USB Functions
Discussion in 'BIOS Optimization Guide (BOG)' started by LFDD@TechARP, May 30, 2010.
  1. LFDD@TechARP
    LFDD@TechARP Newbie
    Hi,
    In order to optimize the BIOS of the ASUS P7P55D-E PRO motherboard, I'm looking for information about the USB functions.
    Here is what the manual says :
    (I cannot post any images, urls, ...)
    USB Functions [Enabled]
    [Enabled] Enables the USB Host Controllers.
    [Disabled] Disables the controllers.
    (the two following items appear only when you set USB Functions to [Enabled])
    Legacy USB Support [Auto]
    [Auto] Allows the system to detect the presence of USB devices at startup. If detected, the USB controller legacy mode is enabled. If not, the legacy USB support is disabled.
    [Enabled] Enables the support for USB devices on legacy OS.
    [Disabled] Disables the function.
    BIOS EHCI Hand-off [Enabled]
    [Enabled] Enables the support for OS without an EHCI hand-off feature.
    There is no literature on the net about this subject.
    Firstly, Windows 7 fully support USB 2.0 and EHCI is for USB 2.0 support so is it necessary to enable that function ?
    I read that it could be responsible for a long-time boot if it was enable with a few models of motherboard.
    I read something about it on this forum but it was not very detailed.
    Secondly, giving that I have almost never a USB device connected at startup, can I safely disable Legacy USB Support ?
    It is said in the following article that it is useful when OS do not natively support USB. So when Windows 7, is it always useful ?
    "This BIOS feature determines if the BIOS should provide legacy support for USB devices like the keyboard, mouse and floppy drive. This is a useful feature when using such USB devices with operating systems that do not natively support USB (e.g. Microsoft DOS or Windows NT).
    When enabled, the BIOS will enable legacy support for USB keyboards, mice and floppy drives. You will be able to use these USB devices even with operating systems that do not support USB.
    When disabled, the BIOS will not enable legacy support for USB keyboards, mice and floppy drives. You will not be able to use these USB devices with operating systems that do not support USB.
    However, the BIOS can only provide relatively rudimentary support. For full functionality, you will need to use an operating system that supports USB and install any necessary driver. Alternatively, you can also enable the USB Port 64/60 Emulation BIOS feature."
    Thanks a lot for your help !
    You can turn both Legacy USB Support and BIOS EHCI Hand-off support off if you boot straight into Windows 7.
  3. LFDD@TechARP
    LFDD@TechARP Newbie
    If I can turn off both settings, can i also turn off the USB Functions setting ?
    Thanks a lot for your answer.
  4. zy
    zy zynine.com Staff Member
    You can turn it off if you don't plan to use any USB devices in windows.
  5. Adrian Wong
    Why would you want to do that??? You can do it if you don't want to use the motherboard's built-in USB ports. But unless you are really hard-up for a free IRQ (and you turned off APIC for some reason), it's really quite pointless...
  6. LFDD@TechARP
    LFDD@TechARP Newbie
    You're toadly right, but I wasn't shure so prefer to ask. Thanks mate !
  7. Adrian Wong
    Oh, no problem. :beer:
