i5 2500k @4.2 GHz @ 1.24 V: Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 173.15 fps, 3912.26 kb/s encoded 1442 frames, 172.82 fps, 3912.26 kb/s encoded 1442 frames, 174.11 fps, 3912.26 kb/s encoded 1442 frames, 173.80 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 35.29 fps, 3961.68 kb/s encoded 1442 frames, 35.29 fps, 3961.67 kb/s encoded 1442 frames, 35.36 fps, 3961.59 kb/s encoded 1442 frames, 35.33 fps, 3961.84 kb/s System Details -------------- Name Intel Core i5 2500K product System Product Name Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Specification PC3-10700 Specification PC3-10700 Core Stepping D2 Technology 32 nm Stock frequency 3300 MHz Core Speed 1600.1 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel P67 rev. B3 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 800.1 MHz (1:6) Memory Type DDR3 Memory Size 4096 MBytes Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 34°C (93°F) [0x22] (CPU socket) Temperature 1 0°C (32°F) [0x0] (CPU) Temperature 2 0°C (32°F) [0x0] (Mainboard)
Intel Core i5 i-2500k @ 4.2Ghz w/ 4GB DDR3 2133 x264 HD BENCHMARK 4.0 RESULTS Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 181.96 fps, 3912.26 kb/s encoded 1442 frames, 186.35 fps, 3912.26 kb/s encoded 1442 frames, 184.87 fps, 3912.26 kb/s encoded 1442 frames, 185.61 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 36.81 fps, 3961.50 kb/s encoded 1442 frames, 36.75 fps, 3961.45 kb/s encoded 1442 frames, 36.87 fps, 3961.41 kb/s encoded 1442 frames, 36.96 fps, 3961.38 kb/s System Details -------------- Name Intel Core i5 2500K product System Product Name Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Specification PC3-17100 Specification PC3-17100 Core Stepping D2 Technology 32 nm Stock frequency 3300 MHz Core Speed 3712.3 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel P67 rev. B3 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 28 Command Rate (CR) 2T Command Rate 1T Command Rate 1T Memory Frequency 1070.3 MHz (1:8) Memory Type DDR3 Memory Size 4096 MBytes Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 37°C (98°F) [0x25] (SYSTIN) Temperature 1 0°C (32°F) [0x0] (CPUTIN) Temperature 2 64°C (147°F) [0x80] (AUXTIN)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 161.12 fps, 3911.63 kb/s encoded 1442 frames, 159.87 fps, 3911.63 kb/s encoded 1442 frames, 159.69 fps, 3911.63 kb/s encoded 1442 frames, 159.16 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 39.33 fps, 3959.10 kb/s encoded 1442 frames, 39.28 fps, 3960.00 kb/s encoded 1442 frames, 39.37 fps, 3959.68 kb/s encoded 1442 frames, 39.40 fps, 3959.98 kb/s System Details -------------- Name Intel Core i7 920 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Specification PC3-16000 Specification PC3-16000 Specification PC3-16000 Core Stepping D0 Technology 45 nm Stock frequency 2666 MHz Core Speed 4198.7 MHz Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 1T Command Rate 1T Command Rate 1T Memory Frequency 799.7 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 41°C (105°F) [0x29] (SYSTIN) Temperature 1 44°C (111°F) [0x58] (CPUTIN) Temperature 2 12°C (52°F) [0x17] (AUXTIN)
Turbo Boost OFF Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 42.06 fps, 3912.26 kb/s encoded 1442 frames, 45.93 fps, 3912.26 kb/s encoded 1442 frames, 42.35 fps, 3912.26 kb/s encoded 1442 frames, 41.39 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 8.93 fps, 3962.05 kb/s encoded 1442 frames, 8.74 fps, 3962.14 kb/s encoded 1442 frames, 8.14 fps, 3961.28 kb/s encoded 1442 frames, 8.06 fps, 3961.63 kb/s System Details -------------- Intel Core i5 520M - Arrandale Multiplier x20 FSB 133 MHz MB - Havendale/Clarkdale Host Bridge - Rev. 02 DRAM Frequency - 532.2 MHz FSBRAM - 4:16 CAS# Latency (CL) - 7.0 clocks RAS# to CAS# Delay (tRCD) - 7 clocks Windows 7 Home Premium Service Pack 1
Turbo Boost ON Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 60.12 fps, 3912.26 kb/s encoded 1442 frames, 58.35 fps, 3912.26 kb/s encoded 1442 frames, 60.61 fps, 3912.26 kb/s encoded 1442 frames, 55.75 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 11.67 fps, 3961.24 kb/s encoded 1442 frames, 12.01 fps, 3961.74 kb/s encoded 1442 frames, 11.18 fps, 3961.45 kb/s encoded 1442 frames, 11.26 fps, 3961.70 kb/s System Details -------------- Intel Core i5 520M - Arrandale Multiplier x20 FSB 133 MHz MB - Havendale/Clarkdale Host Bridge - Rev. 02 DRAM Frequency - 532.2 MHz FSBRAM - 4:16 CAS# Latency (CL) - 7.0 clocks RAS# to CAS# Delay (tRCD) - 7 clocks Windows 7 Home Premium Service Pack 1
i7 2600K @ 4.5Ghz Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 178.44 fps, 3911.63 kb/s encoded 1442 frames, 180.18 fps, 3911.63 kb/s encoded 1442 frames, 178.78 fps, 3911.63 kb/s encoded 1442 frames, 183.04 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 46.13 fps, 3959.77 kb/s encoded 1442 frames, 46.29 fps, 3959.30 kb/s encoded 1442 frames, 46.52 fps, 3959.59 kb/s encoded 1442 frames, 46.50 fps, 3959.46 kb/s System Details -------------- Motherboard ASUS P8P67 EVO Memory 16GByte 9-9-9-24 1600Mhz @ 1.5VDC Processor 1 ID = 0 Number of cores 4 (max 8) Number of threads 8 (max 16) Name Intel Core i7 2600K Codename Sandy Bridge Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Package (platform ID) Socket 1155 LGA (0x1) CPUID 6.A.7 Extended CPUID 6.2A Core Stepping D2 Technology 32 nm TDP Limit 95 Watts Core Speed 4499.7 MHz (Heat Pipe GeminII S cooled) Multiplier x FSB 45.0 x 100.0 MHz Stock frequency 3400 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Turbo Mode supported, enabled Max non-turbo ratio 34x Max turbo ratio 59x Max efficiency ratio 16x Min Power 60 Watts O/C bins unlimited
x264 HD BENCHMARK 4.0 RESULTS Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 110.64 fps, 3911.63 kb/s encoded 1442 frames, 112.52 fps, 3911.63 kb/s encoded 1442 frames, 111.77 fps, 3911.63 kb/s encoded 1442 frames, 111.35 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 27.30 fps, 3959.82 kb/s encoded 1442 frames, 27.28 fps, 3960.16 kb/s encoded 1442 frames, 27.34 fps, 3959.53 kb/s encoded 1442 frames, 27.26 fps, 3960.38 kb/s x264 HD BENCHMARK 4.0 x64 RESULTS Results for x264.exe r1913 x64 ============================== Pass 1 ------ encoded 1442 frames, 106.44 fps, 3911.63 kb/s encoded 1442 frames, 106.61 fps, 3911.63 kb/s encoded 1442 frames, 106.34 fps, 3911.63 kb/s encoded 1442 frames, 106.73 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 29.74 fps, 3960.48 kb/s encoded 1442 frames, 29.74 fps, 3960.30 kb/s encoded 1442 frames, 29.74 fps, 3960.12 kb/s encoded 1442 frames, 29.70 fps, 3958.86 kb/s System Details -------------- Name Intel Core i7 860 product System Product Name Name NVIDIA GeForce 8600 GT Codename Lynnfield Codename G84 Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm Technology 80 nm Stock frequency 2800 MHz Core Speed 3312.2 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel H55 rev. 06 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 662.4 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 64-bit (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 46°C (114°F) [0x2E] (SYSTIN) Temperature 1 70°C (158°F) [0x8C] (CPUTIN) Temperature 2 66°C (149°F) [0x83] (AUXTIN) Temperature 0 58°C (136°F) [0x3A] (TMPIN0) Temperature 0 58°C (136°F) [0x3A] (TMPIN0) x264_Benchmark_HD_v4.0 x64.rar only for Win 64-bit, based on x264 HD BENCHMARK 4.0 by graysky
In the test x264 HD BENCHMARK 4.0 using an outdated version of the library DgIndex (DGDecode.dll v.1.5.0.0; 2007). Recommends that you upgrade to the latest version v.1.5.8.0; 2010. DGDecode.rar
E6300 2.8Ghz at stock settings x264 HD BENCHMARK 4.0 RESULTS Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 48.04 fps, 3909.85 kb/s encoded 1442 frames, 49.59 fps, 3909.89 kb/s encoded 1442 frames, 49.30 fps, 3909.88 kb/s encoded 1442 frames, 49.35 fps, 3909.79 kb/s Pass 2 ------ encoded 1442 frames, 9.37 fps, 3962.51 kb/s encoded 1442 frames, 9.36 fps, 3962.68 kb/s encoded 1442 frames, 9.41 fps, 3962.83 kb/s encoded 1442 frames, 9.39 fps, 3962.06 kb/s System Details -------------- Name Intel Pentium E6300 Codename Wolfdale Specification Pentium(R) Dual-Core CPU E6300 @ 2.80GHz Core Stepping R0 Technology 45 nm Stock frequency 2800 MHz Core Speed 1600.1 MHz FID range 6.0x - 10.5x Northbridge Intel P45/P43/G45/G43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 20 Command Rate (CR) 1T Memory Frequency 533.4 MHz (1:2) Memory Type DDR3 Memory Size 2048 MBytes Channels Single Windows Version Microsoft Windows Vista (6.0) Home Basic Edition Service Pack 2 (Build 6002) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0) Temperature 0 54°C (129°F) [0x36] (TMPIN0) Temperature 1 45°C (112°F) [0x2D] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2)
Lenovo Ideacentre K330B (77273FU) Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 142.91 fps, 3911.63 kb/s encoded 1442 frames, 138.10 fps, 3911.63 kb/s encoded 1442 frames, 133.12 fps, 3911.63 kb/s encoded 1442 frames, 132.28 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 35.20 fps, 3960.03 kb/s encoded 1442 frames, 35.03 fps, 3959.90 kb/s encoded 1442 frames, 34.96 fps, 3959.40 kb/s encoded 1442 frames, 34.94 fps, 3959.27 kb/s System Details -------------- Name Intel Core i7 2600 Codename Sandy Bridge Specification Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Core Stepping D2 Technology 32 nm Stock frequency 3400 MHz Core Speed 1596.5 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel P67 rev. B3 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 665.2 MHz (1:5) Memory Type DDR3 Memory Size 12288 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 18°C (64°F) [0x12] (SYSTIN) Temperature 1 64°C (147°F) [0x80] (CPUTIN) Temperature 2 0°C (32°F) [0x0] (AUXTIN)
Results for x264.exe r1913 x64 ============================== Pass 1 ------ encoded 1442 frames, 202.58 fps, 3912.26 kb/s encoded 1442 frames, 202.16 fps, 3912.26 kb/s encoded 1442 frames, 202.61 fps, 3912.26 kb/s encoded 1442 frames, 202.39 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 44.08 fps, 3961.57 kb/s encoded 1442 frames, 44.17 fps, 3961.05 kb/s encoded 1442 frames, 43.99 fps, 3961.81 kb/s encoded 1442 frames, 44.09 fps, 3961.56 kb/s System Details -------------- CPU-Z version 1.57 Processors ------------------------------------------------------------------------- Number of processors 1 Number of threads 4 APICs ------------------------------------------------------------------------- Processor 0 -- Core 0 -- Thread 0 0 -- Core 1 -- Thread 0 2 -- Core 2 -- Thread 0 4 -- Core 3 -- Thread 0 6 Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 4 (max 8) Number of threads 4 (max 16) Name Intel Core i5 2500K Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Package (platform ID) Socket 1155 LGA (0x1) CPUID 6.A.7 Extended CPUID 6.2A Core Stepping D2 Technology 32 nm TDP Limit 95 Watts Core Speed 4854.4 MHz Multiplier x FSB 48.0 x 101.1 MHz Stock frequency 3300 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size L3 cache 6 MBytes, 12-way set associative, 64-byte line size FID/VID Control yes Turbo Mode supported, enabled Max non-turbo ratio 33x Max turbo ratio 59x Max efficiency ratio 16x Min Power 60 Watts O/C bins unlimited
