x264 Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Sep 9, 2007.
  1. graysky
    graysky ARP Reviewer
    Thanks for the result dude... I see you ran the yet-to-be-released HD version of the benchmark. Where'd you get your hands on a C1 stepping q9450? Another important question is how high does it clock? I'm itching to get one along with a new X38 based board but my fear is that I'd have to pump the FSB too high.
  2. kpfong
    kpfong Newbie
    CPU: Athlon X2 BE-2300 9.5X200
    Chipset: ID9600 (780G)
    Mem: 5-5-5-18@380
    OS: Vista Home
    ---------- RUN1PASS1.LOG
    encoded 1749 frames, 48.14 fps, 1850.89 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1749 frames, 49.46 fps, 1850.89 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1749 frames, 49.33 fps, 1850.89 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1749 frames, 50.64 fps, 1850.89 kb/s
    ---------- RUN5PASS1.LOG
    encoded 1749 frames, 50.32 fps, 1850.89 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1749 frames, 11.93 fps, 1826.37 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1749 frames, 11.85 fps, 1826.37 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1749 frames, 12.08 fps, 1826.37 kb/s
    ---------- RUN4PASS2.LOG
    encoded 1749 frames, 12.15 fps, 1826.37 kb/s
    ---------- RUN5PASS2.LOG
    encoded 1749 frames, 12.13 fps, 1826.37 kb/s
  3. graysky
    Thanks for the results kpfong. Adding to the tables shortly.
  4. cEvin Ki
    cEvin Ki Newbie
    encoded 1749 frames, 161.76 fps, 1850.94 kb/s
    encoded 1749 frames, 162.47 fps, 1850.94 kb/s
    encoded 1749 frames, 161.99 fps, 1850.94 kb/s
    encoded 1749 frames, 162.46 fps, 1850.94 kb/s
    encoded 1749 frames, 42.77 fps, 1829.43 kb/s
    encoded 1749 frames, 42.85 fps, 1829.29 kb/s
    encoded 1749 frames, 42.86 fps, 1829.12 kb/s
    encoded 1749 frames, 42.79 fps, 1829.32 kb/s
    encoded 1749 frames, 42.64 fps, 1829.32 kb/s
    C2 Q6600 Kentsfield
    333x9
    DDR2 1:1 @667 3-3-3-8
    X38
    XP32 Pro SP2
  5. graysky
    Thanks dude... C2 stepping???
  6. silentbob343
    silentbob343 Newbie
    my results
    WinXP Pro w/SP2:
  7. cEvin Ki
    cEvin Ki Newbie
    @graysky
    hehe, no. sorry for the confusion. that was "core 2", but i suppose that wasn't even necessary to include, as there is only one q6600! i'm a doof at times.....
    no, it's a G0 stepping. ;)
  8. Dashken
    Dashken Administrator!
    Hihi... I wish I can overclock it but unfortunately it's not mine. :boohoo:
    So, overclocking it would be impossible with the BIOS available. :faint:
  9. kpfong
    kpfong Newbie
    CPU: Athlon X2 BE2300@200MHz X 9.5
    RAM: 5-5-5-18@380MHz
    Chipset: 690G
    OS: vista home 32
    encoded 1749 frames, 42.38 fps, 1850.89 kb/s
    encoded 1749 frames, 43.64 fps, 1850.89 kb/s
    encoded 1749 frames, 45.46 fps, 1850.89 kb/s
    encoded 1749 frames, 47.45 fps, 1850.89 kb/s
    encoded 1749 frames, 47.25 fps, 1850.89 kb/s
    encoded 1749 frames, 10.68 fps, 1826.37 kb/s
    encoded 1749 frames, 11.08 fps, 1826.21 kb/s
    encoded 1749 frames, 11.43 fps, 1826.37 kb/s
    encoded 1749 frames, 11.34 fps, 1826.37 kb/s
    encoded 1749 frames, 11.21 fps, 1826.37 kb/s
    Same CPU / RAM / OS with 780G setup.... seems 780 gives better result.....
  10. graysky
    Cool man, I'll update the tables shortly.
  11. vandenk
    vandenk Newbie
    CPU : AMD Athlon XP Barton @2671 Mhz (13x205.5)
    MB chipset: Nvidia nForce2 Ultra 400
    Frequency (Timings) : 205 Mhz (2.5/3/3/7)
    OS : WinXP Pro Sp2 x86
    encoded 1749 frames, 30.11 fps, 1854.10 kb/s
    encoded 1749 frames, 30.16 fps, 1854.10 kb/s
    encoded 1749 frames, 30.21 fps, 1854.10 kb/s
    encoded 1749 frames, 30.19 fps, 1854.10 kb/s
    encoded 1749 frames, 7.53 fps, 1825.89 kb/s
    encoded 1749 frames, 7.52 fps, 1825.89 kb/s
  12. graysky
  13. Mac Daddy
    Same system and settings as this thread just the different test :wave:
    http://forums.techarp.com/reviews-articles/23859-x264-hd-benchmark-2.html#post325572
    Code:
    encoded 1749 frames, 69.83 fps, 1850.89 kb/s
    encoded 1749 frames, 69.96 fps, 1850.89 kb/s
    encoded 1749 frames, 70.13 fps, 1850.89 kb/s
    encoded 1749 frames, 70.05 fps, 1850.89 kb/s
    encoded 1749 frames, 70.09 fps, 1850.89 kb/s
    encoded 1749 frames, 16.85 fps, 1826.38 kb/s
    encoded 1749 frames, 16.82 fps, 1826.37 kb/s
    encoded 1749 frames, 16.85 fps, 1826.37 kb/s
    encoded 1749 frames, 16.84 fps, 1826.37 kb/s
    encoded 1749 frames, 16.81 fps, 1826.37 kb/s
  14. Mac Daddy
    These results were posted due to a discussion on this thread ..
    http://forums.techarp.com/processors/23878-c1e-eist.html
    I haven't really O/Ced here as Chai mentioned but the difference is neglagable so far :think:
    Code:
    encoded 1749 frames, 69.74 fps, 1850.89 kb/s
    encoded 1749 frames, 70.00 fps, 1850.89 kb/s
    encoded 1749 frames, 16.77 fps, 1826.37 kb/s
    encoded 1749 frames, 16.75 fps, 1826.37 kb/s
    encoded 1749 frames, 16.77 fps, 1826.38 kb/s
    encoded 1749 frames, 16.76 fps, 1826.37 kb/s
    encoded 1749 frames, 16.75 fps, 1826.33 kb/s
  15. cEvin Ki
    cEvin Ki Newbie
    encoded 1749 frames, 162.70 fps, 1850.94 kb/s
    encoded 1749 frames, 162.94 fps, 1850.94 kb/s
    encoded 1749 frames, 42.85 fps, 1829.18 kb/s
    encoded 1749 frames, 42.87 fps, 1829.13 kb/s
    encoded 1749 frames, 42.81 fps, 1829.39 kb/s
    encoded 1749 frames, 42.89 fps, 1829.17 kb/s
    encoded 1749 frames, 42.85 fps, 1829.35 kb/s
    Q6600 Kentsfield
    333x9
    DDR2 1:1 @667 3-3-3-8 (this time with a tRD=5, as opposed to my above post where it was set at 6)
    X38
    XP32 Pro SP2
  16. ohropax
    ohropax Newbie
    T7500
    11x200
    GM965
    5-5-5-15 @ 333
    XP Pro SP2
    encoded 1749 frames, 63.53 fps, 1850.89 kb/s
    encoded 1749 frames, 63.35 fps, 1850.89 kb/s
    encoded 1749 frames, 62.89 fps, 1850.89 kb/s
    encoded 1749 frames, 63.42 fps, 1850.89 kb/s
    encoded 1749 frames, 63.45 fps, 1850.89 kb/s
    encoded 1749 frames, 15.50 fps, 1826.22 kb/s
    encoded 1749 frames, 15.53 fps, 1826.37 kb/s
    encoded 1749 frames, 15.54 fps, 1826.38 kb/s
    encoded 1749 frames, 15.52 fps, 1826.37 kb/s
  17. Photokon
    Photokon Newbie
    encoded 1749 frames, 193.00 fps, 1850.94 kb/s
    encoded 1749 frames, 192.32 fps, 1850.94 kb/s
    encoded 1749 frames, 195.01 fps, 1850.94 kb/s
    encoded 1749 frames, 193.99 fps, 1850.94 kb/s
    encoded 1749 frames, 194.33 fps, 1850.94 kb/s
    encoded 1749 frames, 44.70 fps, 1829.07 kb/s
    encoded 1749 frames, 44.38 fps, 1829.32 kb/s
    encoded 1749 frames, 44.90 fps, 1829.04 kb/s
    encoded 1749 frames, 44.63 fps, 1829.27 kb/s
    encoded 1749 frames, 45.19 fps, 1829.35 kb/s
    CPU: Intel Kentsfield Q6600
    FSB: 9x344.5
    CPU Speed: 3100.5
    Chipset: Nvidia 750i-SLI
    Memory Timings: 4-4-4-12 1T
    Memory speed: 689 MHz
    OS: WinXP
  18. SomeoneElse
    SomeoneElse Newbie
    Q9450 @ 8x400
    CPU: Intel Yorkfield Q9450 C1
    FSB: 8x400 (Default would be 8x333)
    CPU Speed: 3200
    Chipset: Intel X38
    Motherboard: Abit X38 QuadGT Bios 12
    Memory Timings: 5-5-5-15 2T @ 480.2 MHz
    OS: WinXP SP2 + Updates
    C1E: Auto
    EIST: Enabled
    I bumped the FSB from 8x333 to FSB 8x400. Nothing else was changed in BIOS.
    encoded 1749 frames, 187.80 fps, 1850.94 kb/s
    encoded 1749 frames, 187.82 fps, 1850.94 kb/s
    encoded 1749 frames, 187.18 fps, 1850.94 kb/s
    encoded 1749 frames, 51.56 fps, 1829.56 kb/s
    encoded 1749 frames, 51.51 fps, 1829.14 kb/s
    encoded 1749 frames, 51.42 fps, 1829.31 kb/s
    encoded 1749 frames, 51.51 fps, 1829.39 kb/s
    encoded 1749 frames, 51.32 fps, 1829.43 kb/s
  19. graysky
    Sorry for the lack of activity on my part with the 'classic' SD benchmark, guys. I will get all these new data in there ASAP and update the main page. In the meantime, I'd like to invite everyone to run their systems through the x264 HD Benchmark which can be found at this URL.
  20. SomeoneElse
    SomeoneElse Newbie
    Q9450 @ 8x333
    FSB: 8x333 (stock)
    CPU Speed: 2660
    Chipset: Intel X38
    Memory Timings: 5-5-5-15 2T @ 400 MHz
    C1E: Auto
    EIST: Enabled
    Stock speeds...no overclocking. I don't know what my max stable overclock is yet, I just got this system up and running today.
    encoded 1749 frames, 156.33 fps, 1850.94 kb/s
    encoded 1749 frames, 155.91 fps, 1850.94 kb/s
    encoded 1749 frames, 156.57 fps, 1850.94 kb/s
    encoded 1749 frames, 156.55 fps, 1850.94 kb/s
    encoded 1749 frames, 156.78 fps, 1850.94 kb/s
    encoded 1749 frames, 42.74 fps, 1829.43 kb/s
    encoded 1749 frames, 42.92 fps, 1829.16 kb/s
    encoded 1749 frames, 42.81 fps, 1829.18 kb/s
    encoded 1749 frames, 42.87 fps, 1829.39 kb/s
    encoded 1749 frames, 42.87 fps, 1829.21 kb/s
