AMD Phenom II X4 960T ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 23.26 fps, 7776.34 kb/s encoded 5906 frames, 23.36 fps, 7776.34 kb/s encoded 5906 frames, 23.36 fps, 7776.34 kb/s encoded 5906 frames, 23.36 fps, 7776.34 kb/s Pass 2 ------ encoded 5906 frames, 7.27 fps, 8004.31 kb/s encoded 5906 frames, 7.27 fps, 8004.31 kb/s encoded 5906 frames, 7.28 fps, 8004.31 kb/s encoded 5906 frames, 7.29 fps, 8004.31 kb/s System Details -------------- Name AMD Phenom II X4 960T Codename Thuban Specification AMD Phenom(tm) II X4 960T Processor Specification PC3-17100 Specification PC3-17100 Core Stepping PH-E0 Technology 45 nm Stock frequency 3000 MHz Core Speed 3010.0 MHz Northbridge AMD RD9x0 rev. 02 Southbridge AMD SB910/950 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 668.9 MHz (3:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 40°C (103°F) [0x28] (CPU) Temperature 1 27°C (80°F) [0x1B] (Mainboard) Temperature 0 28°C (82°F) [0xC1C0] (core) Temperature 0 26°C (78°F) [0xC19C] (core)
AMD Phenom II X4 960T @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 26.95 fps, 7752.84 kb/s encoded 11812 frames, 27.80 fps, 7752.83 kb/s encoded 11812 frames, 27.92 fps, 7752.96 kb/s encoded 11812 frames, 27.84 fps, 7752.99 kb/s Pass 2 ------ encoded 11812 frames, 6.98 fps, 8002.58 kb/s encoded 11812 frames, 6.95 fps, 8002.59 kb/s encoded 11812 frames, 6.97 fps, 8002.59 kb/s encoded 11812 frames, 6.98 fps, 8002.60 kb/s System Details -------------- Name AMD Phenom II X4 960T Codename Thuban Specification AMD Phenom(tm) II X4 960T Processor Specification PC3-17100 Specification PC3-17100 Core Stepping PH-E0 Technology 45 nm Stock frequency 3000 MHz Core Speed 3009.9 MHz Northbridge AMD RD9x0 rev. 02 Southbridge AMD SB910/950 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 668.9 MHz (3:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 41°C (105°F) [0x29] (CPU) Temperature 1 28°C (82°F) [0x1C] (Mainboard) Temperature 0 29°C (84°F) [0xC1D0] (core) Temperature 0 27°C (80°F) [0xC1AC] (core)
AMD FX-8150 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 39.42 fps, 7779.53 kb/s encoded 5906 frames, 39.64 fps, 7779.53 kb/s encoded 5906 frames, 39.20 fps, 7779.53 kb/s encoded 5906 frames, 39.54 fps, 7779.53 kb/s Pass 2 ------ encoded 5906 frames, 12.92 fps, 8002.11 kb/s encoded 5906 frames, 12.90 fps, 8002.11 kb/s encoded 5906 frames, 12.94 fps, 8002.11 kb/s encoded 5906 frames, 12.93 fps, 8002.11 kb/s System Details -------------- Name AMD FX-8150 Codename Zambezi Specification AMD FX(tm)-8150 Eight-Core Processor Specification PC3-17100 Specification PC3-17100 Core Stepping OR-B2 Technology 32 nm Stock frequency 3200 MHz Core Speed 3660.2 MHz Northbridge AMD RD9x0 rev. 02 Southbridge AMD SB910/950 rev. 40 CAS# latency (CL) 10.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 10 Cycle Time (tRAS) 27 Command Rate 2T Command Rate 2T Memory Frequency 1067.6 MHz (3:14) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 64°C (147°F) [0x40] (CPU) Temperature 1 34°C (93°F) [0x22] (Mainboard) Temperature 0 36°C (97°F) [0xC244] (core) Temperature 0 33°C (90°F) [0xC20C] (core)
AMD FX-8150 @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 49.59 fps, 7753.95 kb/s encoded 11812 frames, 50.33 fps, 7754.30 kb/s encoded 11812 frames, 49.67 fps, 7754.17 kb/s encoded 11812 frames, 49.83 fps, 7754.20 kb/s Pass 2 ------ encoded 11812 frames, 12.99 fps, 8002.22 kb/s encoded 11812 frames, 13.00 fps, 8002.18 kb/s encoded 11812 frames, 13.01 fps, 8002.12 kb/s encoded 11812 frames, 12.98 fps, 8002.17 kb/s System Details -------------- Name AMD FX-8150 Codename Zambezi Specification AMD FX(tm)-8150 Eight-Core Processor Specification PC3-17100 Specification PC3-17100 Core Stepping OR-B2 Technology 32 nm Stock frequency 3200 MHz Core Speed 3660.3 MHz Northbridge AMD RD9x0 rev. 02 Southbridge AMD SB910/950 rev. 40 CAS# latency (CL) 10.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 10 Cycle Time (tRAS) 27 Command Rate 2T Command Rate 2T Memory Frequency 1067.6 MHz (3:14) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 62°C (143°F) [0x3E] (CPU) Temperature 1 33°C (91°F) [0x21] (Mainboard) Temperature 0 35°C (94°F) [0xC230] (core) Temperature 0 32°C (88°F) [0xC1F8] (core)
AMD FX-8150 @ 4GHz ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 42.80 fps, 7779.53 kb/s encoded 5906 frames, 42.83 fps, 7779.53 kb/s encoded 5906 frames, 43.03 fps, 7779.53 kb/s encoded 5906 frames, 41.85 fps, 7779.53 kb/s Pass 2 ------ encoded 5906 frames, 14.36 fps, 8002.11 kb/s encoded 5906 frames, 14.40 fps, 8002.11 kb/s encoded 5906 frames, 14.39 fps, 8002.11 kb/s encoded 5906 frames, 14.36 fps, 8002.11 kb/s System Details -------------- Name AMD FX-8150 Codename Zambezi Specification AMD FX(tm)-8150 Eight-Core Processor Specification PC3-17100 Specification PC3-17100 Core Stepping OR-B2 Technology 32 nm Stock frequency 4000 MHz Core Speed 4013.3 MHz Northbridge AMD RD9x0 rev. 02 Southbridge AMD SB910/950 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate 2T Command Rate 2T Memory Frequency 802.7 MHz (1:4) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 64°C (147°F) [0x40] (CPU) Temperature 1 31°C (87°F) [0x1F] (Mainboard) Temperature 0 32°C (89°F) [0xC200] (core) Temperature 0 30°C (86°F) [0xC1E4] (core)
AMD FX-8150 @ 4GHz @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 53.64 fps, 7754.19 kb/s encoded 11812 frames, 54.14 fps, 7754.14 kb/s encoded 11812 frames, 53.69 fps, 7754.09 kb/s encoded 11812 frames, 54.06 fps, 7754.30 kb/s Pass 2 ------ encoded 11812 frames, 14.22 fps, 8002.22 kb/s encoded 11812 frames, 14.22 fps, 8002.11 kb/s encoded 11812 frames, 14.22 fps, 8002.20 kb/s encoded 11812 frames, 14.21 fps, 8002.17 kb/s System Details -------------- Name AMD FX-8150 Codename Zambezi Specification AMD FX(tm)-8150 Eight-Core Processor Specification PC3-17100 Specification PC3-17100 Core Stepping OR-B2 Technology 32 nm Stock frequency 4000 MHz Core Speed 4013.3 MHz Northbridge AMD RD9x0 rev. 02 Southbridge AMD SB910/950 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate 2T Command Rate 2T Memory Frequency 802.7 MHz (1:4) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 66°C (150°F) [0x42] (CPU) Temperature 1 31°C (87°F) [0x1F] (Mainboard) Temperature 0 33°C (91°F) [0xC210] (core) Temperature 0 32°C (88°F) [0xC1F8] (core)
Intel Core i5 750 @ 2.66 GHz Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 32.93 fps, 7752.50 kb/s encoded 11812 frames, 32.93 fps, 7752.27 kb/s encoded 11812 frames, 32.91 fps, 7752.50 kb/s encoded 11812 frames, 32.92 fps, 7752.41 kb/s Pass 2 ------ encoded 11812 frames, 7.44 fps, 8002.73 kb/s encoded 11812 frames, 7.43 fps, 8002.69 kb/s encoded 11812 frames, 7.43 fps, 8002.63 kb/s encoded 11812 frames, 7.44 fps, 8002.70 kb/s System Details -------------- Name Intel Core i7 Codename Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Core Stepping B1 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2666 MHz Memory Type Memory Size 8184 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package
Intel Core i5 750 @ 3.6 GHz Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 43.79 fps, 7752.53 kb/s encoded 11812 frames, 43.76 fps, 7752.40 kb/s encoded 11812 frames, 43.88 fps, 7752.42 kb/s encoded 11812 frames, 43.73 fps, 7752.46 kb/s Pass 2 ------ encoded 11812 frames, 10.01 fps, 8002.69 kb/s encoded 11812 frames, 10.02 fps, 8002.71 kb/s encoded 11812 frames, 10.01 fps, 8002.68 kb/s encoded 11812 frames, 10.03 fps, 8002.70 kb/s System Details -------------- Name Intel Core i7 Codename Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Core Stepping B1 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2666 MHz Memory Type Memory Size 16376 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package
Intel Core i5 750 @ 4.0 GHz Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 43.43 fps, 7752.24 kb/s encoded 11812 frames, 46.20 fps, 7752.43 kb/s encoded 11812 frames, 46.12 fps, 7752.51 kb/s encoded 11812 frames, 46.20 fps, 7752.40 kb/s Pass 2 ------ encoded 11812 frames, 11.07 fps, 8002.75 kb/s encoded 11812 frames, 11.06 fps, 8002.65 kb/s encoded 11812 frames, 11.08 fps, 8002.67 kb/s encoded 11812 frames, 11.09 fps, 8002.70 kb/s System Details -------------- Not sure why the system details was cut off. Perhaps unstable overclock? Although I prime'd it overnight. Also I should mention that I did all of these tests in safe mode, to ensure that nothing else would rob cpu cycles.
AMD Phenom X4 9750 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 17.15 fps, 7776.34 kb/s encoded 5906 frames, 17.27 fps, 7776.34 kb/s encoded 5906 frames, 17.05 fps, 7776.34 kb/s encoded 5906 frames, 16.99 fps, 7776.34 kb/s Pass 2 ------ encoded 5906 frames, 5.49 fps, 8004.31 kb/s encoded 5906 frames, 5.51 fps, 8004.31 kb/s encoded 5906 frames, 5.51 fps, 8004.31 kb/s encoded 5906 frames, 5.51 fps, 8004.31 kb/s System Details -------------- Name AMD Phenom X4 9750 product System Product Name Codename Agena Specification AMD Phenom(tm) 9750 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Stock frequency 2400 MHz Core Speed 2399.9 MHz FID range 6.0x - 12.0x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 57°C (134°F) [0x39] (TMPIN0) Temperature 1 41°C (105°F) [0x29] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
AMD Phenom X4 9750 @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 20.64 fps, 7752.91 kb/s encoded 11812 frames, 20.48 fps, 7752.95 kb/s encoded 11812 frames, 20.56 fps, 7752.99 kb/s encoded 11812 frames, 20.40 fps, 7752.83 kb/s Pass 2 ------ encoded 11812 frames, 5.29 fps, 8002.58 kb/s encoded 11812 frames, 5.29 fps, 8002.55 kb/s encoded 11812 frames, 5.29 fps, 8002.53 kb/s encoded 11812 frames, 5.29 fps, 8002.55 kb/s System Details -------------- Name AMD Phenom X4 9750 product System Product Name Codename Agena Specification AMD Phenom(tm) 9750 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Stock frequency 2400 MHz Core Speed 2399.3 MHz FID range 6.0x - 12.0x Northbridge ATI RS690/RS690M rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 399.9 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 57°C (134°F) [0x39] (TMPIN0) Temperature 1 41°C (105°F) [0x29] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
phenom x6 CPU speed was 3.6ghz Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 33.56 fps, 7753.80 kb/s encoded 11812 frames, 33.59 fps, 7753.75 kb/s encoded 11812 frames, 33.56 fps, 7753.87 kb/s encoded 11812 frames, 33.65 fps, 7753.90 kb/s Pass 2 ------ encoded 11812 frames, 12.34 fps, 8002.16 kb/s encoded 11812 frames, 12.32 fps, 8002.20 kb/s encoded 11812 frames, 12.34 fps, 8002.12 kb/s encoded 11812 frames, 12.34 fps, 8002.13 kb/s System Details -------------- Name AMD Phenom II X6 1055T Codename Thuban Specification AMD Phenom(tm) II X6 1055T Processor Specification PC3-12800 Specification PC3-12800 Core Stepping PH-E0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2800 MHz Core Speed 1032.0 MHz FID range 4.0x - 16.5x Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 860.0 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 36°C (96°F) [0x24] (TMPIN0) Temperature 1 36°C (96°F) [0x24] (TMPIN1) Temperature 2 49°C (120°F) [0x31] (TMPIN2)
Intel Core i7-3770 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 50.03 fps, 7779.52 kb/s encoded 5906 frames, 49.97 fps, 7779.52 kb/s encoded 5906 frames, 49.20 fps, 7779.52 kb/s encoded 5906 frames, 49.50 fps, 7779.52 kb/s Pass 2 ------ encoded 5906 frames, 13.28 fps, 8002.16 kb/s encoded 5906 frames, 13.20 fps, 8002.16 kb/s encoded 5906 frames, 13.13 fps, 8002.16 kb/s encoded 5906 frames, 13.13 fps, 8002.16 kb/s System Details -------------- Name Intel Core i3/i5/i7 Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz Core Stepping E1 Technology 22 nm Stock frequency 3400 MHz Memory Type Memory Size 4038 MBytes Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package
phenom x6 Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 35.23 fps, 7753.89 kb/s encoded 11812 frames, 35.24 fps, 7754.07 kb/s encoded 11812 frames, 35.31 fps, 7753.90 kb/s encoded 11812 frames, 35.33 fps, 7753.87 kb/s Pass 2 ------ encoded 11812 frames, 13.25 fps, 8002.12 kb/s encoded 11812 frames, 13.23 fps, 8002.13 kb/s encoded 11812 frames, 13.22 fps, 8002.10 kb/s encoded 11812 frames, 13.24 fps, 8002.18 kb/s System Details -------------- Name AMD Phenom II X6 1055T Codename Thuban Specification AMD Phenom(tm) II X6 1055T Processor Specification PC3-12800 Specification PC3-12800 Core Stepping PH-E0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2800 MHz Core Speed 1116.0 MHz FID range 4.0x - 16.5x Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 744.0 MHz (3:8) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 34°C (93°F) [0x22] (TMPIN0) Temperature 1 39°C (102°F) [0x27] (TMPIN1) Temperature 2 53°C (127°F) [0x35] (TMPIN2) Thank you and good job for keeping up with 3770 in 2nd pass.
Intel Core i7-3770 @ Turbo 3.7GHz ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 53.65 fps, 7779.52 kb/s encoded 5906 frames, 54.53 fps, 7779.52 kb/s encoded 5906 frames, 52.18 fps, 7779.52 kb/s encoded 5906 frames, 52.48 fps, 7779.52 kb/s Pass 2 ------ encoded 5906 frames, 14.38 fps, 8002.16 kb/s encoded 5906 frames, 14.30 fps, 8002.16 kb/s encoded 5906 frames, 14.20 fps, 8002.16 kb/s encoded 5906 frames, 14.19 fps, 8002.16 kb/s System Details -------------- Name Intel Core i7 3770 Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz Core Stepping E1 Technology 22 nm Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Stock frequency 3400 MHz Core Speed 1597.8 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel ID1E48 rev. 04 CAS# latency (CL) 11.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 11 Cycle Time (tRAS) 28 Command Rate (CR) 1T Memory Frequency 799.0 MHz (1:6) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 57°C (134°F) [0x39] (TMPIN0) Temperature 1 49°C (120°F) [0x31] (TMPIN1) Temperature 2 24°C (75°F) [0x18] (TMPIN2) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Intel Core i7-3770 @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 59.44 fps, 7754.24 kb/s encoded 11812 frames, 58.23 fps, 7754.20 kb/s encoded 11812 frames, 58.45 fps, 7754.17 kb/s encoded 11812 frames, 58.53 fps, 7754.26 kb/s Pass 2 ------ encoded 11812 frames, 13.15 fps, 8002.05 kb/s encoded 11812 frames, 13.02 fps, 8002.16 kb/s encoded 11812 frames, 13.01 fps, 8002.10 kb/s encoded 11812 frames, 13.02 fps, 8002.16 kb/s System Details -------------- Name Intel Core i7 3770 Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz Core Stepping E1 Technology 22 nm Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Stock frequency 3400 MHz Core Speed 3394.7 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel ID1E48 rev. 04 CAS# latency (CL) 11.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 11 Cycle Time (tRAS) 28 Command Rate (CR) 1T Memory Frequency 798.8 MHz (1:6) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 59°C (138°F) [0x3B] (TMPIN0) Temperature 1 49°C (120°F) [0x31] (TMPIN1) Temperature 2 24°C (75°F) [0x18] (TMPIN2) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Intel Core i7-3770 @ Turbo 3.7GHz @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 63.24 fps, 7754.20 kb/s encoded 11812 frames, 61.74 fps, 7754.17 kb/s encoded 11812 frames, 62.17 fps, 7754.28 kb/s encoded 11812 frames, 61.44 fps, 7754.28 kb/s Pass 2 ------ encoded 11812 frames, 14.22 fps, 8002.19 kb/s encoded 11812 frames, 14.07 fps, 8002.10 kb/s encoded 11812 frames, 14.07 fps, 8002.09 kb/s encoded 11812 frames, 14.06 fps, 8002.11 kb/s System Details -------------- Name Intel Core i7 3770 Codename Ivy Bridge Specification Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz Core Stepping E1 Technology 22 nm Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Stock frequency 3400 MHz Core Speed 1596.6 MHz Northbridge Intel Ivy Bridge rev. 09 Southbridge Intel ID1E48 rev. 04 CAS# latency (CL) 11.0 RAS# to CAS# delay (tRCD) 11 RAS# Precharge (tRP) 11 Cycle Time (tRAS) 28 Command Rate (CR) 1T Memory Frequency 798.3 MHz (1:6) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 57°C (134°F) [0x39] (TMPIN0) Temperature 1 48°C (118°F) [0x30] (TMPIN1) Temperature 2 24°C (75°F) [0x18] (TMPIN2) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Intel Core i7-3770 @ Turbo 3.7GHz @ DDR3 Dual Channel @ x64 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 67.00 fps, 7754.40 kb/s encoded 11812 frames, 66.83 fps, 7754.25 kb/s encoded 11812 frames, 67.54 fps, 7754.20 kb/s encoded 11812 frames, 66.75 fps, 7754.33 kb/s Pass 2 ------ encoded 11812 frames, 14.32 fps, 8002.11 kb/s encoded 11812 frames, 14.29 fps, 8002.11 kb/s encoded 11812 frames, 14.28 fps, 8002.24 kb/s encoded 11812 frames, 14.29 fps, 8002.14 kb/s System Details -------------- (EMPTY)
Results for x264.exe r2200 x264 Benchmark: 64-bit ========================== Pass 1 ------ encoded 11812 frames, 36.67 fps, 7752.34 kb/s encoded 11812 frames, 36.71 fps, 7752.35 kb/s encoded 11812 frames, 36.90 fps, 7752.54 kb/s encoded 11812 frames, 36.38 fps, 7752.36 kb/s Pass 2 ------ encoded 11812 frames, 8.92 fps, 8002.67 kb/s encoded 11812 frames, 8.95 fps, 8002.72 kb/s encoded 11812 frames, 8.98 fps, 8002.61 kb/s encoded 11812 frames, 8.13 fps, 8002.73 kb/s System Details -------------- Name Intel Core 2 Quad Q9550 @ 3,6 GHz Name NVIDIA GeForce GTX 660 Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Core Stepping E0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2833 MHz FID range 6.0x - 8.5x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 39°C (102°F) [0x27] (System) Temperature 1 37°C (98°F) [0x25] (CPU)
i5-2520M / turbo disabled ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r2200 x264 Benchmark: 32-bit ========================== Pass 1 ------ encoded 5906 frames, 20.41 fps, 7775.81 kb/s encoded 5906 frames, 22.20 fps, 7775.81 kb/s encoded 5906 frames, 21.57 fps, 7775.81 kb/s encoded 5906 frames, 22.15 fps, 7775.81 kb/s Pass 2 ------ encoded 5906 frames, 4.69 fps, 8004.45 kb/s encoded 5906 frames, 4.69 fps, 8004.45 kb/s encoded 5906 frames, 4.65 fps, 8004.45 kb/s encoded 5906 frames, 4.69 fps, 8004.45 kb/s System Details -------------- Name Intel Core i5 Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz Core Stepping D2 Technology 32 nm Manufacturer (ID) Micron Technology (2C00000000000000) Manufacturer (ID) Micron Technology (2C00000000000000) Stock frequency 2500 MHz Core Speed 2494.4 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel QM67 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 665.2 MHz (1:5) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 988B rPGA (0x4) Temperature 0 25°C (76°F) [0xBA6] (THM_) Temperature 0 51°C (123°F) [0xC330] (core) Temperature 0 46°C (114°F) [0xC2DE] (core)
