x264 Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Sep 9, 2007.
  1. kpfong
    kpfong Newbie
    CPU: AMD Phenom 9750
    FSB: 200MHz x 12
    Chipset: RD790 (790FX)
    Memory Timing: 6-6-6-18@400MHz
    OS: Win Vista Ult 64
    ---------- RUN1PASS1.LOG
    encoded 1749 frames, 127.84 fps, 1850.94 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1749 frames, 126.97 fps, 1850.94 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1749 frames, 127.98 fps, 1850.94 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1749 frames, 127.26 fps, 1850.94 kb/s
    ---------- RUN5PASS1.LOG
    ---------- RUN1PASS2.LOG
    encoded 1749 frames, 32.56 fps, 1829.21 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1749 frames, 32.33 fps, 1829.32 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1749 frames, 32.73 fps, 1829.48 kb/s
    ---------- RUN4PASS2.LOG
    encoded 1749 frames, 32.53 fps, 1829.37 kb/s
    ---------- RUN5PASS2.LOG
    encoded 1749 frames, 32.53 fps, 1829.25 kb/s
  2. supply2k
    supply2k Newbie
    HP DL580 G5 4P 8G
    CPU : INTEL XEON X7350 * 4EA
    RAM : 2GB PC5300 FBDIMM * 4EA
    OTHER : HP DL580 G5 SYSTEM
    OS : WINDOWS SERVER 2003 R2 X64 STANDARD SP2
    encoded 1749 frames, 98.02 fps, 1849.61 kb/s
    encoded 1749 frames, 113.99 fps, 1849.61 kb/s
    encoded 1749 frames, 102.60 fps, 1849.61 kb/s
    encoded 1749 frames, 105.00 fps, 1849.61 kb/s
    encoded 1749 frames, 102.98 fps, 1849.61 kb/s
    encoded 1749 frames, 107.63 fps, 1847.40 kb/s
    encoded 1749 frames, 109.00 fps, 1847.40 kb/s
    encoded 1749 frames, 97.00 fps, 1847.40 kb/s
    encoded 1749 frames, 112.27 fps, 1847.40 kb/s
    encoded 1749 frames, 107.01 fps, 1847.40 kb/s
  3. supply2k
    supply2k Newbie
  4. speedy
    speedy Newbie
    Q9450 @ 3800
    See screenshots for system info
    encoded 1749 frames, 204.80 fps, 1850.94 kb/s
    encoded 1749 frames, 204.66 fps, 1850.94 kb/s
    encoded 1749 frames, 204.71 fps, 1850.94 kb/s
    encoded 1749 frames, 204.92 fps, 1850.94 kb/s
    encoded 1749 frames, 56.13 fps, 1829.19 kb/s
    encoded 1749 frames, 56.20 fps, 1829.45 kb/s
    encoded 1749 frames, 56.30 fps, 1829.34 kb/s
    encoded 1749 frames, 56.35 fps, 1829.29 kb/s
    encoded 1749 frames, 56.39 fps, 1829.51 kb/s
  5. Bennett
    Bennett Newbie
    CPU: Intel C2D E2180 M0
    FSB: 8x388
    CPU Speed: 3104
    Chipset: Intel P35
    Motherboard: Gigabyte EP35-DS3 Bios F2
    Memory: A-Data 2GB 800MHz
    Memory Timings: 5-5-5-18 2T @ 485 MHz
    OS: WinXP SP2 + Updates
  6. sopiebaba
    sopiebaba Newbie
    Here are Mine , slightly overclocked:
    Machine Specs :
    *Proc.........: Phenom 9950BE @ 2800mhz,
    *MP/FSB.....: 14x200,
    *Chipset.....: nForce 750a SLI MCP,
    *Mobo........: MSI K9N2 SLI Platinum
    *RAM..........: OCZ 2x2048 MB PC2-8500
    *RAM Timing.: [email protected],
    *OS............: XP Pro x64 SP3
    encoded 1749 frames, 150.66 fps, 1850.94 kb/s
    encoded 1749 frames, 147.86 fps, 1850.94 kb/s
    encoded 1749 frames, 148.85 fps, 1850.94 kb/s
    encoded 1749 frames, 149.04 fps, 1850.94 kb/s
    encoded 1749 frames, 38.61 fps, 1829.40 kb/s
    encoded 1749 frames, 38.51 fps, 1829.21 kb/s
    encoded 1749 frames, 38.65 fps, 1829.34 kb/s
    encoded 1749 frames, 38.36 fps, 1829.36 kb/s
    encoded 1749 frames, 38.61 fps, 1829.13 kb/s
    :wall:
  7. Brolloks
    Brolloks Newbie
    encoded 1749 frames, 255.55 fps, 1849.61 kb/s
    encoded 1749 frames, 253.81 fps, 1849.61 kb/s
    encoded 1749 frames, 254.99 fps, 1849.61 kb/s
    encoded 1749 frames, 256.75 fps, 1849.61 kb/s
    encoded 1749 frames, 89.98 fps, 1835.04 kb/s
    encoded 1749 frames, 89.69 fps, 1834.86 kb/s
    encoded 1749 frames, 90.05 fps, 1834.86 kb/s
    encoded 1749 frames, 90.20 fps, 1834.86 kb/s
    encoded 1749 frames, 90.20 fps, 1834.22 kb/s
  8. Brolloks
    Brolloks Newbie
    Results for x264.exe v0.58.747
    encoded 1442 frames, 95.14 fps, 3904.94 kb/s
    encoded 1442 frames, 99.45 fps, 3904.94 kb/s
    encoded 1442 frames, 100.21 fps, 3904.94 kb/s
    encoded 1442 frames, 100.64 fps, 3904.94 kb/s
    encoded 1442 frames, 33.73 fps, 3974.08 kb/s
    encoded 1442 frames, 33.95 fps, 3974.08 kb/s
    encoded 1442 frames, 33.98 fps, 3974.08 kb/s
    encoded 1442 frames, 33.81 fps, 3974.08 kb/s
    System Details
    Name Intel Processor
    Codename Bloomfield
    Specification Intel(R) Core(TM) i7 CPU 940 @ 2.93GHz
    Core Stepping
    Technology 45 nm
    Stock frequency 2933 MHz
    Core Speed 4004.0 MHz (22.0 x 182.0 MHz)
    Northbridge Intel X58 rev. 12
    Memory Frequency 1456.0 MHz ()
    Memory Type DDR3
    Memory Size 3064 MBytes
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    max VID 0.825 V
    Voltage sensor 0 1.40 Volts [0xAF] (CPU VCORE)
    Number of processors 1
    Number of threads 8
    Number of threads 8 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
    Package Socket 1366 LGA (platform ID = 1h)
    Temperature sensor 0 29°C (84°F) [0x1D] (SYSTIN)
    Temperature sensor 1 57°C (133°F) [0x71] (CPUTIN)
    Temperature sensor 2 32°C (88°F) [0x3F] (AUXTIN)
    Temperature sensor 0 69°C (156°F) [0x24] (core #0)
    Temperature sensor 1 70°C (157°F) [0x23] (core #1)
    Temperature sensor 2 68°C (154°F) [0x25] (core #2)
    Temperature sensor 3 65°C (148°F) [0x28] (core #3)
    Temperature sensor 0 35°C (94°F) [0x23] (GPU Core)
  9. Arctucas
    Arctucas Newbie
    encoded 1749 frames, 103.93 fps, 1850.89 kb/s
    encoded 1749 frames, 104.61 fps, 1850.89 kb/s
    encoded 1749 frames, 104.52 fps, 1850.89 kb/s
    encoded 1749 frames, 104.42 fps, 1850.89 kb/s
    encoded 1749 frames, 25.77 fps, 1826.26 kb/s
    encoded 1749 frames, 25.83 fps, 1826.38 kb/s
    encoded 1749 frames, 25.87 fps, 1826.38 kb/s
    encoded 1749 frames, 25.86 fps, 1826.38 kb/s
    encoded 1749 frames, 25.86 fps, 1826.39 kb/s
    Core2 Duo E6750
    8x450
    nVidia 680i
    5-4-4-11 @ 450 MHz
    XP Pro SP3
  10. jwaggz82
    jwaggz82 Newbie
    how is your raid0 with the 3ware 9650SE-2LP card?
  11. Smithcraft
    Smithcraft Newbie
    encoded 1749 frames, 30.04 fps, 1850.89 kb/s
    encoded 1749 frames, 29.69 fps, 1850.89 kb/s
    encoded 1749 frames, 30.07 fps, 1850.89 kb/s
    encoded 1749 frames, 29.95 fps, 1850.89 kb/s
    encoded 1749 frames, 29.99 fps, 1850.89 kb/s
    encoded 1749 frames, 7.58 fps, 1826.37 kb/s
    encoded 1749 frames, 7.48 fps, 1826.37 kb/s
    encoded 1749 frames, 7.57 fps, 1826.37 kb/s
    encoded 1749 frames, 7.57 fps, 1826.21 kb/s
    encoded 1749 frames, 7.51 fps, 1826.20 kb/s
    System Details
    Name Intel Pentium 4 540
    Codename Prescott
    Specification Intel(R) Pentium(R) 4 CPU 3.20GHz
    Core Stepping D0
    Technology 90 nm
    Stock frequency 3200 MHz
    Core Speed 3192.1 MHz (16.0 x 199.5 MHz)
    Northbridge Intel i915P/i915G rev. B1
    Southbridge Intel 82801FB (ICH6) rev. 03
    CAS# 3.0
    RAS# to CAS# 3
    RAS# Precharge 3
    Cycle Time (tRAS) 8
    Memory Frequency 199.5 MHz (1:1)
    Memory Type DDR
    Memory Size 1024 MBytes
    Channels Dual
    Windows Version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
  12. tanakaro
    tanakaro Newbie
    encoded 1749 frames, 200.60 fps, 1850.94 kb/s
    encoded 1749 frames, 197.43 fps, 1850.94 kb/s
    encoded 1749 frames, 204.27 fps, 1850.94 kb/s
    encoded 1749 frames, 203.51 fps, 1850.94 kb/s
    encoded 1749 frames, 202.78 fps, 1850.94 kb/s
    encoded 1749 frames, 49.77 fps, 1829.32 kb/s
    encoded 1749 frames, 49.95 fps, 1829.15 kb/s
    encoded 1749 frames, 50.08 fps, 1829.49 kb/s
    encoded 1749 frames, 49.93 fps, 1829.51 kb/s
    encoded 1749 frames, 50.13 fps, 1829.40 kb/s
    Processors Information
    Processor 1 (ID = 0)
    Number of cores 4 (max 4)
    Number of threads 4 (max 4)
    Name AMD Phenom II Black Edition
    Codename Deneb
    Specification AMD Phenom(tm) II X4 B50 Processor
    Package Socket AM2+ (940)
    CPUID F.4.2
    Extended CPUID 10.4
    Brand ID 29
    Core Stepping RB-C2
    Technology 45 nm
    Core Speed 883.7 MHz (4.0 x 220.9 MHz)
    HT Link speed 2209.2 MHz
    Memory Type DDR3
    Memory Size 4096 MBytes
    Channels Dual (Unganged)
    Memory Frequency 736.4 MHz (3:10)
    CAS# 9.0
    RAS# to CAS# 9
    RAS# Precharge 9
    Cycle Time (tRAS) 24
    Bank Cycle Time (tRC) 33
    Command Rate 1T
    NB Frequency 2209.2 MHz
  13. giox069
    giox069 Newbie
    CPU: Intel Mobile Core 2 Duo P8600
    Codename: Penryn
    Core speed: 1596MHz
    Multiplier: x 6.0
    Chipset: Intel PM45 Rev 07
    DRAM Frequency: 399.0 MHz
    FSB:DRAM: 2:3
    DRAM Timings: 6-6-6-18
    OS: Windows XP Professional 32 bits, italian, OEM, Dell
    encoded 1749 frames, 69.61 fps, 1850.89 kb/s
    encoded 1749 frames, 69.57 fps, 1850.89 kb/s
    encoded 1749 frames, 69.40 fps, 1850.89 kb/s
    encoded 1749 frames, 69.31 fps, 1850.89 kb/s
    encoded 1749 frames, 69.79 fps, 1850.89 kb/s
    encoded 1749 frames, 17.91 fps, 1826.38 kb/s
    encoded 1749 frames, 17.71 fps, 1826.37 kb/s
    encoded 1749 frames, 17.87 fps, 1826.38 kb/s
    encoded 1749 frames, 17.89 fps, 1826.37 kb/s
    encoded 1749 frames, 17.86 fps, 1826.26 kb/s
  14. giox069
    giox069 Newbie
    CPU: AMD Athlon 64 X2 4200+
    CodeName: Windsor
    Core speed: 2210.2MHx
    Multiplier: x 11.0
    Chipset: NVIDIA MCP61
    DRAM Frequency: 315.7MHz
    FSB:DRAM: CPU/7
    DRAM Timings: 5-6-6-18
    OS: Windows Vista Professional x64 OEM
    encoded 1749 frames, 55.90 fps, 1850.89 kb/s
    encoded 1749 frames, 55.46 fps, 1850.89 kb/s
    encoded 1749 frames, 55.87 fps, 1850.89 kb/s
    encoded 1749 frames, 56.70 fps, 1850.89 kb/s
    encoded 1749 frames, 56.12 fps, 1850.89 kb/s
    encoded 1749 frames, 13.82 fps, 1826.38 kb/s
    encoded 1749 frames, 13.84 fps, 1826.37 kb/s
    encoded 1749 frames, 13.72 fps, 1826.37 kb/s
    encoded 1749 frames, 13.73 fps, 1826.37 kb/s
    encoded 1749 frames, 13.74 fps, 1825.85 kb/s
  15. laychi
    laychi Newbie
    3570K@4,5GHz-2200MHZ RAm :D:D
    encoded 1749 frames, 407.88 fps, 1850.94 kb/s
    encoded 1749 frames, 410.08 fps, 1850.94 kb/s
    encoded 1749 frames, 407.60 fps, 1850.94 kb/s
    encoded 1749 frames, 410.76 fps, 1850.94 kb/s
    encoded 1749 frames, 400.60 fps, 1850.94 kb/s
    encoded 1749 frames, 92.37 fps, 1829.11 kb/s
    encoded 1749 frames, 92.71 fps, 1829.48 kb/s
    encoded 1749 frames, 93.32 fps, 1829.53 kb/s
    encoded 1749 frames, 93.48 fps, 1829.17 kb/s
    encoded 1749 frames, 93.33 fps, 1829.17 kb/s
