ViewSonic VG2228wm
Discussion in 'Graphics Cards & Displays' started by automaton, Nov 4, 2011.
  1. automaton
    automaton Newbie
    any suggestions sub 200 dollar monitors
  2. Chai
    I would recommend Dell U2312HM if you can stretch your budget a little more.
  3. Adrian Wong
    A cheaper TN-based panel would be the Dell Professional P2211H LED monitor. I prefer it to the non-professional version is because it has a fully-adjustable stand. Over here, you can get it for RM 479 (US$ 160).
  4. Chai
    Looks like Dell monitors are a lot more expensive in US.
  5. automaton
    automaton Newbie
    Dell UltraSharp U2212HM 21.5-inch Monitor with LED
    I am going with this model base price 219
    thanks for lead looks juicy hard to find reviews:faint:
  6. Chai
    Excellent choice. That has the eIPS panel. You won't regret it. :thumb:
  7. automaton
    automaton Newbie
    resolution readability
    currently I have a crt viewsonic pro p95f @ 1600x1200
    I have the dpi up and on the web have a zoom plug in in firefox
    This is my first led
    will the resolution size make the text miniscule?
  8. lee_what2004
    lee_what2004 Just Started
    The bigger the resolution, the smaller the text, with the same dpi settings.
  9. Chai
    With CRT, I would advise you to reduce the resolution instead of bumping up the DPI settings.
