as required. There is no special mounting is required for the the DrivePro Body 10, the unit comes with a sturdy clip that provides a secure mount. When it comes to being at the line of duty, things can get messy and one may not only need to run but also might be involved in close quarters action. The clip is such that it ensures that the recording unit doesn’t dislodge easily when in action. What’s even more assuring is that the DrivePro Body 10 is shock resistant and water resistant, such durability is much welcome when it comes to working in harsh environments, or in cases where accident happens where the device becomes dislodged. By being durable it also means the DrivePro Body 10 is protected and less prone to damage that results in not only the loss of data but also the loss of a unit, after all having to arrange for a replacement unit costs time and money. Product Details at : DrivePro™ Body 10-Body Cameras Capture clear images anytime, anywhere 1080P Full HD, 30fps, body camera, built-in battery, F/2.8 Aperture, 160° wide angle lens, IPX4 water resistant, shock resistant, infrared LED, IR, night vision, snapshot, 360° rotatable clip, DrivePro Body Toolbox, DrivePro Body 10, DPB10
