Aethir, Is your processor really an Athlon XP 2600+? Cause the "Thoroughbred" Athlon XP 2600+ runs at either 2.13 GHz or 2.08 GHz.
Hi guys I'm new here Found this benchmark through Legit Reviews. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 83.54 fps, 3901.21 kb/s encoded 1442 frames, 83.82 fps, 3900.68 kb/s encoded 1442 frames, 84.10 fps, 3900.68 kb/s encoded 1442 frames, 83.87 fps, 3900.68 kb/s encoded 1442 frames, 25.29 fps, 3971.50 kb/s encoded 1442 frames, 25.31 fps, 3970.87 kb/s encoded 1442 frames, 25.19 fps, 3972.17 kb/s encoded 1442 frames, 25.23 fps, 3971.59 kb/s System Details -------------- Name AMD Phenom II X4 965 Codename Deneb Specification AMD Phenom(tm) II X4 965 Processor Core Stepping RB-C3 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Core Speed 3937.6 MHz Northbridge AMD 790X rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 11.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 11 Cycle Time (tRAS) 29 Command Rate (CR) 1T Memory Frequency 900.0 MHz (1:4) Memory Type DDR3 Memory Size 6144 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 34°C (93°F) [0x22] (TMPIN0) Temperature 1 47°C (116°F) [0x2F] (TMPIN1) Temperature 2 47°C (116°F) [0x2F] (TMPIN2) Temperature 0 48°C (117°F) [0x17D] (Core #0) Temperature 1 48°C (117°F) [0x17C] (Core #1) Temperature 3 48°C (117°F) [0x17D] (Core #3) Temperature 2 48°C (118°F) [0x17F] (Core #2)
It's what the BIOS reports it as, and CPU-Z backs it up: Validated As you can see this one is running at a nonstandard 2.10GHz
Here's my bench.... Results for x264.exe r1342 -------------------------- encoded 1442 frames, 11.64 fps, 3899.26 kb/s encoded 1442 frames, 12.29 fps, 3899.26 kb/s encoded 1442 frames, 12.24 fps, 3899.26 kb/s encoded 1442 frames, 12.22 fps, 3899.26 kb/s encoded 1442 frames, 2.83 fps, 3970.96 kb/s encoded 1442 frames, 2.86 fps, 3970.83 kb/s encoded 1442 frames, 2.86 fps, 3971.09 kb/s encoded 1442 frames, 2.86 fps, 3971.33 kb/s System Details -------------- Name Intel Pentium 4 Codename Prescott Specification Intel(R) Pentium(R) 4 CPU 3.00GHz Core Stepping D0 Technology 90 nm Manufacturer (ID) Nanya Technology (7F7F7F0B000000FF) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) vendor Gigabyte Technology Co., Ltd. Stock frequency 3000 MHz Core Speed 3014.7 MHz Northbridge Intel i865P/PE/G/i848P rev. A2 Southbridge Intel 82801EB (ICH5) rev. 02 CAS# latency (CL) 2.5 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 8 Memory Frequency 201.0 MHz (1:1) Memory Type DDR Memory Size 1536 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 1024 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3 Package (platform ID) Socket 478 mPGA (0x2) Temperature 0 85°C (184°F) [0x55] (Diode 1) Temperature 1 39°C (102°F) [0x27] (Ambient) Temperature 2 1°C (33°F) [0x1] (Diode 2)
Hi I bought this cpu two weeks ago. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 96.69 fps, 3899.02 kb/s encoded 1442 frames, 93.94 fps, 3899.02 kb/s encoded 1442 frames, 95.79 fps, 3899.02 kb/s encoded 1442 frames, 95.29 fps, 3899.02 kb/s encoded 1442 frames, 38.69 fps, 3955.26 kb/s encoded 1442 frames, 38.56 fps, 3956.33 kb/s encoded 1442 frames, 38.48 fps, 3960.31 kb/s encoded 1442 frames, 38.55 fps, 3957.44 kb/s System Details -------------- Name Intel Core i7 950 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz Core Stepping D0 Technology 45 nm Stock frequency 3066 MHz Core Speed 4199.9 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 800.0 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 27°C (80°F) [0x1B] (SYSTIN) Temperature 1 43°C (109°F) [0x56] (CPUTIN) Temperature 2 32°C (89°F) [0x40] (AUXTIN) Temperature 0 58°C (136°F) [0x2A] (Core #0) Temperature 1 51°C (123°F) [0x31] (Core #1) Temperature 2 55°C (130°F) [0x2D] (Core #2) Temperature 3 49°C (120°F) [0x33] (Core #3)
x264 HD BENCHMARK 3.0 RESULTS Results for x264.exe r1342 -------------------------- encoded 1442 frames, 64.44 fps, 3899.02 kb/s encoded 1442 frames, 64.32 fps, 3899.02 kb/s encoded 1442 frames, 65.24 fps, 3899.02 kb/s encoded 1442 frames, 64.06 fps, 3898.50 kb/s encoded 1442 frames, 26.39 fps, 3962.78 kb/s encoded 1442 frames, 26.37 fps, 3967.58 kb/s encoded 1442 frames, 26.27 fps, 3956.74 kb/s encoded 1442 frames, 26.12 fps, 3962.12 kb/s -------------------------------------------- Results for x264.exe r1804 32bit ------------------------------- encoded 1442 frames, 103.67 fps, 3911.14 kb/s encoded 1442 frames, 105.47 fps, 3911.14 kb/s encoded 1442 frames, 104.32 fps, 3911.14 kb/s encoded 1442 frames, 104.58 fps, 3911.14 kb/s encoded 1442 frames, 26.89 fps, 3959.93 kb/s encoded 1442 frames, 26.75 fps, 3960.16 kb/s encoded 1442 frames, 26.35 fps, 3958.00 kb/s encoded 1442 frames, 26.72 fps, 3958.50 kb/s -------------------------------------------- Results for x264.exe r1804 64bit ------------------------------- encoded 1442 frames, 100.03 fps, 3911.14 kb/s encoded 1442 frames, 101.24 fps, 3911.14 kb/s encoded 1442 frames, 100.82 fps, 3911.14 kb/s encoded 1442 frames, 100.52 fps, 3911.14 kb/s encoded 1442 frames, 28.53 fps, 3959.14 kb/s encoded 1442 frames, 28.48 fps, 3959.84 kb/s encoded 1442 frames, 28.49 fps, 3960.63 kb/s encoded 1442 frames, 28.44 fps, 3960.01 kb/s performance gain at 2 pass ~7% System Details -------------- Name Intel Core i7 860 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Stock frequency 2800 MHz Core Speed 2943.6 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel H55 rev. 06 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 669.0 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 x64 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 40°C (103°F) [0x28] (SYSTIN) Temperature 1 67°C (151°F) [0x85] (CPUTIN) Temperature 2 56°C (132°F) [0x70] (AUXTIN) Temperature 0 73°C (163°F) [0x1A] (Core #0) Temperature 1 77°C (170°F) [0x16] (Core #1) Temperature 2 74°C (165°F) [0x19] (Core #2) Temperature 3 75°C (166°F) [0x18] (Core #3)
Yes, I think it's time to make two separate branches of the test for 32-bit version of the codec, and 64-bit version.
Well, the 32-bit and 64-bit versions do not have quite that much of a difference, but it might be interesting to see if AMD or Intel processors perform differently for the 64-bit version. In any case, the 32-bit encoder needs to be updated. There is a huge performance difference from the encoder we are using now.
x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 75.58 fps, 3901.21 kb/s encoded 1442 frames, 76.21 fps, 3900.68 kb/s encoded 1442 frames, 76.15 fps, 3900.68 kb/s encoded 1442 frames, 76.21 fps, 3900.10 kb/s encoded 1442 frames, 22.95 fps, 3971.94 kb/s encoded 1442 frames, 22.88 fps, 3970.73 kb/s encoded 1442 frames, 22.89 fps, 3970.51 kb/s encoded 1442 frames, 22.92 fps, 3971.90 kb/s System Details -------------- Name Intel Core 2 Quad Q9550 product System Product Name Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Core Stepping E0 Technology 45 nm Stock frequency 2833 MHz Core Speed 3434.0 MHz FID range 6.0x - 8.5x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 484.8 MHz (5:6) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 26°C (78°F) [0x1A] (SYSTIN) Temperature 1 66°C (150°F) [0x84] (CPUTIN) Temperature 2 36°C (95°F) [0x47] (AUXTIN) Temperature 0 68°C (154°F) [0x20] (Core #0) Temperature 1 62°C (143°F) [0x26] (Core #1) Temperature 2 64°C (147°F) [0x24] (Core #2) Temperature 3 65°C (148°F) [0x23] (Core #3)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 87.50 fps, 3898.50 kb/s encoded 1442 frames, 85.99 fps, 3899.02 kb/s encoded 1442 frames, 87.29 fps, 3899.02 kb/s encoded 1442 frames, 88.68 fps, 3898.31 kb/s encoded 1442 frames, 35.22 fps, 3961.81 kb/s encoded 1442 frames, 35.32 fps, 3960.54 kb/s encoded 1442 frames, 35.23 fps, 3959.82 kb/s encoded 1442 frames, 35.32 fps, 3968.82 kb/s System Details -------------- Name Intel Core i7 920 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping D0 Technology 45 nm Stock frequency 2666 MHz Core Speed 3800.8 MHz Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 724.0 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 41°C (105°F) [0x29] (SYSTIN) Temperature 1 51°C (122°F) [0x65] (CPUTIN) Temperature 2 17°C (62°F) [0x1DE] (AUXTIN) Temperature 0 52°C (125°F) [0x30] (Core #0) Temperature 1 57°C (134°F) [0x2B] (Core #1) Temperature 2 49°C (120°F) [0x33] (Core #2) Temperature 3 52°C (125°F) [0x30] (Core #3)
x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 118.66 fps, 3899.02 kb/s encoded 1442 frames, 121.15 fps, 3899.02 kb/s encoded 1442 frames, 118.61 fps, 3899.02 kb/s encoded 1442 frames, 121.62 fps, 3899.02 kb/s encoded 1442 frames, 47.43 fps, 3957.61 kb/s encoded 1442 frames, 47.16 fps, 3951.39 kb/s encoded 1442 frames, 47.45 fps, 3966.18 kb/s encoded 1442 frames, 47.55 fps, 3971.91 kb/s System Details -------------- Name Intel Sandy Bridge Codename Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Specification PC3-12800 Specification PC3-12800 Core Stepping Technology 32 nm Stock frequency 3400 MHz Core Speed 4635.4 MHz Northbridge Intel ID0100 rev. 09 Southbridge Intel ID1C46 rev. 03 Command Rate 2T Command Rate 2T Memory Type Memory Size 8192 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) (0x1) Temperature 0 36°C (96°F) [0x24] (SYSTIN) Temperature 1 51°C (122°F) [0x65] (CPUTIN) Temperature 2 62°C (143°F) [0x7C] (AUXTIN) Temperature 0 36°C (96°F) [0x24] (SYSTIN) Temperature 1 51°C (122°F) [0x65] (CPUTIN) Temperature 2 63°C (144°F) [0x7D] (AUXTIN) Temperature 0 50°C (121°F) [0x30] (Core #0) Temperature 1 58°C (136°F) [0x28] (Core #1) Temperature 2 51°C (123°F) [0x2F] (Core #2) Temperature 3 57°C (134°F) [0x29] (Core #3)
