x264 HD Benchmark 5.0
Discussion in 'Reviews & Articles' started by Adrian Wong, May 25, 2012.
  1. Intel i7-4770K OC
    These are preliminary results, with my stable 4.6Ghz OC. Though, it says it's a higher clock speed, due to dynamic base clock.
    Results for x264.exe r2200
    x264 Benchmark: 32-bit
    Pass 1
    encoded 5906 frames, 76.25 fps, 7779.52 kb/s
    encoded 5906 frames, 77.93 fps, 7779.52 kb/s
    encoded 5906 frames, 77.01 fps, 7779.52 kb/s
    encoded 5906 frames, 77.55 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 20.09 fps, 8002.16 kb/s
    encoded 5906 frames, 20.14 fps, 8002.16 kb/s
    encoded 5906 frames, 20.04 fps, 8002.16 kb/s
    System Details
    Name Intel Processor
    Codename Haswell
    Specification Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
    Specification PC3-18300
    Specification PC3-16000
    Core Stepping
    Technology 22 nm
    Stock frequency 3500 MHz
    Core Speed 4825.3 MHz
    Northbridge Intel ID0C00 rev. 06
    Southbridge Intel ID8C44 rev. 04
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Type
    Memory Size 8192 MBytes
    Windows Version Microsoft Windows 8 (6.2) 64-bit (Build 9200)
    Number of processors 1
    Number of threads 8
    Number of threads 8 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA
    Package (platform ID) Socket 1150 LGA (0x1)
    ______________________________________________________________________________________________________________
    Test #2, Used 64-Bit Version; Made a HUGE difference. I have my CPU @ 46x, but Bclock is dynamic, which auto OC's from 100-105mhz multiplied by mulitplier.
    x264 Benchmark: 64-bit
    Pass 1
    encoded 11812 frames, 99.38 fps, 7754.03 kb/s
    encoded 11812 frames, 99.88 fps, 7754.09 kb/s
    encoded 11812 frames, 98.36 fps, 7754.09 kb/s
    encoded 11812 frames, 98.95 fps, 7754.17 kb/s
    Pass 2
    encoded 11812 frames, 20.23 fps, 8002.19 kb/s
    encoded 11812 frames, 20.25 fps, 8002.13 kb/s
    encoded 11812 frames, 20.30 fps, 8002.09 kb/s
    encoded 11812 frames, 20.24 fps, 8002.13 kb/s
    System Details
    Codename Haswell
    Core Stepping
    Technology 22 nm
    Stock frequency 800 MHz
    Core Speed 4599.9 MHz
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Type
    Number of threads 8
  2. jafir
    jafir Newbie
    Pass 1
    encoded 11812 frames, 54.81 fps, 7757.25 kb/s
    encoded 11812 frames, 55.51 fps, 7757.09 kb/s
    encoded 11812 frames, 55.95 fps, 7757.22 kb/s
    encoded 11812 frames, 54.94 fps, 7757.33 kb/s
    Pass 2
    encoded 11812 frames, 15.58 fps, 7999.43 kb/s
    encoded 11812 frames, 15.59 fps, 7999.57 kb/s
    encoded 11812 frames, 15.61 fps, 7999.44 kb/s
    encoded 11812 frames, 15.58 fps, 7999.39 kb/s
    System Details
    Name Intel Xeon E5620
    Codename Westmere-EP
    Specification Intel(R) Xeon(R) CPU E5620 @ 2.40GHz
    Core Stepping B1
    Core Stepping B1
    Technology 32 nm
    Technology 32 nm
    Stock frequency 2400 MHz
    Core Speed 1596.0 MHz
    Northbridge Intel 5520 rev. 22
    CAS# latency (CL) 7.0
    RAS# to CAS# delay (tRCD) 7
    RAS# Precharge (tRP) 7
    Cycle Time (tRAS) 20
    Command Rate (CR) 1T
    Memory Frequency 532.0 MHz (2:8)
    Memory Type DDR3
    Memory Size 18430 MBytes
    Channels Triple
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
    Number of processors 2
    Number of threads 16
    Number of threads 8 (max 32)
    Package (platform ID) Socket 1366 LGA (0x0)
  3. jafir
    jafir Newbie
    So the first post had memory interleaving set to NUMA. This time I had it set for SMP, and it appears to improve the speed of the first pass.
    Pass 1
    encoded 11812 frames, 64.70 fps, 7757.32 kb/s
    encoded 11812 frames, 65.49 fps, 7757.27 kb/s
    encoded 11812 frames, 65.10 fps, 7757.23 kb/s
    encoded 11812 frames, 65.72 fps, 7757.31 kb/s
    Pass 2
    encoded 11812 frames, 15.82 fps, 7999.39 kb/s
    encoded 11812 frames, 15.87 fps, 7999.43 kb/s
    encoded 11812 frames, 15.91 fps, 7999.43 kb/s
    encoded 11812 frames, 15.91 fps, 7999.44 kb/s
    System Details
    Core Stepping B1
    Core Stepping B1
    Technology 32 nm
    Technology 32 nm
    Core Speed 1596.1 MHz
    Memory Type DDR3
    Channels Triple
  4. RJARRRPCGP
    RJARRRPCGP Newbie
    Q6600 @ 2.8 Ghz (312x9.0) (Maximus II Gene)
    Pass 1
    encoded 11812 frames, 23.35 fps, 7752.29 kb/s
    encoded 11812 frames, 23.36 fps, 7752.22 kb/s
    encoded 11812 frames, 23.49 fps, 7752.29 kb/s
    encoded 11812 frames, 23.53 fps, 7752.19 kb/s
    Pass 2
    encoded 11812 frames, 6.53 fps, 8002.84 kb/s
    encoded 11812 frames, 6.54 fps, 8002.84 kb/s
    System Details
    Name Intel Core 2 Quad Q6600
    product System Product Name
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
    Core Stepping G0
    Technology 65 nm
    Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000)
    Core Speed 2808.1 MHz
    FID range 6.0x - 9.0x
    Northbridge Intel P45/P43/G45/G43 rev. A3
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 15
    Command Rate (CR) 2T
    Memory Frequency 312.0 MHz (1:1)
    Memory Type DDR2
    Memory Size 4096 MBytes
    Channels Single
    Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601)
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
    Package (platform ID) Socket 775 LGA (0x4)
    Temperature 0 35°C (94°F) [0x23] (SYSTIN)
    Temperature 1 41°C (104°F) [0x51] (CPUTIN)
    Temperature 2 36°C (96°F) [0x48] (AUXTIN)
  5. RJARRRPCGP
    RJARRRPCGP Newbie
    Q6600 @ 3.0 Ghz (333x9.0) (Maximus II Gene)
    Pass 1
    encoded 11812 frames, 25.57 fps, 7752.32 kb/s
    encoded 11812 frames, 25.55 fps, 7752.24 kb/s
    encoded 11812 frames, 25.14 fps, 7752.22 kb/s
    encoded 11812 frames, 25.32 fps, 7752.20 kb/s
    Pass 2
    encoded 11812 frames, 7.03 fps, 8002.78 kb/s
    encoded 11812 frames, 7.01 fps, 8002.82 kb/s
    encoded 11812 frames, 7.01 fps, 8002.81 kb/s
    encoded 11812 frames, 7.01 fps, 8002.83 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 3005.4 MHz
    Memory Frequency 333.9 MHz (1:1)
    Memory Type DDR2
    Channels Single
    Number of threads 4
    Temperature 0 24°C (75°F) [0x18] (SYSTIN)
    Temperature 1 22°C (71°F) [0x2C] (CPUTIN)
    Temperature 2 36°C (95°F) [0x47] (AUXTIN)
  6. laychi
    laychi Newbie
    [email protected],5Ghz/MSI Z87 G43/TeamGroup Zeus 1600 X.M.P
    Pass 1
    encoded 11812 frames, 68.41 fps, 7752.40 kb/s
    encoded 11812 frames, 68.44 fps, 7752.39 kb/s
    encoded 11812 frames, 69.39 fps, 7752.33 kb/s
    encoded 11812 frames, 68.63 fps, 7752.47 kb/s
    Pass 2
    encoded 11812 frames, 17.14 fps, 8002.70 kb/s
    encoded 11812 frames, 17.16 fps, 8002.66 kb/s
    encoded 11812 frames, 17.04 fps, 8002.68 kb/s
    encoded 11812 frames, 17.17 fps, 8002.61 kb/s
    System Details
    Codename Haswell
    Specification Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
    Specification PC3-12800
    Core Stepping
    Technology 22 nm
    Stock frequency 3400 MHz
    Core Speed 800.9 MHz
    Command Rate 2T
    Command Rate 2T
    Memory Type
    Number of threads 4
    Number of threads 4 (max 16)
    Temperature 0 31°C (87°F) [0x1F] (SYSTIN)
    Temperature 0 28°C (82°F) [0xBC2] (TZ00)
    Temperature 1 30°C (85°F) [0xBD6] (TZ01)
  7. RJARRRPCGP
    RJARRRPCGP Newbie
    Q6600 @ 3.2 Ghz (357x9.0):
    x264 HD BENCHMARK 5.0 RESULTS
    Pass 1
    encoded 11812 frames, 26.91 fps, 7752.18 kb/s
    encoded 11812 frames, 26.94 fps, 7752.25 kb/s
    encoded 11812 frames, 27.03 fps, 7752.27 kb/s
    encoded 11812 frames, 26.93 fps, 7752.29 kb/s
    Pass 2
    encoded 11812 frames, 7.49 fps, 8002.84 kb/s
    encoded 11812 frames, 7.48 fps, 8002.82 kb/s
    encoded 11812 frames, 7.47 fps, 8002.84 kb/s
    encoded 11812 frames, 7.50 fps, 8002.83 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 3213.1 MHz
    Memory Frequency 357.0 MHz (1:1)
    Memory Type DDR2
    Channels Single
    Number of threads 4
    Temperature 0 20°C (67°F) [0x14] (SYSTIN)
    Temperature 1 21°C (68°F) [0x29] (CPUTIN)
  8. RJARRRPCGP
    RJARRRPCGP Newbie
    Q6600 @ 3.3 Ghz (367x9.0)
    Pass 1
    encoded 11812 frames, 28.04 fps, 7752.30 kb/s
    encoded 11812 frames, 27.63 fps, 7752.28 kb/s
    encoded 11812 frames, 27.69 fps, 7752.33 kb/s
    encoded 11812 frames, 27.70 fps, 7752.17 kb/s
    Pass 2
    encoded 11812 frames, 7.69 fps, 8002.85 kb/s
    encoded 11812 frames, 7.70 fps, 8002.81 kb/s
    encoded 11812 frames, 7.71 fps, 8002.74 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 3302.9 MHz
    Memory Frequency 367.0 MHz (1:1)
    Memory Type DDR2
    Channels Single
    Number of threads 4
    Temperature 0 27°C (80°F) [0x1B] (SYSTIN)
    Temperature 1 32°C (89°F) [0x40] (CPUTIN)
  9. RJARRRPCGP
    RJARRRPCGP Newbie
    Q6600 @ 3.3 Ghz (367x9.0) with all DIMMs used:
    Pass 1
    encoded 11812 frames, 29.96 fps, 7752.27 kb/s
    encoded 11812 frames, 30.17 fps, 7752.35 kb/s
    encoded 11812 frames, 29.94 fps, 7752.28 kb/s
    encoded 11812 frames, 30.16 fps, 7752.24 kb/s
    Pass 2
    encoded 11812 frames, 7.76 fps, 8002.85 kb/s
    encoded 11812 frames, 7.77 fps, 8002.82 kb/s
    encoded 11812 frames, 7.76 fps, 8002.84 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 3303.0 MHz
    Memory Type DDR2
    Memory Size 5120 MBytes
    Channels Dual, (Symmetric)
    Number of threads 4
    Temperature 1 32°C (88°F) [0x3F] (CPUTIN)
  10. xwin
    xwin Newbie
    Older Phenom X6 1045t
    Pass 1
    encoded 11812 frames, 28.53 fps, 7754.10 kb/s
    encoded 11812 frames, 28.59 fps, 7754.15 kb/s
    encoded 11812 frames, 28.60 fps, 7754.05 kb/s
    encoded 11812 frames, 28.66 fps, 7754.16 kb/s
    Pass 2
    encoded 11812 frames, 9.39 fps, 8002.01 kb/s
    encoded 11812 frames, 9.40 fps, 8002.00 kb/s
    encoded 11812 frames, 9.40 fps, 8002.02 kb/s
    encoded 11812 frames, 9.41 fps, 8001.96 kb/s
    System Details
    Name AMD Phenom II X6 1045T
    Codename Thuban
    Specification AMD Phenom(tm) II X6 1045T Processor
    Specification PC3-12800H
    Core Stepping PH-E0
    Technology 45 nm
    manufacturer Gigabyte Technology Co., Ltd.
    vendor Gigabyte Technology Co., Ltd.
    Stock frequency 2700 MHz
    Core Speed 805.4 MHz
    FID range 4.0x - 16.0x
    Northbridge AMD RD9x0 rev. 02
    Southbridge AMD SB910/950 rev. 40
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 24
    Command Rate 3T
    Command Rate 3T
    Memory Frequency 805.4 MHz (1:4)
    Memory Type DDR3
    Channels Dual, (Unganged)
    Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601)
    Number of threads 6
    Number of threads 6 (max 6)
    L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    Package Socket AM3 (938)
    Package Type 0x1
    Temperature 0 31°C (87°F) [0x1F] (TMPIN0)
    Temperature 1 51°C (123°F) [0x33] (TMPIN1)
    Temperature 2 44°C (111°F) [0x2C] (TMPIN2)
  11. tbo
    tbo Newbie
    Intel Core i3-3120M
    Pass 1
    encoded 11812 frames, 25.42 fps, 7752.54 kb/s
    encoded 11812 frames, 26.72 fps, 7752.59 kb/s
    encoded 11812 frames, 26.62 fps, 7752.36 kb/s
    encoded 11812 frames, 26.60 fps, 7752.46 kb/s
    Pass 2
    encoded 11812 frames, 4.95 fps, 8002.59 kb/s
    encoded 11812 frames, 4.93 fps, 8002.60 kb/s
    encoded 11812 frames, 4.93 fps, 8002.63 kb/s
    encoded 11812 frames, 4.93 fps, 8002.59 kb/s
    System Details
    Name Intel Core i3
    Codename Ivy Bridge
    Specification Intel(R) Core(TM) i3-3120M CPU @ 2.50GHz
    Core Stepping E1
    Technology 22 nm
    Stock frequency 2500 MHz
    Core Speed 1197.3 MHz
    Northbridge Intel Ivy Bridge rev. 09
    Southbridge Intel ID1E57 rev. 04
    Memory Frequency 665.2 MHz (1:5)
    Memory Type DDR3
    Channels Dual
    Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601)
    Number of threads 4
    L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AVX
    Package (platform ID) Socket 988B rPGA (0x4)
  12. begna112
    begna112 Newbie
    3770k and 4790k
    Pass 1
    encoded 5906 frames, 49.40 fps, 7779.52 kb/s
    encoded 5906 frames, 49.89 fps, 7779.52 kb/s
    encoded 5906 frames, 47.83 fps, 7779.52 kb/s
    encoded 5906 frames, 49.78 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 13.53 fps, 8002.16 kb/s
    encoded 5906 frames, 13.49 fps, 8002.16 kb/s
    encoded 5906 frames, 13.39 fps, 8002.16 kb/s
    encoded 5906 frames, 13.51 fps, 8002.16 kb/s
    System Details
    Codename Ivy Bridge
    Specification Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
    Core Stepping E1
    Technology 22 nm
    Core Speed 3703.7 MHz
    Southbridge Intel Z77 rev. 04
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 667.4 MHz (1:5)
    Memory Type DDR3
    Memory Size 16384 MBytes
    Channels Single
    Number of threads 8
    Package (platform ID) Socket 1155 LGA (0x1)
    Temperature 0 37°C (98°F) [0x25] (TMPIN0)
    Temperature 1 37°C (98°F) [0x25] (TMPIN1)
    Temperature 2 50°C (121°F) [0x32] (TMPIN2)
    Pass 1
    encoded 5906 frames, 71.78 fps, 7779.52 kb/s
    encoded 5906 frames, 72.14 fps, 7779.52 kb/s
    encoded 5906 frames, 68.49 fps, 7779.52 kb/s
    encoded 5906 frames, 72.45 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 18.42 fps, 8002.16 kb/s
    encoded 5906 frames, 18.23 fps, 8002.16 kb/s
    encoded 5906 frames, 17.98 fps, 8002.16 kb/s
    encoded 5906 frames, 18.43 fps, 8002.16 kb/s
    System Details
    Codename Haswell
    Specification Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
    Core Stepping
    Technology 22 nm
    Stock frequency 4000 MHz
    Core Speed 800.0 MHz
    Southbridge Intel ID8CC4 rev. 00
    Memory Type
    Memory Size 16326 MBytes
    Number of threads 8
    Also, It would be really nice if you would include a working 64-bit test if you already have avisynth installed. Mine just skips over them, says permissions to deleting all of my filters is denied (thank god) and then doesn't test anything.
  13. Razerlikes
    Razerlikes Newbie
    With Turbo Boost:
    Pass 1
    encoded 5906 frames, 73.25 fps, 7779.52 kb/s
    encoded 5906 frames, 73.18 fps, 7779.52 kb/s
    encoded 5906 frames, 72.73 fps, 7779.52 kb/s
    encoded 5906 frames, 72.25 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 19.09 fps, 8002.16 kb/s
    encoded 5906 frames, 19.14 fps, 8002.16 kb/s
    encoded 5906 frames, 19.13 fps, 8002.16 kb/s
    System Details
    Codename Haswell
    Core Stepping
    Technology 22 nm
    Core Speed 4407.6 MHz
    Memory Type
    Memory Size 8134 MBytes
    Number of threads 8
    No Turbo Boost:
    Pass 1
    encoded 5906 frames, 66.40 fps, 7779.52 kb/s
    encoded 5906 frames, 67.52 fps, 7779.52 kb/s
    encoded 5906 frames, 68.03 fps, 7779.52 kb/s
    encoded 5906 frames, 67.73 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 17.51 fps, 8002.16 kb/s
    encoded 5906 frames, 17.47 fps, 8002.16 kb/s
    encoded 5906 frames, 17.49 fps, 8002.16 kb/s
    encoded 5906 frames, 17.48 fps, 8002.16 kb/s
    System Details
    Codename Haswell
    Core Stepping
    Technology 22 nm
    Core Speed 3997.8 MHz
    Memory Type
    Number of threads 8
  14. tarapada
    tarapada Newbie
    4700MQ results
    Lenovo Z710 with Turbo Boost turned off (via ThrottleStop 6.00)
    Pass 1
    encoded 5906 frames, 49.44 fps, 7779.52 kb/s
    encoded 5906 frames, 50.07 fps, 7779.52 kb/s
    encoded 5906 frames, 49.52 fps, 7779.52 kb/s
    encoded 5906 frames, 49.62 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 12.77 fps, 8002.16 kb/s
    encoded 5906 frames, 12.73 fps, 8002.16 kb/s
    encoded 5906 frames, 12.84 fps, 8002.16 kb/s
    encoded 5906 frames, 12.90 fps, 8002.16 kb/s
    System Details
    Codename Haswell
    Specification Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
    Core Stepping
    Technology 22 nm
    Memory Type
    Memory Size 8118 MBytes
    Number of threads 8
    Package
    (I tried the same benchmark with 16GB RAM and it turned out the same)
    HP ENVY 1966 (4700 MQ Touchscreen)
    Pass 1
    encoded 5906 frames, 51.85 fps, 7779.52 kb/s
    encoded 5906 frames, 50.89 fps, 7779.52 kb/s
    encoded 5906 frames, 50.29 fps, 7779.52 kb/s
    encoded 5906 frames, 52.37 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 12.81 fps, 8002.16 kb/s
    encoded 5906 frames, 12.44 fps, 8002.16 kb/s
    encoded 5906 frames, 12.88 fps, 8002.16 kb/s
    encoded 5906 frames, 12.97 fps, 8002.16 kb/s
    (Lenovo Z710 4700MQ 64-bit results to follow - running right now)
  15. tarapada
    tarapada Newbie
    Lenovo Z710 64-bit 4700MQ
    Pass 1
    encoded 11812 frames, 60.61 fps, 7754.09 kb/s
    encoded 11812 frames, 62.80 fps, 7754.20 kb/s
    encoded 11812 frames, 63.33 fps, 7754.16 kb/s
    encoded 11812 frames, 60.19 fps, 7754.22 kb/s
    Pass 2
    encoded 11812 frames, 12.98 fps, 8002.11 kb/s
    encoded 11812 frames, 12.98 fps, 8002.12 kb/s
    encoded 11812 frames, 12.62 fps, 8002.11 kb/s
    encoded 11812 frames, 12.51 fps, 8002.10 kb/s
    System Details
    Codename Haswell
    Core Stepping
    Technology 22 nm
    Core Speed 3196.7 MHz
    Northbridge Intel Haswell rev. 06
    Southbridge Intel ID8C49 rev. 05
    Memory Type
    Number of threads 8
    Package (platform ID) Socket 947 rPGA (0x4)
    The HP ENVY 1966 would have likely peaked in the 13.5 fps range in the 2nd pass and 64-65fps in the 1st. The HP performed better (please see previous post) and did not require ThrottleStop. All tests with Turbo Boost on.
    For all those mobile users thinking of a new purchase - hope this helps!
    Toshiba P70 (4700MQ 16GB) posted similar numbers to the HP ENVY 1966 but ran very hot with temps above the 90s...
  16. tarapada
    tarapada Newbie
    Q6600 at stock, no throttle, only passive cooling
    Finally, here's my (now) underwhelming Q6600 - 32-bit only:
    Pass 1
    encoded 5906 frames, 20.21 fps, 7775.81 kb/s
    encoded 5906 frames, 20.27 fps, 7775.81 kb/s
    encoded 5906 frames, 20.36 fps, 7775.81 kb/s
    encoded 5906 frames, 20.24 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 5.82 fps, 8004.45 kb/s
    encoded 5906 frames, 5.80 fps, 8004.45 kb/s
    encoded 5906 frames, 5.81 fps, 8004.45 kb/s
    System Details
    Codename Kentsfield
    Core Stepping G0
    Technology 65 nm
    Core Speed 2399.9 MHz
    Northbridge Intel P35/G33/G31 rev. A2
    Southbridge Intel 82801IB (ICH9) rev. 02
    Memory Frequency 400.0 MHz (1:1)
    Memory Type DDR2
    Channels Dual, (Asymmetric)
    Number of threads 4
    Temperature 0 54°C (129°F) [0x36] (SYSTIN)
    Temperature 1 78°C (172°F) [0x9C] (CPUTIN)
    Temperature 2 3°C (36°F) [0x5] (AUXTIN)
    When it gets cold again, I'm hoping to run this in the garage at 3.5GHz - not sure if it will complete!
  17. Engell
    Engell Newbie
    Pass 1
    encoded 11812 frames, 83.83 fps, 7761.48 kb/s
    encoded 11812 frames, 89.17 fps, 7761.32 kb/s
    encoded 11812 frames, 84.08 fps, 7761.23 kb/s
    encoded 11812 frames, 83.91 fps, 7761.20 kb/s
    Pass 2
    encoded 11812 frames, 30.74 fps, 7995.62 kb/s
    encoded 11812 frames, 30.71 fps, 7995.70 kb/s
    encoded 11812 frames, 30.82 fps, 7995.76 kb/s
    encoded 11812 frames, 30.68 fps, 7995.69 kb/s
    System Details
    :wall:
    ProLiant DL380p Gen8
    Dual Intel Xeon E5-2650 @ 2.00 GHZ with Boost enabled
    32GB RAM DDR3 800Mhz
  18. hito
    hito Newbie
    3720QM QC25 QS/ES
    Pass 1
    encoded 5906 frames, 49.42 fps, 7779.52 kb/s
    encoded 5906 frames, 48.17 fps, 7779.52 kb/s
    encoded 5906 frames, 48.06 fps, 7779.52 kb/s
    Pass 2
    encoded 5906 frames, 11.91 fps, 8002.16 kb/s
    encoded 5906 frames, 11.84 fps, 8002.16 kb/s
    encoded 5906 frames, 11.81 fps, 8002.16 kb/s
    encoded 5906 frames, 11.79 fps, 8002.16 kb/s
    System Details
    3720QM QC25 QS/ES @ HP 2570p, Win8.1
    This specific piece cpu is in bad power efficiency, which i am thinking about to replace it with a none-ES cpu.
  19. RJARRRPCGP
    RJARRRPCGP Newbie
    My new FX system! (Built yesterday by RJARRRPCGP)
    FX Vishera 8350 at defaults:
    Gigabyte 970A-D3P motherboard.
    4 GB of DDR 3 SDRAM (Single stick and thus single channel.)
    Pass 1
    encoded 11812 frames, 53.00 fps, 7754.12 kb/s
    encoded 11812 frames, 53.06 fps, 7753.90 kb/s
    encoded 11812 frames, 53.35 fps, 7753.90 kb/s
    encoded 11812 frames, 53.11 fps, 7753.95 kb/s
    Pass 2
    encoded 11812 frames, 14.93 fps, 8002.25 kb/s
    encoded 11812 frames, 14.93 fps, 8002.26 kb/s
    encoded 11812 frames, 14.90 fps, 8002.21 kb/s
    encoded 11812 frames, 14.73 fps, 8002.25 kb/s
    But it still decimated my Q6600 @ 3.3 Ghz.
  20. RJARRRPCGP
    RJARRRPCGP Newbie
    Pass 1
    Pass 2
    System Details
    Name AMD FX
    Codename Zambezi
    Specification AMD FX(tm)-8350 Eight-Core Processor
    Core Stepping OR-C0
    Technology 32 nm
    Core Speed 1406.5 MHz
    Memory Type DDR3
    Number of threads 8
    Number of threads 8 (max 8)
    L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA
    Package Socket AM3+ (942)
    Package Type 0x1
    Temperature 0 23°C (73°F) [0x17] (TMPIN0)
    Temperature 1 49°C (120°F) [0x31] (TMPIN1)
    Temperature 2 41°C (105°F) [0x29] (TMPIN2)
