x264 HD Benchmark 5.0
Discussion in 'Reviews & Articles' started by Adrian Wong, May 25, 2012.
  1. Revrnd
    Revrnd Newbie
    i7-4930K (Shuttle SX79R5)
    x264 HD BENCHMARK 5.0 RESULTS - TURBO MODE
    Results for x264.exe r2200
    x264 Benchmark: 64-bit
    Pass 1
    encoded 11812 frames, 91.24 fps, 7757.11 kb/s
    encoded 11812 frames, 93.31 fps, 7757.11 kb/s
    encoded 11812 frames, 93.55 fps, 7756.86 kb/s
    encoded 11812 frames, 93.72 fps, 7756.80 kb/s
    Pass 2
    encoded 11812 frames, 20.64 fps, 8000.19 kb/s
    encoded 11812 frames, 20.75 fps, 8000.22 kb/s
    encoded 11812 frames, 20.79 fps, 8000.10 kb/s
    System Details
    Name Intel Core i7
    Codename Ivy Bridge-E
    Specification Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
    Core Stepping
    Technology 22 nm
    Stock frequency 3400 MHz
    Core Speed 1199.9 MHz (possibly reported before CPU speed scaled up to 3.6GHz - TURBO)
    Northbridge Intel ID0E00 rev. 04
    Southbridge Intel X79 rev. 06
    Memory Type
    Memory Size 32688 MBytes
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
    Number of processors 1
    Number of threads 12
    Number of threads 12 (max 32)
    L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID) Socket 2011 LGA (0x2)
    Temperature 0 34°C (93°F) [0x22] (TMPIN0)
    Temperature 1 42°C (107°F) [0x2A] (TMPIN1)
    x264 HD BENCHMARK 5.0 RESULTS - NON-TURBO
    Pass 1
    encoded 11812 frames, 86.70 fps, 7756.85 kb/s
    encoded 11812 frames, 87.56 fps, 7756.69 kb/s
    encoded 11812 frames, 87.84 fps, 7757.32 kb/s
    encoded 11812 frames, 88.14 fps, 7756.78 kb/s
    Pass 2
    encoded 11812 frames, 19.52 fps, 8000.11 kb/s
    encoded 11812 frames, 19.47 fps, 8000.23 kb/s
    encoded 11812 frames, 19.58 fps, 8000.07 kb/s
    encoded 11812 frames, 19.54 fps, 8000.21 kb/s
    System Details
    Name Intel Core i7
    Core Stepping
    Technology 22 nm
    Core Speed 1200.0 MHz (Reported through CPU-Z before CPU scaled to 3.4GHz)
    Memory Type
    Temperature 1 40°C (103°F) [0x28] (TMPIN1)
  2. jnmbhj
    jnmbhj Newbie
    Pass 1
    encoded 11812 frames, 87.32 fps, 7753.81 kb/s
    encoded 11812 frames, 83.35 fps, 7754.09 kb/s
    encoded 11812 frames, 86.35 fps, 7754.34 kb/s
    encoded 11812 frames, 85.51 fps, 7753.84 kb/s
    Pass 2
    encoded 11812 frames, 18.99 fps, 8002.28 kb/s
    encoded 11812 frames, 19.17 fps, 8002.28 kb/s
    encoded 11812 frames, 19.24 fps, 8002.18 kb/s
    encoded 11812 frames, 19.14 fps, 8002.30 kb/s
    System Details
    Name Intel Processor
    Codename Haswell
    Specification Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
    Core Stepping
    Technology 22 nm
    Stock frequency 4000 MHz
    Core Speed 4400.6 MHz
    Northbridge Intel ID0C00 rev. 06
    Southbridge Intel ID8CC4 rev. 00
    Memory Type
    Memory Size 16336 MBytes
    Number of threads 8
    Number of threads 8 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA
    Package (platform ID) Socket 1150 LGA (0x1)
    Temperature 0 29°C (84°F) [0x1D] (SYSTIN)
    Temperature 0 28°C (82°F) [0xBC2] (TZ00)
    Temperature 1 30°C (85°F) [0xBD6] (TZ01)
  3. voxmagna
    voxmagna Newbie
    problem with CPU-Z
    Hi, I have this issue that later versions of CPU-Z won't run on my Intel i7-4930K Asus P9X79 mobo winXP. When I execute them I see a long wait and freeze at the splash screen. X264 completes all passes but there's no system info. I will test on the dual boot Win7_64. The CPU temperature is lower than what I see realtime when the cores are at 95%. The core temperature drop very quickly when there is no work. I think the app may be sampling core temp after the work has been done and temperature has reduced?
    I subsituted the packed version of CPU-Z with v1.44.2 which executes fine stand alone. Benchmark report is now complete as follows. I haven't looked further into the CPU-Z issue, but I have had problems with some other apps not working correctly with this 6 core 12 thread cpu.
    Results are about what I expected, although the cpu cores only max out to about 94% whereas Prime95 can run at 100%
    x264 Benchmark: 32-bit
    Pass 1
    encoded 5906 frames, 88.23 fps, 7787.14 kb/s
    encoded 5906 frames, 87.44 fps, 7787.14 kb/s
    encoded 5906 frames, 87.74 fps, 7787.14 kb/s
    encoded 5906 frames, 89.13 fps, 7787.14 kb/s
    Pass 2
    encoded 5906 frames, 24.39 fps, 8001.61 kb/s
    encoded 5906 frames, 24.38 fps, 8001.61 kb/s
    encoded 5906 frames, 24.25 fps, 8001.61 kb/s
    encoded 5906 frames, 24.42 fps, 8001.61 kb/s
    System Details
    product System Product Name
    Codename
    Core Stepping
    Core Speed 4400.0 MHz
    Southbridge Intel ID1D41 rev. 06
    Memory Type
    Memory Size 3268 MBytes
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    Voltage sensor 0 1.43 Volts [0xB3] (CPU VCORE)
    Package
    Temperature sensor 0 28°C (82°F) [0x1C] (SYSTIN)
    Temperature sensor 1 34°C (93°F) [0x44] (CPUTIN)
    Temperature sensor 2 53°C (126°F) [0x69] (AUXTIN)
    Temperature sensor 0 33°C (91°F) [0x21] (GPU Core)
  4. Adrian Wong
    My apologies. It's been a while since we updated the benchmark. :(
  5. Pridebowl
    Pridebowl Newbie
    Pass 1
    encoded 5906 frames, 53.93 fps, 7779.03 kb/s
    encoded 5906 frames, 53.99 fps, 7779.03 kb/s
    encoded 5906 frames, 53.94 fps, 7779.03 kb/s
    encoded 5906 frames, 54.10 fps, 7779.03 kb/s
    Pass 2
    encoded 5906 frames, 20.81 fps, 8003.21 kb/s
    encoded 5906 frames, 20.90 fps, 8003.21 kb/s
    encoded 5906 frames, 20.85 fps, 8003.21 kb/s
    System Details
    Name Intel Core i7 3960X
    Codename Sandy Bridge-E
    Specification Intel(R) Core(TM) i7-3960X CPU @ 3.30GHz
    Specification PC3-17100
    Core Stepping C2
    Technology 32 nm
    Stock frequency 3300 MHz
    Core Speed 4800.0 MHz
    Northbridge Intel Sandy Bridge-E rev. 07
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 11
    RAS# Precharge (tRP) 11
    Cycle Time (tRAS) 31
    Command Rate (CR) 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 1066.7 MHz (1:16)
    Memory Type DDR3
    Memory Size 65476 MBytes
    Channels Quad
    Windows Version Microsoft Windows 7 (6.1) 64-bit Service Pack 1 (Build 7601)
    Number of threads 6
    Number of threads 6 (max 32)
    Temperature 0 32°C (89°F) [0x20] (SYSTIN)
    Temperature 1 124°C (254°F) [0xF7] (CPUTIN)
    Temperature 2 63°C (144°F) [0x183] (AUXTIN)
    Temperature 3 40°C (103°F) [0x28] (TMPIN3)
  6. SgtDuster
    SgtDuster Newbie
    Pass 1
    encoded 11812 frames, 36.80 fps, 7754.05 kb/s
    encoded 11812 frames, 37.40 fps, 7754.31 kb/s
    encoded 11812 frames, 37.61 fps, 7754.31 kb/s
    encoded 11812 frames, 37.88 fps, 7754.28 kb/s
    Pass 2
    encoded 11812 frames, 11.37 fps, 8002.22 kb/s
    encoded 11812 frames, 11.38 fps, 8002.10 kb/s
    encoded 11812 frames, 11.42 fps, 8002.08 kb/s
    encoded 11812 frames, 11.47 fps, 8002.07 kb/s
    System Details
    Name Intel Xeon E5420
    Codename Harpertown
    Codename Harpertown
    Specification Intel(R) Xeon(R) CPU E5420 @ 2.50GHz
    Core Stepping E0
    Core Stepping E0
    Technology 45 nm
    Technology 45 nm
    Stock frequency 2500 MHz
    Core Speed 1995.0 MHz
    Core Speed 2493.7 MHz
    FID range 6.0x - 7.5x
    Northbridge Intel 5000X rev. 31
    Southbridge Intel 6321ESB rev. 09
    Memory Frequency 332.5 MHz (1:1)
    Memory Type FB-DDR2
    Memory Size 16384 MBytes
    Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601)
    Number of processors 2
    Number of threads 8
    Number of threads 4 (max 4)
    L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
    Package (platform ID) Socket 771 LGA (0x6)
    Temperature 0 72°C (161°F) [0x90] (core)
    Temperature 0 76°C (167°F) [0x97] (core)
    Temperature 0 84°C (183°F) [0xA8] (core)
    Temperature 0 81°C (176°F) [0xA1] (core)
    Temperature 0 64°C (147°F) [0x80] (core)
    Temperature 0 83°C (180°F) [0xA5] (core)
    Temperature 0 69°C (156°F) [0x8A] (core)
  7. rvborgh
    rvborgh Newbie
    Just for giggles i ran this on my Quad Opty.
    for some reason after it completed the system details were blank (perhaps its not used to a PC with this many cores?):
    so the details are:
    4 x Opteron 61xx "Magny Cours" (ES - multiplier unlocked) = 48 K10 cores @ 3.0 GHz - multiplier was 15x
    Motherboard: SuperMicro H8QGi-f quad opteron motherboard
    Ram = 32GB = 16x2GB G.Skill DDR3 1600 running at 9, 9, 9, 24, 33, 1T (DDR3-1333)
    OS = Windows Server 2008R2
    Also it doesn't seem to fully saturate all 48 cores in pass 2... averages around 85% or so... with large swings.
    Pass 1
    encoded 11812 frames, 69.99 fps, 7765.62 kb/s
    encoded 11812 frames, 68.82 fps, 7765.52 kb/s
    encoded 11812 frames, 67.90 fps, 7765.55 kb/s
    encoded 11812 frames, 67.69 fps, 7765.34 kb/s
    Pass 2
    encoded 11812 frames, 58.14 fps, 7989.19 kb/s
    encoded 11812 frames, 58.31 fps, 7989.11 kb/s
    encoded 11812 frames, 58.11 fps, 7989.14 kb/s
    encoded 11812 frames, 57.96 fps, 7989.23 kb/s
    System Details
  8. hirorir
    hirorir Newbie
    This was done with an i7-5960X clocked at 4326.6 MHz (4.3 GHz) under closed loop liquid cooling. The OC seems to be a significant improvement over the stock numbers listed over at us.hardware.info
    I have two separate benches done below, a 64-bit one and a 32-bit one. 64-bit one seems to be about 25% better on the first pass, and about 6% better in the second pass.
    Pass 1
    encoded 11812 frames, 152.95 fps, 7757.52 kb/s
    encoded 11812 frames, 153.25 fps, 7757.73 kb/s
    encoded 11812 frames, 153.14 fps, 7757.46 kb/s
    encoded 11812 frames, 152.14 fps, 7757.58 kb/s
    Pass 2
    encoded 11812 frames, 34.37 fps, 7999.72 kb/s
    encoded 11812 frames, 34.38 fps, 7999.68 kb/s
    encoded 11812 frames, 34.31 fps, 7999.73 kb/s
    encoded 11812 frames, 34.44 fps, 7999.74 kb/s
    System Details
    Codename
    Specification Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
    Core Stepping
    Core Speed 3820.1 MHz
    Northbridge Intel ID2F00 rev. 02
    Southbridge Intel ID8D47 rev. 05
    Memory Type
    Memory Size 32670 MBytes
    Windows Version Microsoft Windows 8 (6.2) 64-bit (Build 9200)
    Number of threads 16
    Number of threads 16 (max 16)
    L2 cache 8 x 256 KBytes, 8-way set associative, 64-byte line size
    Package
    Temperature 0 40°C (103°F) [0x28] (SYSTIN)
    Temperature 1 47°C (116°F) [0x5E] (CPUTIN)
    Pass 1
    encoded 5906 frames, 121.57 fps, 7793.71 kb/s
    encoded 5906 frames, 122.17 fps, 7793.71 kb/s
    encoded 5906 frames, 122.22 fps, 7793.71 kb/s
    encoded 5906 frames, 122.03 fps, 7793.71 kb/s
    Pass 2
    encoded 5906 frames, 33.73 fps, 7999.72 kb/s
    encoded 5906 frames, 33.69 fps, 7999.72 kb/s
    encoded 5906 frames, 33.72 fps, 7999.72 kb/s
    encoded 5906 frames, 33.70 fps, 7999.72 kb/s
    System Details
    Codename
    Core Stepping
    Core Speed 3819.5 MHz
    Memory Type
    Package
    Temperature 1 57°C (133°F) [0x71] (CPUTIN)
  9. RJARRRPCGP
    RJARRRPCGP Newbie
    Motherboard was changed to a Sabertooth 990 FX R 2.0 in summer, 2015:
    Results for Halloween of 2015:
    Pass 1
    encoded 11812 frames, 54.55 fps, 7754.15 kb/s
    encoded 11812 frames, 54.57 fps, 7754.26 kb/s
    encoded 11812 frames, 54.59 fps, 7754.30 kb/s
    encoded 11812 frames, 54.88 fps, 7754.18 kb/s
    Pass 2
    encoded 11812 frames, 14.78 fps, 8002.19 kb/s
    encoded 11812 frames, 14.77 fps, 8002.11 kb/s
    encoded 11812 frames, 14.78 fps, 8002.09 kb/s
    encoded 11812 frames, 14.80 fps, 8002.20 kb/s
  10. CZauX
    CZauX Newbie
    Dell Inspiron 15-7559 Laptop
    Pass 1
    encoded 11812 frames, 47.29 fps, 7752.43 kb/s
    encoded 11812 frames, 47.21 fps, 7752.59 kb/s
    encoded 11812 frames, 47.06 fps, 7752.53 kb/s
    encoded 11812 frames, 47.34 fps, 7752.45 kb/s
    Pass 2
    encoded 11812 frames, 11.44 fps, 8002.57 kb/s
    encoded 11812 frames, 11.41 fps, 8002.59 kb/s
    encoded 11812 frames, 11.41 fps, 8002.56 kb/s
    encoded 11812 frames, 11.39 fps, 8002.58 kb/s
    System Details
    Codename
    Specification Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
    Core Stepping
    Core Speed 2309.3 MHz
    Northbridge Intel ID1910 rev. 07
    Southbridge Intel IDA14E rev. 31
    Memory Type
    Memory Size 8066 MBytes
    Number of threads 4
    Number of threads 4 (max 16)
    L2 cache 4 x 256 KBytes, 4-way set associative, 64-byte line size
    Package
  11. Guest201511
    Guest201511 Newbie
    Microsoft Surface Pro 4 i5 6300U
    Pass 1
    encoded 5906 frames, 31.25 fps, 7775.81 kb/s
    encoded 5906 frames, 28.96 fps, 7775.81 kb/s
    encoded 5906 frames, 28.90 fps, 7775.81 kb/s
    encoded 5906 frames, 28.89 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 6.86 fps, 8004.45 kb/s
    encoded 5906 frames, 6.73 fps, 8004.45 kb/s
    encoded 5906 frames, 6.66 fps, 8004.45 kb/s
    encoded 5906 frames, 6.71 fps, 8004.45 kb/s
    System Details
    Codename
    Specification Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz
    Core Stepping
    Core Speed 2502.8 MHz
    Northbridge Intel ID1904 rev. 08
    Southbridge Intel ID9D48 rev. 21
    Memory Size 8116 MBytes
    Windows Version Microsoft Windows 10 64-bit
    Number of threads 4
    L2 cache 2 x 256 KBytes, 4-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA Package
    per Quicksynch in Handbrake very much better
  12. Miazda
    Miazda Newbie
    I'm having some issues getting the benchmark to run. I'm on Windows 10 64-bit and I have installed AviSynth 2.5.8 and extracted the necessary .dll files (avisynth.dll and devil.dll) into the System32 directory. The first (and perhaps most concerning) problem is that the security checksums you've listed do not match the downloaded file using the link on your website. Further, when I attempt to extract the files using WinRAR, it tells me that the files are corrupted. When attempting a work around using 7zip, I can extract without an error message, but there is no Run Benchmark.vbs file. When running the bench_script.bat file using Administrator command prompt, I get this:
    The system cannot find the path specified.
    The system cannot find the file specified.
    e.g. the CPU multiplier and FSB (like 333x9 for example):
    Once I input a value for the multiplier and FSB, the program runs through in a matter of a few milliseconds. NVIDIA Shadowplay recording at 60 fps is the only reason I have these frames:
    So, what am I doing wrong? Or is there indeed something wrong with the file?
    Thanks
  13. RJARRRPCGP
    RJARRRPCGP Newbie
  14. RJARRRPCGP
    RJARRRPCGP Newbie
    Here's mine again, with 16 GB of G.Skill RipJaws @ DDR 1333:
    Pass 1
    encoded 11812 frames, 58.41 fps, 7754.30 kb/s
    encoded 11812 frames, 58.63 fps, 7754.23 kb/s
    encoded 11812 frames, 59.08 fps, 7754.27 kb/s
    encoded 11812 frames, 59.07 fps, 7754.17 kb/s
    Pass 2
    encoded 11812 frames, 14.80 fps, 8002.09 kb/s
    encoded 11812 frames, 14.83 fps, 8002.06 kb/s
    encoded 11812 frames, 14.88 fps, 8002.10 kb/s
    encoded 11812 frames, 14.89 fps, 8002.12 kb/s
  15. RJARRRPCGP
    RJARRRPCGP Newbie
    FX8350 OC'ed to 4.4 Ghz:
    Pass 1
    encoded 11812 frames, 61.80 fps, 7754.21 kb/s
    encoded 11812 frames, 62.41 fps, 7754.15 kb/s
    encoded 11812 frames, 62.45 fps, 7754.21 kb/s
    encoded 11812 frames, 62.09 fps, 7754.13 kb/s
    Pass 2
    encoded 11812 frames, 16.00 fps, 8002.09 kb/s
    encoded 11812 frames, 16.00 fps, 8002.20 kb/s
    encoded 11812 frames, 16.06 fps, 8002.09 kb/s
  16. shadowofjazz
    shadowofjazz Newbie
    i7-4790K OC'ed to 4.4 Ghz:
    Pass 1
    encoded 11812 frames, 88.32 fps, 7754.32 kb/s
    encoded 11812 frames, 83.72 fps, 7754.16 kb/s
    encoded 11812 frames, 85.54 fps, 7754.28 kb/s
    encoded 11812 frames, 88.03 fps, 7754.29 kb/s
    Pass 2
    encoded 11812 frames, 17.36 fps, 8002.09 kb/s
    encoded 11812 frames, 17.48 fps, 8002.11 kb/s
    encoded 11812 frames, 17.78 fps, 8002.11 kb/s
    encoded 11812 frames, 17.92 fps, 8002.17 kb/s
    System Details
    Name Intel Core i7 4790K
    Codename Haswell
    Core Stepping C0
    Core Speed 4389.5 MHz
    Northbridge Intel Haswell rev. 06
    Southbridge Intel H81 rev. C2
    Memory Frequency 798.1 MHz (1:6)
    Memory Type DDR3
    Memory Size 16 GBytes
    Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 10586)
    Number of threads 8
    Instructions setsMMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
    Temperature 1 40°C (104°F) [0x3C] (Package)
    Temperature 0 39°C (102°F) [0x3D] (Core #0)
    Temperature 0 39°C (102°F) [0x27] (TMPIN0)
    Temperature 2 33°C (91°F) [0x21] (TMPIN2)
    Temperature 0 35°C (95°F) [0x23] (TMPIN0)
  17. laychi
    laychi Newbie
    Hi guys.
    I have a problem under win10.
    I have installed avisynth but the program is not running and open the link of avisynth.
  18. tonyhsie
    tonyhsie Newbie
    Nice to see the thread is still alive thru serveral years :clap:
  19. zelante
    zelante Newbie
    Pass 1
    encoded 11812 frames, 71.04 fps, 7754.40 kb/s
    encoded 11812 frames, 70.92 fps, 7754.22 kb/s
    encoded 11812 frames, 71.03 fps, 7754.38 kb/s
    encoded 11812 frames, 70.74 fps, 7754.28 kb/s
    Pass 2
    encoded 11812 frames, 14.77 fps, 8002.07 kb/s
    encoded 11812 frames, 14.79 fps, 8002.10 kb/s
    encoded 11812 frames, 14.74 fps, 8002.12 kb/s
    encoded 11812 frames, 14.80 fps, 8002.07 kb/s
    System Details
    Name Intel Core i7 4700MQ
    Name Samsung SSD 850 PRO 256GB
    Name HDD 1
    Name TS128GMTS400
    Name NVIDIA GeForce GT 755M
    Codename Haswell
    Specification Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
    Core Stepping C0
    Technology 22 nm
    Stock frequency 2400 MHz
    Core Speed 3395.6 MHz
    Southbridge Intel HM86 rev. C2
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 27
    Command Rate (CR) 1T
    Memory Frequency 799.0 MHz (1:6)
    Memory Type DDR3
    Channels Dual
    Windows Version Microsoft Windows 10 (10.0) Home Single Language 64-bit (Build 14393)
    Number of threads 8
    Number of threads 8 (max 8)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
    Package (platform ID) Socket 947 rPGA (0x4)
    Temperature 4 48 degC (118 degF) (Package)
    Power 0 16.86 W (Package)
    Temperature 0 47 degC (116 degF) (Core #0)
    Temperature 1 45 degC (113 degF) (Core #1)
    Temperature 2 48 degC (118 degF) (Core #2)
    Temperature 3 45 degC (113 degF) (Core #3)
    Temperature 0 38 degC (100 degF) [0x26] (TMPIN0)
    Temperature 0 28 degC (82 degF) [0x1C] (TMPIN0)
