x264 HD Benchmark 5.0
Discussion in 'Reviews & Articles' started by Adrian Wong, May 25, 2012.
  1. kowalski
    kowalski Newbie
    i5-2520M / turbo enabled
    Results for x264.exe r2200
    x264 Benchmark: 32-bit
    Pass 1
    encoded 5906 frames, 24.50 fps, 7775.81 kb/s
    encoded 5906 frames, 25.60 fps, 7775.81 kb/s
    encoded 5906 frames, 24.67 fps, 7775.81 kb/s
    encoded 5906 frames, 26.10 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 5.57 fps, 8004.45 kb/s
    encoded 5906 frames, 5.45 fps, 8004.45 kb/s
    encoded 5906 frames, 5.39 fps, 8004.45 kb/s
    encoded 5906 frames, 5.38 fps, 8004.45 kb/s
    System Details
    Name Intel Core i5
    Codename Sandy Bridge
    Specification Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz
    Core Stepping D2
    Technology 32 nm
    Manufacturer (ID) Micron Technology (2C00000000000000)
    Stock frequency 2500 MHz
    Core Speed 798.2 MHz
    Northbridge Intel Sandy Bridge rev. 09
    Southbridge Intel QM67 rev. 04
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 24
    Command Rate (CR) 1T
    Memory Frequency 665.2 MHz (1:5)
    Memory Type DDR3
    Memory Size 8192 MBytes
    Channels Dual
    Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601)
    Number of processors 1
    Number of threads 4
    Number of threads 4 (max 16)
    L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID) Socket 988B rPGA (0x4)
    Temperature 0 25°C (76°F) [0xBA6] (THM_)
    Temperature 0 55°C (130°F) [0xC36E] (core)
    Temperature 0 49°C (119°F) [0xC30E] (core)
  2. jorgemac
    jorgemac Newbie
    Intel i5 750
    x264 Benchmark: 64-bit
    Pass 1
    encoded 11812 frames, 46.21 fps, 7752.50 kb/s
    encoded 11812 frames, 46.46 fps, 7752.62 kb/s
    encoded 11812 frames, 46.43 fps, 7752.39 kb/s
    encoded 11812 frames, 46.36 fps, 7752.47 kb/s
    Pass 2
    encoded 11812 frames, 10.15 fps, 8002.58 kb/s
    encoded 11812 frames, 10.16 fps, 8002.59 kb/s
    encoded 11812 frames, 10.18 fps, 8002.67 kb/s
    encoded 11812 frames, 10.16 fps, 8002.67 kb/s
    System Details
    Name Intel Core i5 750
    Codename Lynnfield
    Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
    Specification PC3-12800
    Core Stepping B1
    Technology 45 nm
    Stock frequency 2666 MHz
    Core Speed 3932.6 MHz
    Northbridge Intel DMI Host Bridge rev. 11
    Southbridge Intel P55 rev. 05
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 786.5 MHz (2:8)
    Memory Type DDR3
    Channels Dual
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit (Build 7600)
    Number of threads 4
    Package (platform ID) Socket 1156 LGA (0x1)
    Temperature 0 55°C (130°F) [0x37] (CPU)
    Temperature 1 57°C (134°F) [0x39] (VREG)
    Temperature 2 37°C (98°F) [0x25] (System)
  3. tfon
    tfon Newbie
    Benchmark runs, results are generated, output looks bad
    Followed instructions on AVI Synth install and benchmark runs ok.
    Input file is 2:03 1080p MPEG2 20Mbps 101MB smooth I am legend trailer
    Output file is 8:12 1080p MP4 8Mbps 481MB choppy 4 loops of I am legend trailer with what looks like injected blank frames.
    Is this correct behavior?
    If so, what is the purpose of transcoding to a larger file size?
    If not, am I running something wrong and can someone tell me what their output files look like?
    Thanks!
  4. tonyhsie
    tonyhsie Newbie
    Are you running x264 hd benchmark 64-bit version?
    There are some decoding errors on 64-bit version transcoding, so the output file is corrupted, that's fine.
    I think the the test result of 32-bit version is more accurate since it doesn't have such decoding errors.
  5. tonyhsie
    tonyhsie Newbie
    Intel Core 2 Quad Q8400
    Pass 1
    encoded 5906 frames, 21.74 fps, 7775.81 kb/s
    encoded 5906 frames, 21.67 fps, 7775.81 kb/s
    encoded 5906 frames, 21.10 fps, 7775.81 kb/s
    encoded 5906 frames, 21.62 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 6.56 fps, 8004.45 kb/s
    encoded 5906 frames, 6.48 fps, 8004.45 kb/s
    encoded 5906 frames, 6.52 fps, 8004.45 kb/s
    encoded 5906 frames, 6.57 fps, 8004.45 kb/s
    System Details
    Name Intel Core 2 Quad Q8400
    Codename Yorkfield
    Specification Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz
    Core Stepping R0
    Technology 45 nm
    Manufacturer (ID) Nanya Technology (7F7F7F0B00000000)
    Core Speed 1995.0 MHz
    FID range 6.0x - 8.0x
    Northbridge Intel G41 rev. A3
    Southbridge Intel 82801GB (ICH7/R) rev. A1
    CAS# latency (CL) 6.0
    RAS# to CAS# delay (tRCD) 6
    RAS# Precharge (tRP) 6
    Cycle Time (tRAS) 18
    Command Rate (CR) 2T
    Memory Frequency 399.0 MHz (5:6)
    Memory Type DDR2
    Memory Size 4096 MBytes
    Channels Dual, (Symmetric)
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
    Package (platform ID) Socket 775 LGA (0x4)
  6. tonyhsie
    tonyhsie Newbie
    Intel Core 2 Quad Q8400 @ x64
    Pass 1
    encoded 11812 frames, 25.94 fps, 7752.36 kb/s
    encoded 11812 frames, 26.48 fps, 7752.31 kb/s
    encoded 11812 frames, 26.52 fps, 7752.48 kb/s
    encoded 11812 frames, 25.65 fps, 7752.52 kb/s
    Pass 2
    encoded 11812 frames, 6.52 fps, 8002.67 kb/s
    encoded 11812 frames, 6.57 fps, 8002.74 kb/s
    encoded 11812 frames, 6.55 fps, 8002.63 kb/s
    encoded 11812 frames, 6.48 fps, 8002.63 kb/s
    System Details
    Codename Yorkfield
    Core Stepping R0
    Technology 45 nm
    Memory Type DDR2
    Number of threads 4
  7. laychi
    laychi Newbie
    Dear Adrien.
    Sorry for my question and that i post to here.(and my soft english:))
    So...
    I wanna use x264-64.exe to video encoding,because it is faster than the 32 bit version.But...I don't know how.
    If I make a new avs script for encoding and i want to launch the x264-64.exe, the program stopped with error.
    error message:
    x264 error: could not open imput file "somethig.avs"
    I have 64bit avisynt and the 64 bit encoder...
    what is the problem and how i can fix it?
  8. Dashken
    Dashken Administrator!
    Hi bro, appreciate if you can post the question in the Software section, then I'll try to see if I can help. :D
    Also, do attach your codes if possible. ;)
  9. tonyhsie
    tonyhsie Newbie
    Intel Core 2 Duo Mobile P8700
    Pass 1
    encoded 5906 frames, 17.34 fps, 7772.23 kb/s
    encoded 5906 frames, 17.35 fps, 7772.23 kb/s
    encoded 5906 frames, 17.46 fps, 7772.23 kb/s
    encoded 5906 frames, 17.59 fps, 7772.23 kb/s
    Pass 2
    encoded 5906 frames, 3.19 fps, 8005.80 kb/s
    encoded 5906 frames, 3.15 fps, 8005.80 kb/s
    encoded 5906 frames, 3.17 fps, 8005.80 kb/s
    encoded 5906 frames, 3.18 fps, 8005.80 kb/s
    System Details
    Name Intel Mobile Core 2 Duo P8700
    Codename Penryn
    Specification Intel(R) Core(TM)2 Duo CPU P8700 @ 2.53GHz
    Core Stepping R0
    Technology 45 nm
    Stock frequency 2533 MHz
    Core Speed 2660.0 MHz
    FID range 6.0x - 9.5x
    Northbridge Intel GM45/GM47 rev. 07
    Southbridge Intel 82801IM (ICH9-M) rev. 03
    CAS# latency (CL) 7.0
    RAS# to CAS# delay (tRCD) 7
    RAS# Precharge (tRP) 7
    Cycle Time (tRAS) 20
    Memory Frequency 532.0 MHz (1:2)
    Memory Type DDR3
    Memory Size 3990 MBytes
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 3072 KBytes, 12-way set associative, 64-byte line size
    Package (platform ID) Socket P (478) (0x7)
    Temperature 0 66°C (150°F) [0xD40] (THM0)
    Temperature 1 60°C (139°F) [0xD04] (THM1)
  10. tonyhsie
    tonyhsie Newbie
    Intel Core 2 Duo Mobile P8700 @ x64
    Pass 1
    encoded 11812 frames, 18.73 fps, 7752.16 kb/s
    encoded 11812 frames, 18.83 fps, 7752.09 kb/s
    encoded 11812 frames, 18.81 fps, 7752.11 kb/s
    encoded 11812 frames, 18.82 fps, 7752.17 kb/s
    Pass 2
    encoded 11812 frames, 3.22 fps, 8003.26 kb/s
    encoded 11812 frames, 3.22 fps, 8003.27 kb/s
    encoded 11812 frames, 3.23 fps, 8003.26 kb/s
    System Details
    Codename Penryn
    Core Stepping R0
    Technology 45 nm
    Core Speed 2660.2 MHz
    Memory Type DDR3
    Number of threads 2
    Temperature 0 67°C (152°F) [0xD4A] (THM0)
    Temperature 1 63°C (145°F) [0xD22] (THM1)
  11. laychi
    laychi Newbie
    pls check general software-> x264 64bit video encoding
  12. kikizam
    kikizam Newbie
    intel quad Q6600
    salut tout le monde,
    Pass 1
    encoded 5906 frames, 17.88 fps, 7775.81 kb/s
    encoded 5906 frames, 18.86 fps, 7775.81 kb/s
    encoded 5906 frames, 18.80 fps, 7775.81 kb/s
    encoded 5906 frames, 18.58 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 5.67 fps, 8004.45 kb/s
    encoded 5906 frames, 5.68 fps, 8004.45 kb/s
    encoded 5906 frames, 5.65 fps, 8004.45 kb/s
    System Details
    Name Intel Core 2 Quad Q6600
    Codename Kentsfield
    Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
    Core Stepping G0
    Technology 65 nm
    Stock frequency 2400 MHz
    Core Speed 2394.0 MHz
    FID range 6.0x - 9.0x
    Northbridge Intel P965/G965 rev. C2
    Southbridge Intel 82801HH (ICH8DH) rev. B0
    Memory Type DDR2
    Windows Version Microsoft Windows 7 (6.1) Home Premium Edition 64-bit Service Pack 1 (Build 7601)
    Number of threads 4
    L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
  13. kikizam
    kikizam Newbie
    (apologize for my english)
    ?!!??? are you sure about the result ? it seams slower for a i3770 !! (same result as a phenom X6 ....)
  14. tonyhsie
    tonyhsie Newbie
    It's a real result from my i7-3770. :lol:
  15. tonyhsie
    tonyhsie Newbie
    Intel Pentium E6500
    @ XP
    Pass 1
    encoded 5906 frames, 17.89 fps, 7772.23 kb/s
    encoded 5906 frames, 17.97 fps, 7772.23 kb/s
    encoded 5906 frames, 18.02 fps, 7772.23 kb/s
    encoded 5906 frames, 17.93 fps, 7772.23 kb/s
    Pass 2
    encoded 5906 frames, 3.68 fps, 8005.80 kb/s
    encoded 5906 frames, 3.67 fps, 8005.80 kb/s
    System Details
    Name Intel Pentium E6500
    Codename Wolfdale
    Specification Pentium(R) Dual-Core CPU E6500 @ 2.93GHz
    Core Stepping R0
    Technology 45 nm
    Stock frequency 2933 MHz
    Core Speed 2926.1 MHz
    FID range 6.0x - 11.0x
    Northbridge Intel P35/G33/G31 rev. 10
    Memory Frequency 399.0 MHz (2:3)
    Memory Type DDR2
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    Number of threads 2
    L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
    Package (platform ID) Socket 775 LGA (0x0)
    Temperature 0 30°C (85°F) [0xBD8] (THRM)
  16. MingoDynasty
    MingoDynasty Newbie
    Stock 4770k 3.5ghz (though possibly turboed up to 3.9ghz)
    x264 HD BENCHMARK 5.0 RESULTS
    Please do NOT compare it with older versions of the benchmark!
    Please copy/paste everything below the line to to report your data
    to [You are only allowed to post URLs, images, email once you have at least 5 posts.]
    Pass 1
    encoded 11812 frames, 68.67 fps, 7754.15 kb/s
    encoded 11812 frames, 70.29 fps, 7754.22 kb/s
    encoded 11812 frames, 69.21 fps, 7753.92 kb/s
    encoded 11812 frames, 70.41 fps, 7754.27 kb/s
    Pass 2
    encoded 11812 frames, 15.28 fps, 8002.12 kb/s
    encoded 11812 frames, 15.30 fps, 8002.12 kb/s
    encoded 11812 frames, 15.29 fps, 8002.22 kb/s
    encoded 11812 frames, 15.34 fps, 8002.17 kb/s
    System Details
  17. MrScientist
    MrScientist Newbie
    8350 @ 4.6
    Pass 1
    encoded 11812 frames, 66.19 fps, 7754.12 kb/s
    encoded 11812 frames, 66.66 fps, 7754.09 kb/s
    encoded 11812 frames, 66.64 fps, 7754.27 kb/s
    encoded 11812 frames, 66.73 fps, 7754.04 kb/s
    Pass 2
    encoded 11812 frames, 16.95 fps, 8002.21 kb/s
    encoded 11812 frames, 16.90 fps, 8002.16 kb/s
    encoded 11812 frames, 16.92 fps, 8002.12 kb/s
    encoded 11812 frames, 16.88 fps, 8002.13 kb/s
    System Details
    Name AMD FX
    Codename Zambezi
    Specification AMD FX(tm)-8350 Eight-Core Processor
    Core Stepping OR-C0
    Technology 32 nm
    Stock frequency 4600 MHz
    Core Speed 4600.0 MHz
    Northbridge AMD RD9x0 rev. 02
    Southbridge AMD SB910/950 rev. 40
    Cycle Time (tRAS) 25
    Command Rate 2T
    Memory Frequency 800.0 MHz (1:4)
    Memory Type DDR3
    Memory Size 16384 MBytes
    Channels Dual
    Windows Version Microsoft Windows 8 (6.2) 64-bit (Build 9200)
    Number of threads 8
    Number of threads 8 (max 8)
    L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA
    Package Socket AM3+ (942)
    Package Type 0x1
    Temperature 0 38°C (100°F) [0x26] (TMPIN0)
    Temperature 1 33°C (91°F) [0x21] (TMPIN1)
    Temperature 2 98°C (208°F) [0x62] (TMPIN2)
    (peaked at 59°C during encoding, 1.5V)
  18. laychi
    laychi Newbie
    HP G61-410 SA Laptop
    I think so it's not bad from a 3 years old Value laptop:)(but I don't say that it's good)
    Pass 1
    encoded 5906 frames, 11.69 fps, 7772.23 kb/s
    encoded 5906 frames, 12.34 fps, 7772.23 kb/s
    encoded 5906 frames, 12.59 fps, 7772.23 kb/s
    encoded 5906 frames, 12.62 fps, 7772.23 kb/s
    Pass 2
    encoded 5906 frames, 2.20 fps, 8005.80 kb/s
    encoded 5906 frames, 2.21 fps, 8005.80 kb/s
    encoded 5906 frames, 2.22 fps, 8005.80 kb/s
    System Details
    Name Intel Celeron T3100
    Codename Penryn
    Specification Celeron(R) Dual-Core CPU T3100 @ 1.90GHz
    Core Stepping R0
    Technology 45 nm
    Stock frequency 1900 MHz
    Core Speed 1895.3 MHz
    Northbridge Intel GL40 rev. 07
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 15
    Memory Frequency 332.5 MHz (3:5)
    Memory Type DDR2
    Memory Size 3072 MBytes
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 64-bit Service Pack 1 (Build 7601)
    Number of threads 2
    L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
    Temperature 0 48°C (118°F) [0xC8C] (TZ01)
    Peak temps.(checked with AIDA64):
    Before the test I cleaned the cooler and applied new Arctic MX-4 Cooling paste.
    CPU temp= 50-51°C
    HDD temp= 47-48°C
  19. laychi
    laychi Newbie
    i5 3450@3.8GHz
    Pass 1
    encoded 5906 frames, 41.77 fps, 7775.81 kb/s
    encoded 5906 frames, 42.60 fps, 7775.81 kb/s
    encoded 5906 frames, 42.72 fps, 7775.81 kb/s
    encoded 5906 frames, 42.48 fps, 7775.81 kb/s
    Pass 2
    encoded 5906 frames, 12.06 fps, 8004.45 kb/s
    encoded 5906 frames, 12.04 fps, 8004.45 kb/s
    encoded 5906 frames, 12.05 fps, 8004.45 kb/s
    System Details
    Name Intel Core i5 3450
    product System Product Name
    Codename Ivy Bridge
    Specification Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
    Core Stepping E1
    Technology 22 nm
    Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000)
    Stock frequency 3100 MHz
    Core Speed 1648.3 MHz
    Northbridge Intel Ivy Bridge rev. 09
    Southbridge Intel Z77 rev. 04
    Memory Frequency 686.8 MHz (1:5)
    Memory Type DDR3
    Channels Dual
    Number of threads 4
    Package (platform ID) Socket 1155 LGA (0x1)
    Temperature 0 32°C (89°F) [0x20] (SYSTIN)
    Temperature 1 45°C (112°F) [0x59] (CPUTIN)
    Temperature 0 28°C (82°F) [0xBC2] (TZ00)
    Temperature 1 30°C (85°F) [0xBD6] (TZ01)
  20. laychi
    laychi Newbie
    i5 3450@ 3,8GHz new core : r2334
    Results for x264.exe r2334
    Pass 1
    encoded 5906 frames, 74.88 fps, 7771.83 kb/s
    encoded 5906 frames, 74.37 fps, 7771.83 kb/s
    encoded 5906 frames, 75.21 fps, 7771.83 kb/s
    encoded 5906 frames, 75.38 fps, 7771.83 kb/s
    Pass 2
    encoded 5906 frames, 12.63 fps, 8005.23 kb/s
    encoded 5906 frames, 12.69 fps, 8005.23 kb/s
    encoded 5906 frames, 12.67 fps, 8005.23 kb/s
    System Details
    Codename Ivy Bridge
    Core Stepping E1
    Technology 22 nm
    Memory Type DDR3
    Channels Dual
    Number of threads 4
    Temperature 0 37°C (98°F) [0x25] (SYSTIN)
    Temperature 1 50°C (121°F) [0x63] (CPUTIN)
