Do both the Asus 680i boards(Striker & P5N32-E SLI) have the same problem ? I think this is just a Buggy Bios problem & can be corrected by applying a new Firmwire which Nvidia is yet to release.
yup, using FF... i do encounter some screwed up blogs using FF too, but my IE7 displays it perfectly.. =(
no way i will pay premium juz to get the latest mobo either... moreover, there seem to be issue with the sata controller of 680i or sth liddat... read abt it in a few forums..
The problem with Firefox is that, I can't save a webpage in MHT form,which is way better than normal .html coz in MHT we can get a webpage saved in just a .mht file.This MHT support should be included in Firefox like the I.E. What do u say ?
The problems has been resolved with the Sata controllers in 680i.Nvidia, EVGA Fix Problems with Latest High-End Core-Logic.EVGA and Nvidia Releases Fix for Serial ATA Issues on nForce 680i. Though, a few users claimed that their Serial ATA problems remained even after flashing the new BIOS.Maybe they'll have to wait 4 another Bios upgrade.But this kinda thing can't be expected from Nvidia whatsoever. http://www.xbitlabs.com/news/chipsets/display/20061217121610.html
yup... u shld suggest that to FF.. i cant do anything abt it.. but i wouldnt wanna save a screwed up page with FF either...
but den there's another rumour of "sata data loss" aiya, dun care la.. why pay so much for a buggy new product? wait for em solve most of the problems, den i shall start hunting for the 2nd hand ones @ a much much much lower cost, hee~
So to sum it all up. What is the best, most stable non SLI mobo, cost not a concern? And what is the best, most stable SLI mobo under $275 USD? With c2d e6600. (I WAN IT!!!) I am not much of a gamer, But I want a very fast box for everything else. The only reason I would like a SLI board is because I might end up with, or need two v-cards someday.
I think Abit AW9D is quite good if you are not overclocking, it's quite buggy when overclocking. Quite cheap for a 975X chipset board. Or else, consider Asus P5B.
