Useful Links For Palm Users!
Discussion in 'Notebooks & Mobile Devices' started by Adrian Wong, Aug 22, 2004.
  1. Adrian Wong
    Useful Software For Palm Users!
    NetFront 3.1 for Palm
    - The BEST Internet Browser for Palm!
    - http://www.leggnet.com/clie/ux/NetFront3.prc
    Skins for Palm PCs
    - Here's the site for skinning software and various Palm skins!
    - http://www.festus440.happypalm.com/
    Crash Pro
    - Software to automatically reset your Palm whenever it crashes.
    - http://www.79media.com/crashpro/
    Dimmer
    - Software to automatically dim or turn off the backlight after a period of time.
    - http://www.79media.com/dimmer/
    Lightspeed
    - Software to under- or overclock your Palm CPU for each INDIVIDUAL program!
    - http://www.clievideo.com/default.asp?item=3&intProductID=3
    Palm Webcam
    - Software to turn your Palm into a webcam! You can stream the video using USB or WiFi!
    - http://www.clievideo.com/default.asp?item=3&intProductID=4
    If you have any tools or links to add, please add below! I will then add them to the list.
    Thanks! :thumb:
  2. jzelano
    jzelano Newbie
    Netfront3.prc from leggnet NOT 3.1
    Adrian:
    I finally figured out the problem with the read only file from leggnet.com. You copy it to the memory stick using MSimport. Then Mcfile will copy it to RAM. You can either run in RAM or copy to Flash memory to execute it.
    The only problem is that this version is still v 3.0 not 3.1 and there is no difference.
    Does anyone in the forum know where I can find a Netfront 3.1 download for Palm OS. It should be compatible with the Sony NZ-90.
    Please help if you can.
    Regards,
    John Zelano
