x264 HD Benchmark 4.0
Discussion in 'Reviews & Articles' started by Adrian Wong, Mar 7, 2011.
  1. Adrian Wong
    Thanks for the results, stivut! :thumb:
    If you have the time, please do retest at different speeds and at stock speed (with Turbo Boost disabled). Thanks!! :thumb:
  2. stivut
    stivut Newbie
    First: i5 2500k @ 5400MHz, 4Gb DDR3 2133MHz 7-9-7-20
    Results for x264.exe r1913 x64
    Pass 1
    encoded 1442 frames, 224.26 fps, 3912.26 kb/s
    encoded 1442 frames, 215.13 fps, 3912.26 kb/s
    encoded 1442 frames, 211.65 fps, 3912.26 kb/s
    encoded 1442 frames, 208.32 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 45.19 fps, 3961.35 kb/s
    encoded 1442 frames, 42.18 fps, 3961.59 kb/s
    encoded 1442 frames, 42.64 fps, 3961.60 kb/s
    encoded 1442 frames, 42.34 fps, 3961.18 kb/s
    System Details
    Name Intel Core i5 2500K
    product System Product Name
    Name Radeon HD 5850
    Codename Sandy Bridge
    Codename RV870
    Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
    Specification PC3-17100
    Core Stepping D2
    Technology 32 nm
    Technology 40 nm
    Stock frequency 3300 MHz
    Core Speed 5529.6 MHz
    Northbridge Intel Sandy Bridge rev. 09
    Southbridge Intel P67 rev. B3
    CAS# latency (CL) 7.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 7
    Cycle Time (tRAS) 20
    Command Rate (CR) 1T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 1072.5 MHz (1:8)
    Memory Type DDR3
    Memory Size 4096 MBytes
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
    Number of processors 1
    Number of threads 4
    Number of threads 4 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID) Socket 1155 LGA (0x1)
    Temperature 0 34°C (93°F) [0x22] (SYSTIN)
    Temperature 1 0°C (32°F) [0x0] (CPUTIN)
    Temperature 2 0°C (32°F) [0x0] (AUXTIN)
    Temperature 0 36°C (95°F) [0x23] (TMPIN0)
    CPU-Z version 1.57
    Processors
    Number of threads 4
    APICs
    Processor 0
    -- Core 0
    -- Thread 0 0
    -- Core 1
    -- Thread 0 2
    -- Core 2
    -- Thread 0 4
    -- Core 3
    -- Thread 0 6
    Processors Information
    Processor 1 ID = 0
    Number of cores 4 (max 8)
    CPUID 6.A.7
    Extended CPUID 6.2A
    Core Stepping D2
    Technology 32 nm
    TDP Limit 95 Watts
    Core Speed 5400.8 MHz
    Multiplier x FSB 54.0 x 100.0 MHz
    L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
    L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
    L3 cache 6 MBytes, 12-way set associative, 64-byte line size
    FID/VID Control yes
    Turbo Mode supported, enabled
    Max non-turbo ratio 33x
    Max turbo ratio 59x
    Max efficiency ratio 16x
    Min Power 60 Watts
    O/C bins unlimited
    I'll be back with the test on stock settings without TurboBoost:)!
  3. Adrian Wong
    Thanks, stivut!!! Keep 'em coming! :beer:
  4. FIXIT
    FIXIT Newbie
    A couple of AMDs
    Well, hello everyone! :wave:
    Here's my first post and as a longtime AMD fan I've noticed there are way too few AMD processors listed in the 4.0 results.
    As a system builder I mainly build AMD based systems and like to test 'em on a regular basis with this nifty little benchmark.
    So I'd like to start off with a Phenom 1090T from right off the shelf - no overclocking or any funny stuff.
    And Turbo Core disabled, of course.
    It's averaging 72.48fps
    Pass 1
    encoded 1442 frames, 114.12 fps, 3913.31 kb/s
    encoded 1442 frames, 112.59 fps, 3913.31 kb/s
    encoded 1442 frames, 111.77 fps, 3913.31 kb/s
    encoded 1442 frames, 114.54 fps, 3913.31 kb/s
    Pass 2
    encoded 1442 frames, 31.66 fps, 3957.93 kb/s
    encoded 1442 frames, 31.75 fps, 3959.00 kb/s
    encoded 1442 frames, 31.67 fps, 3958.38 kb/s
    encoded 1442 frames, 31.74 fps, 3960.22 kb/s
    System Details
    Name AMD Phenom II X6 1090T
    Name NVIDIA GeForce 9500 GT (Microsoft Corporation - WDDM v1.1)
    Codename Thuban
    Codename G96
    Specification AMD Phenom(tm) II X6 1090T Processor
    Specification PC3-12800
    Core Stepping PH-E0
    Technology 45 nm
    Technology 65 nm
    Stock frequency 3200 MHz
    Core Speed 800.1 MHz
    Northbridge AMD 890FX rev. 02
    Southbridge AMD SB850 rev. 40
    CAS# latency (CL) 9.0
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 24
    Command Rate (CR) 2T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 800.1 MHz (1:4)
    Memory Type DDR3
    Channels Dual, (Unganged)
    Number of threads 6
    Number of threads 6 (max 6)
    L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    Package Socket AM3 (938)
    Package Type 0x1
    Temperature 0 51°C (123°F) [0x33] (SYSTIN)
    Temperature 0 57°C (134°F) [0x39] (TMPIN0)
  5. FIXIT
    FIXIT Newbie
    A couple of AMDs
    Followed by a mobile AMD M320 which beats in a lenovo G555 laptop I have lying around here somewhere.
    It's averaging 20.48fps overall in the bench.
    Pass 1
    encoded 1442 frames, 34.69 fps, 3909.84 kb/s
    encoded 1442 frames, 34.83 fps, 3909.84 kb/s
    encoded 1442 frames, 34.84 fps, 3909.85 kb/s
    encoded 1442 frames, 34.76 fps, 3909.85 kb/s
    Pass 2
    encoded 1442 frames, 6.18 fps, 3962.59 kb/s
    encoded 1442 frames, 6.17 fps, 3962.41 kb/s
    encoded 1442 frames, 6.17 fps, 3962.67 kb/s
    encoded 1442 frames, 6.20 fps, 3962.04 kb/s
    System Details
    Name AMD Athlon II M320
    Codename Caspian
    Specification AMD Athlon(tm) II Dual-Core M320
    Core Stepping DA-C2
    Technology 45 nm
    Manufacturer (ID) Micron Technology (2C00000000000000)
    Stock frequency 2100 MHz
    Core Speed 2094.7 MHz
    FID range 4.0x - 10.5x
    Northbridge AMD 785GX rev. 00
    Southbridge AMD SB700 rev. 00
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 15
    Memory Frequency 332.5 MHz (3:5)
    Memory Type DDR2
    Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600)
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
    Package Socket S1 (638)
    Package Type 0x2
    Temperature 0 48°C (118°F) [0xC8C] (THRM)
    Temperature 1 0°C (32°F) [0xAAC] (THR1)
    I was just about to write a script myself when I accidently stumbled upon this little bench. Thanks again, very much appreciated.
    Cheers :beer:
    And stay tuned.
  6. FIXIT
    FIXIT Newbie
    And another AMD
    Here comes another reasonably priced CPU: the Athlon X2 220 averaging 28.7fps
    Pass 1
    encoded 1442 frames, 48.73 fps, 3909.82 kb/s
    encoded 1442 frames, 47.79 fps, 3909.84 kb/s
    encoded 1442 frames, 47.89 fps, 3909.82 kb/s
    encoded 1442 frames, 48.65 fps, 3909.85 kb/s
    Pass 2
    encoded 1442 frames, 9.17 fps, 3962.65 kb/s
    encoded 1442 frames, 9.07 fps, 3962.65 kb/s
    encoded 1442 frames, 9.11 fps, 3962.60 kb/s
    encoded 1442 frames, 9.17 fps, 3962.68 kb/s
    System Details
    Name AMD Athlon II X2 220
    Name NVIDIA GeForce 7025 / NVIDIA nForce 630a
    Codename Regor
    Specification AMD Athlon(tm) II X2 220 Processor
    Core Stepping DA-C3
    Technology 45 nm
    Stock frequency 2800 MHz
    Core Speed 803.7 MHz
    FID range 4.0x - 14.0x
    Northbridge NVIDIA GeForce 7025 rev. A3
    Southbridge NVIDIA nForce 630a rev. A2
    RAS# to CAS# delay (tRCD) 12
    RAS# Precharge (tRP) 12
    Cycle Time (tRAS) 30
    Memory Frequency 669.7 MHz (3:10)
    Memory Type DDR3
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
    Number of threads 2
    Package Type 0x1
    Temperature 0 38°C (100°F) [0x26] (SYSTIN)
    Temperature 1 51°C (122°F) [0x65] (CPUTIN)
    Temperature 2 29°C (84°F) [0x3A] (AUXTIN)
    1 person likes this.
  7. Adrian Wong
    Indeed! We don't have enough AMD processor results! :(
    Please see if you can test your AMD processors at various overclocked speeds so we can get more results.
    Thanks!! +rep! :D
  8. Novotno
    Novotno Newbie
    Intel's Core Quad 6600 @ 3600MHz (400x9).
    I've tried to run x264 on 3700Mhz(410x9), but failed, BSOD'ing...
    Pass 1
    encoded 1442 frames, 113.01 fps, 3912.26 kb/s
    encoded 1442 frames, 113.28 fps, 3912.26 kb/s
    encoded 1442 frames, 114.25 fps, 3912.26 kb/s
    encoded 1442 frames, 113.41 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 23.54 fps, 3961.14 kb/s
    encoded 1442 frames, 23.47 fps, 3961.57 kb/s
    encoded 1442 frames, 23.61 fps, 3961.54 kb/s
    encoded 1442 frames, 23.74 fps, 3961.07 kb/s
    System Details
    Name Intel Core 2 Quad Q6600
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
    Core Stepping G0
    Technology 65 nm
    Stock frequency 2400 MHz
    Core Speed 2402.5 MHz
    FID range 6.0x - 9.0x
    Northbridge Intel P35/G33/G31 rev. A2
    Southbridge Intel 82801IR (ICH9R) rev. 02
    Cycle Time (tRAS) 18
    Memory Frequency 533.9 MHz (1:2)
    Memory Type DDR2
    Channels Dual, (Symmetric)
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
    Package (platform ID) Socket 775 LGA (0x4)
    Temperature 0 39°C (102°F) [0x27] (SYSTIN)
    Temperature 1 39°C (102°F) [0x4E] (CPUTIN)
    Temperature 2 125°C (256°F) [0xF9] (AUXTIN)
  9. Adrian Wong
    Thanks, Novotno!
    BTW, if you have the time, please do us a favour and retest at stock speeds, and other (lower) clock speeds.
    Thanks!
  10. Novotno
    Novotno Newbie
    Q6600@2400 (266x9) Stock Speed
    Pass 1
    encoded 1442 frames, 79.48 fps, 3912.26 kb/s
    encoded 1442 frames, 79.62 fps, 3912.26 kb/s
    encoded 1442 frames, 79.82 fps, 3912.26 kb/s
    encoded 1442 frames, 79.96 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 16.09 fps, 3961.33 kb/s
    encoded 1442 frames, 16.09 fps, 3961.46 kb/s
    encoded 1442 frames, 16.01 fps, 3961.53 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 2402.4 MHz
    Memory Type DDR2
    Number of threads 4
    Temperature 1 30°C (85°F) [0x3C] (CPUTIN)
    Also tested Q6600@2400 with RAM set to 800MHz and 1T to see if ram speed matters:
    Pass 1
    encoded 1442 frames, 76.02 fps, 3912.32 kb/s
    encoded 1442 frames, 75.89 fps, 3912.26 kb/s
    encoded 1442 frames, 76.52 fps, 3912.31 kb/s
    encoded 1442 frames, 77.61 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 15.76 fps, 3961.24 kb/s
    encoded 1442 frames, 15.80 fps, 3961.25 kb/s
    encoded 1442 frames, 15.88 fps, 3961.60 kb/s
    encoded 1442 frames, 15.59 fps, 3961.10 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Memory Frequency 400.4 MHz (2:3)
    Memory Type DDR2
    Number of threads 4
    Temperature 0 33°C (91°F) [0x21] (SYSTIN)
    Temperature 1 31°C (87°F) [0x3E] (CPUTIN)
  11. Novotno
    Novotno Newbie
    Q6600@3000 (333x9) RAM@1111 2T
    Pass 1
    encoded 1442 frames, 96.69 fps, 3912.26 kb/s
    encoded 1442 frames, 97.82 fps, 3912.26 kb/s
    encoded 1442 frames, 97.20 fps, 3912.26 kb/s
    encoded 1442 frames, 97.40 fps, 3912.35 kb/s
    Pass 2
    encoded 1442 frames, 19.93 fps, 3961.86 kb/s
    encoded 1442 frames, 19.69 fps, 3961.87 kb/s
    encoded 1442 frames, 19.93 fps, 3961.10 kb/s
    encoded 1442 frames, 20.02 fps, 3961.29 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 2001.7 MHz
    Memory Frequency 556.0 MHz (3:5)
    Memory Type DDR2
    Number of threads 4
    Temperature 0 32°C (89°F) [0x20] (SYSTIN)
  12. Novotno
    Novotno Newbie
    Q6600@3300 (366x9) RAM@1100 2T
    Pass 1
    encoded 1442 frames, 105.28 fps, 3912.26 kb/s
    encoded 1442 frames, 104.57 fps, 3912.26 kb/s
    encoded 1442 frames, 104.45 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 21.40 fps, 3961.55 kb/s
    encoded 1442 frames, 21.70 fps, 3961.51 kb/s
    encoded 1442 frames, 21.58 fps, 3961.47 kb/s
    encoded 1442 frames, 21.70 fps, 3961.39 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 2193.8 MHz
    Memory Frequency 548.4 MHz (2:3)
    Memory Type DDR2
    Number of threads 4
    Temperature 1 29°C (84°F) [0x3A] (CPUTIN)
  13. Novotno
    Novotno Newbie
    Just tried Q6600@3700, but CPU throttles on air cooling :(
    It's clearly seen on floating fps from 1 to 4 runs.
    Pass 1
    encoded 1442 frames, 116.71 fps, 3912.26 kb/s
    encoded 1442 frames, 109.39 fps, 3912.26 kb/s
    encoded 1442 frames, 104.10 fps, 3912.26 kb/s
    encoded 1442 frames, 104.09 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 21.52 fps, 3961.05 kb/s
    encoded 1442 frames, 18.87 fps, 3961.89 kb/s
    encoded 1442 frames, 18.83 fps, 3961.30 kb/s
    encoded 1442 frames, 18.69 fps, 3961.23 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 2465.7 MHz
    Memory Frequency 547.9 MHz (3:4)
    Memory Type DDR2
    Number of threads 4
    Temperature 1 40°C (103°F) [0x50] (CPUTIN)
  14. Adrian Wong
    Wow! Thanks for the extra results, Novotno!! +rep!! :beer:
  15. chlp
    chlp Newbie
    Q6600 3400MHz (425x8) Windows NT 5.2.3790 x64
  16. Adrian Wong
    Thanks for the results, chlp!
    However, what type of memory and memory speed did you use? Thanks!
  17. Groucho2004
    Groucho2004 Newbie
    Can you explain to me why you publish the results from somebody who is interchanging the tools (x264 64 bit, for example) in your benchmark package?
  18. Adrian Wong
    Hello Groucho2004,
    I'm actually posting only r1913 results. I'm ignoring the 64-bit results.
  19. Groucho2004
    Groucho2004 Newbie
    From your last update:
    Added the Intel Core i5-2500K desktop processor (overclocked to 5.4 GHz).
    Added the Intel Core i5-2500K desktop processor (overclocked to 4.85 GHz).
    Both of these are x64 results. Just look closely at the posts from where you took the numbers.
    I don't want to be a troll but there are virtually no verifications about the software versions used, Avisynth, DGDecode, x264.
    This could easily be done with some lines of C/C++ code. It would also allow to remove the ridiculous check for Avisynth in the batch file. What if a user decides to install Avisynth to a different directory than the default?
  20. siriq
    siriq Newbie
    My result
    Pass 1
    encoded 1442 frames, 120.29 fps, 3912.32 kb/s
    encoded 1442 frames, 119.52 fps, 3912.32 kb/s
    encoded 1442 frames, 119.41 fps, 3912.32 kb/s
    encoded 1442 frames, 120.73 fps, 3912.32 kb/s
    Pass 2
    encoded 1442 frames, 24.14 fps, 3962.00 kb/s
    encoded 1442 frames, 24.03 fps, 3961.77 kb/s
    encoded 1442 frames, 24.12 fps, 3961.83 kb/s
    encoded 1442 frames, 24.15 fps, 3960.98 kb/s
    System Details
    Name AMD Phenom II X4
    Codename Deneb
    Specification AMD Phenom(tm) II X4 B55 Processor
    Specification PC3-10700
    Core Stepping RB-C3
    Technology 45 nm
    manufacturer Gigabyte Technology Co., Ltd.
    vendor Gigabyte Technology Co., Ltd.
    Core Speed 3616.6 MHz
    Cycle Time (tRAS) 29
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 803.7 MHz (1:4)
    Memory Type DDR3
    Memory Size 12288 MBytes
    Number of threads 4
    L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
    Package Type 0x1
    Temperature 0 30°C (85°F) [0x1E] (TMPIN0)
    Temperature 1 45°C (112°F) [0x2D] (TMPIN1)
    Temperature 2 48°C (118°F) [0x30] (TMPIN2)
    NB was not on stock. I use it on 2600 mhz
