x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 25.49 fps, 3905.08 kb/s encoded 1442 frames, 25.84 fps, 3905.08 kb/s encoded 1442 frames, 25.77 fps, 3905.08 kb/s encoded 1442 frames, 25.94 fps, 3905.08 kb/s encoded 1442 frames, 5.99 fps, 3942.92 kb/s encoded 1442 frames, 5.97 fps, 3942.92 kb/s encoded 1442 frames, 5.99 fps, 3942.92 kb/s encoded 1442 frames, 5.95 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 26.80 fps, 3889.96 kb/s encoded 1442 frames, 26.82 fps, 3889.96 kb/s encoded 1442 frames, 26.40 fps, 3889.96 kb/s encoded 1442 frames, 26.93 fps, 3889.96 kb/s encoded 1442 frames, 6.29 fps, 3953.35 kb/s encoded 1442 frames, 6.29 fps, 3953.35 kb/s encoded 1442 frames, 6.30 fps, 3953.35 kb/s encoded 1442 frames, 6.30 fps, 3953.35 kb/s System Details -------------- Name AMD Athlon 64 X2 4400+ Codename Toledo Specification AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ Core Stepping JH-E6 Technology 90 nm Stock frequency 2200 MHz Core Speed 2481.1 MHz (10.0 x 248.1 MHz) Northbridge NVIDIA nForce4 rev. A3 Southbridge NVIDIA nForce4 MCP rev. A3 CAS# 2.0 RAS# to CAS# 3 RAS# Precharge 2 Cycle Time (tRAS) 8 Command Rate 1T Memory Frequency 206.8 MHz (CPU/12) Memory Type DDR Memory Size 2046 MBytes Channels Dual Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) Voltage sensor 0 1.39 Volts [0x57] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket 939 Temperature sensor 0 46°C (114°F) [0x2E] (TMPIN0) Temperature sensor 1 61°C (141°F) [0x3D] (TMPIN1) Temperature sensor 2 51°C (123°F) [0x33] (TMPIN2) Temperature sensor 0 45°C (112°F) [0x5E] (core #0) Temperature sensor 1 48°C (118°F) [0x61] (core #1) Temperature sensor 0 57°C (134°F) [0x39] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 19.22 fps, 3905.08 kb/s encoded 1442 frames, 19.63 fps, 3905.08 kb/s encoded 1442 frames, 19.42 fps, 3905.08 kb/s encoded 1442 frames, 18.44 fps, 3905.08 kb/s encoded 1442 frames, 4.62 fps, 3942.92 kb/s encoded 1442 frames, 4.63 fps, 3942.92 kb/s encoded 1442 frames, 4.39 fps, 3942.92 kb/s encoded 1442 frames, 4.60 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 21.90 fps, 3889.96 kb/s encoded 1442 frames, 21.68 fps, 3889.96 kb/s encoded 1442 frames, 21.87 fps, 3889.96 kb/s encoded 1442 frames, 21.65 fps, 3889.96 kb/s encoded 1442 frames, 5.15 fps, 3953.34 kb/s encoded 1442 frames, 5.18 fps, 3953.35 kb/s encoded 1442 frames, 5.18 fps, 3953.35 kb/s encoded 1442 frames, 5.18 fps, 3953.35 kb/s System Details -------------- Name Intel Celeron E1200 Codename Conroe Specification Intel(R) Celeron(R) CPU E1200 @ 1.60GHz Core Stepping M0 Technology 65 nm Stock frequency 1600 MHz Core Speed 1928.0 MHz (8.0 x 241.0 MHz) FID range 6.0x - 8.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 482.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000) max VID 1.313 V Voltage sensor 0 1.34 Volts [0xA7] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 512 KBytes, 2-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 0h) Temperature sensor 0 38°C (100°F) [0x26] (SYSTIN) Temperature sensor 1 51°C (123°F) [0x66] (CPUTIN) Temperature sensor 2 1°C (32°F) [0x1] (AUXTIN) Temperature sensor 0 45°C (112°F) [0x28] (core #0) Temperature sensor 1 47°C (116°F) [0x26] (core #1) Temperature sensor 0 42°C (106°F) [0x29] (GPU Core) Temperature sensor 0 41°C (105°F) [0x29] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 55.73 fps, 3904.62 kb/s encoded 1442 frames, 58.04 fps, 3904.62 kb/s encoded 1442 frames, 56.93 fps, 3904.62 kb/s encoded 1442 frames, 57.83 fps, 3904.62 kb/s encoded 1442 frames, 11.81 fps, 3953.18 kb/s encoded 1442 frames, 11.87 fps, 3953.18 kb/s encoded 1442 frames, 12.29 fps, 3953.18 kb/s encoded 1442 frames, 12.19 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 59.46 fps, 3887.69 kb/s encoded 1442 frames, 59.08 fps, 3886.47 kb/s encoded 1442 frames, 60.40 fps, 3885.74 kb/s encoded 1442 frames, 60.80 fps, 3889.05 kb/s encoded 1442 frames, 12.56 fps, 3963.23 kb/s encoded 1442 frames, 13.48 fps, 3963.66 kb/s encoded 1442 frames, 11.83 fps, 3963.63 kb/s encoded 1442 frames, 13.11 fps, 3963.01 kb/s System Details -------------- Name AMD Phenom X4 9850 Black Edition Codename Agena Specification AMD Phenom(tm) 9850 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Core Speed 3100.2 MHz (15.5 x 200.0 MHz) Northbridge ATI RD770 rev. 00 Southbridge ATI SB600 rev. 00 CAS# 4.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 16 Command Rate 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Voltage sensor 0 1.47 Volts [0x5C] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 74°C (165°F) [0x4A] (TMPIN0) Temperature sensor 1 44°C (111°F) [0x2C] (TMPIN1) Temperature sensor 2 25°C (76°F) [0x19] (TMPIN2) Temperature sensor 0 60°C (139°F) [0x1E0] (core #0) Temperature sensor 1 61°C (140°F) [0x1E4] (core #1) Temperature sensor 2 61°C (140°F) [0x1E4] (core #2) Temperature sensor 3 61°C (140°F) [0x1E4] (core #3) Temperature sensor 0 60°C (139°F) [0x3C] (GPU Core)
AMD Phenom 7750 Black Edition STOCK STOCK ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 31.18 fps, 3905.08 kb/s encoded 1442 frames, 31.31 fps, 3905.08 kb/s encoded 1442 frames, 31.33 fps, 3905.08 kb/s encoded 1442 frames, 31.26 fps, 3905.08 kb/s encoded 1442 frames, 7.17 fps, 3942.92 kb/s encoded 1442 frames, 7.17 fps, 3942.92 kb/s encoded 1442 frames, 7.18 fps, 3942.92 kb/s encoded 1442 frames, 7.18 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 32.65 fps, 3888.05 kb/s encoded 1442 frames, 32.70 fps, 3889.11 kb/s encoded 1442 frames, 32.69 fps, 3889.07 kb/s encoded 1442 frames, 32.80 fps, 3887.74 kb/s encoded 1442 frames, 7.70 fps, 3953.55 kb/s encoded 1442 frames, 7.70 fps, 3953.35 kb/s encoded 1442 frames, 7.71 fps, 3953.43 kb/s encoded 1442 frames, 7.71 fps, 3955.32 kb/s System Details -------------- Name AMD Phenom 7750 Black Edition Codename Kuma Specification AMD Athlon(tm) 7750 Dual-Core Processor Core Stepping DR-B3 Technology 65 nm Core Speed 2700.1 MHz (13.5 x 200.0 MHz) Northbridge NVIDIA ID0754 rev. A2 Southbridge NVIDIA ID075C rev. A2 CAS# 5.0 RAS# to CAS# 6 RAS# Precharge 6 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 3200 MBytes Channels Dual (Ganged) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Voltage sensor 0 1.38 Volts [0x56] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 63°C (145°F) [0x3F] (TMPIN0) Temperature sensor 1 35°C (94°F) [0x23] (TMPIN1) Temperature sensor 2 86°C (186°F) [0x56] (TMPIN2) Temperature sensor 0 54°C (129°F) [0x1B0] (core #0) Temperature sensor 1 54°C (129°F) [0x1B0] (core #1) Temperature sensor 0 66°C (150°F) [0x42] (GPU Core)
Her are the results from my old HP xw6200, I will post the results from my other Machine later. By the way: wouldn't a "Upload results to Server"-Function simplify things? ========================================= Machine: HP xW6200, 2 x Xeon Nocona Dualcore, 3600Mhz, Stepping E0 RAM: PC2-3200, CL 3-3-3, ECC Results for x264.exe v0.58.747 encoded 1442 frames, 22.88 fps, 3905.42 kb/s encoded 1442 frames, 23.34 fps, 3905.42 kb/s encoded 1442 frames, 23.36 fps, 3905.42 kb/s encoded 1442 frames, 23.41 fps, 3905.42 kb/s encoded 1442 frames, 6.23 fps, 3952.85 kb/s encoded 1442 frames, 6.22 fps, 3952.85 kb/s encoded 1442 frames, 6.19 fps, 3952.85 kb/s encoded 1442 frames, 6.18 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 24.36 fps, 3889.26 kb/s encoded 1442 frames, 23.99 fps, 3889.14 kb/s encoded 1442 frames, 23.93 fps, 3887.12 kb/s encoded 1442 frames, 24.58 fps, 3886.37 kb/s encoded 1442 frames, 6.85 fps, 3962.75 kb/s encoded 1442 frames, 6.84 fps, 3962.73 kb/s encoded 1442 frames, 6.83 fps, 3963.14 kb/s encoded 1442 frames, 6.76 fps, 3963.23 kb/s System Details -------------- Name Intel Xeon Name Intel Xeon Codename Nocona Codename Nocona Specification Intel(R) Xeon(TM) CPU 3.60GHz Specification Intel(R) Xeon(TM) CPU 3.60GHz Core Stepping E0 Core Stepping E0 Technology 90 nm Technology 90 nm Stock frequency 3600 MHz Stock frequency 3600 MHz Core Speed 3600.8 MHz (18.0 x 200.0 MHz) Core Speed 3600.8 MHz (18.0 x 200.0 MHz) FID range 14.0x - 18.0x FID range 14.0x - 18.0x Northbridge Intel E7525 rev. 0C Southbridge Intel 82801EB (ICH5) rev. 02 Memory Type Memory Size 3584 MBytes Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 2 Number of threads 4 Number of threads 2 (max 2) Number of threads 2 (max 2) L2 cache 1024 KBytes, 8-way set associative, 64-byte line size L2 cache 1024 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, EM64T Instructions sets MMX, SSE, SSE2, SSE3, EM64T Package Socket 604 mPGA (platform ID = 0h) Package Socket 604 mPGA (platform ID = 0h) Temperature sensor 0 50°C (121°F) [0x32] (GPU Core)
Here we go: Shuttle SD37P2, 1 x Core 2 Quad QX6700 Kentsfield, 2667Mhz RAM: PC2-6400, CL 5 Results for x264.exe v0.58.747 encoded 1442 frames, 52.50 fps, 3904.67 kb/s encoded 1442 frames, 52.80 fps, 3904.67 kb/s encoded 1442 frames, 52.92 fps, 3904.67 kb/s encoded 1442 frames, 52.23 fps, 3904.67 kb/s encoded 1442 frames, 15.00 fps, 3952.97 kb/s encoded 1442 frames, 15.03 fps, 3952.97 kb/s encoded 1442 frames, 14.99 fps, 3952.97 kb/s encoded 1442 frames, 15.01 fps, 3952.97 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 56.62 fps, 3879.87 kb/s encoded 1442 frames, 56.76 fps, 3884.04 kb/s encoded 1442 frames, 56.62 fps, 3879.81 kb/s encoded 1442 frames, 57.32 fps, 3884.06 kb/s encoded 1442 frames, 16.75 fps, 3963.51 kb/s encoded 1442 frames, 16.76 fps, 3964.12 kb/s encoded 1442 frames, 16.80 fps, 3963.10 kb/s encoded 1442 frames, 16.80 fps, 3963.94 kb/s System Details -------------- Name Intel Core 2 Extreme QX6700 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU @ 2.66GHz Core Stepping B3 Technology 65 nm Stock frequency 2666 MHz Core Speed 2667.8 MHz (10.0 x 266.8 MHz) FID range 6.0x - 10.0x Northbridge Intel i975X rev. C0 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Memory Frequency 400.2 MHz (2:3) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.350 V Voltage sensor 0 1.23 Volts [0x4D] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 89°C (192°F) [0xB] (core #0) Temperature sensor 3 85°C (184°F) [0xF] (core #3) Temperature sensor 2 84°C (183°F) [0x10] (core #2) Temperature sensor 1 87°C (188°F) [0xD] (core #1) Temperature sensor 0 59°C (138°F) [0x3B] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 67.51 fps, 3905.42 kb/s encoded 1442 frames, 68.16 fps, 3905.42 kb/s encoded 1442 frames, 68.26 fps, 3905.42 kb/s encoded 1442 frames, 68.41 fps, 3905.42 kb/s encoded 1442 frames, 17.30 fps, 3952.85 kb/s encoded 1442 frames, 17.36 fps, 3952.85 kb/s encoded 1442 frames, 17.35 fps, 3952.85 kb/s encoded 1442 frames, 17.29 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 70.24 fps, 3891.55 kb/s encoded 1442 frames, 70.07 fps, 3891.55 kb/s encoded 1442 frames, 68.77 fps, 3891.55 kb/s encoded 1442 frames, 68.06 fps, 3891.55 kb/s encoded 1442 frames, 18.64 fps, 3963.43 kb/s encoded 1442 frames, 18.15 fps, 3963.44 kb/s encoded 1442 frames, 18.07 fps, 3963.43 kb/s encoded 1442 frames, 18.37 fps, 3963.43 kb/s System Details -------------- Name AMD Phenom II X4 955 Black Edition Codename Deneb Specification AMD Phenom(tm) II X4 955 Processor Core Stepping RB-C2 Technology 45 nm Core Speed 3200.2 MHz (16.0 x 200.0 MHz) Northbridge AMD 790FX rev. 00 Southbridge ATI SB600 rev. 00 CAS# 6.0 RAS# to CAS# 6 CAS# 4.0 5.0 6.0 RAS# to CAS# delay 4 5 6 CAS# 4.0 5.0 6.0 RAS# to CAS# delay 4 5 6 CAS# 4.0 5.0 6.0 RAS# to CAS# delay 4 5 6 CAS# 4.0 5.0 6.0 RAS# to CAS# delay 4 5 6 RAS# Precharge 6 RAS# Precharge 4 5 6 RAS# Precharge 4 5 6 RAS# Precharge 4 5 6 RAS# Precharge 4 5 6 Cycle Time (tRAS) 18 Command Rate 2T Address Command Rate 2T Address Command Rate 2T Address Command Rate 2T Address Command Rate 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual (Unganged) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) Voltage sensor 0 3.31 Volts [0xCF] (+3.3V) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 46°C (114°F) [0x2E] (TMPIN0) Temperature sensor 2 41°C (105°F) [0x29] (TMPIN2) Temperature sensor 0 56°C (133°F) [0x1C2] (Core #0) Temperature sensor 1 56°C (133°F) [0x1C2] (Core #1) Temperature sensor 2 56°C (133°F) [0x1C1] (Core #2) Temperature sensor 3 56°C (133°F) [0x1C1] (Core #3) Temperature sensor 0 51°C (123°F) [0x33] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 51.15 fps, 3905.42 kb/s encoded 1442 frames, 50.82 fps, 3905.42 kb/s encoded 1442 frames, 50.68 fps, 3905.42 kb/s encoded 1442 frames, 50.46 fps, 3905.42 kb/s encoded 1442 frames, 12.76 fps, 3952.85 kb/s encoded 1442 frames, 12.74 fps, 3952.85 kb/s encoded 1442 frames, 12.75 fps, 3952.85 kb/s encoded 1442 frames, 12.68 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 52.13 fps, 3891.55 kb/s encoded 1442 frames, 52.17 fps, 3889.35 kb/s encoded 1442 frames, 52.08 fps, 3891.55 kb/s encoded 1442 frames, 51.90 fps, 3891.55 kb/s encoded 1442 frames, 13.69 fps, 3963.43 kb/s encoded 1442 frames, 13.72 fps, 3963.51 kb/s encoded 1442 frames, 13.68 fps, 3963.43 kb/s encoded 1442 frames, 13.63 fps, 3963.43 kb/s System Details -------------- Name AMD Phenom X4 9750 Codename Agena Specification AMD Phenom(tm) 9750 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Stock frequency 2400 MHz Core Speed 2400.0 MHz (12.0 x 200.0 MHz) FID range 5.0x - 12.0x Northbridge NVIDIA nForce 750a SLI SPP rev. A2 Southbridge NVIDIA nForce 750a SLI MCP rev. A2 CAS# 5.0 RAS# to CAS# 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 RAS# Precharge 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual (Ganged) Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7000) max VID 1.250 V Voltage sensor 0 1.30 Volts [0x51] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 56°C (132°F) [0x38] (TMPIN0) Temperature sensor 1 40°C (103°F) [0x28] (TMPIN1) Temperature sensor 0 57°C (133°F) [0x1C4] (Core #0) Temperature sensor 1 57°C (133°F) [0x1C4] (Core #1) Temperature sensor 2 57°C (133°F) [0x1C4] (Core #2) Temperature sensor 3 56°C (132°F) [0x1C0] (Core #3) Temperature sensor 0 53°C (127°F) [0x35] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 63.18 fps, 3905.42 kb/s encoded 1442 frames, 63.66 fps, 3905.42 kb/s encoded 1442 frames, 64.96 fps, 3905.42 kb/s encoded 1442 frames, 61.62 fps, 3905.42 kb/s encoded 1442 frames, 16.39 fps, 3952.85 kb/s encoded 1442 frames, 16.44 fps, 3952.85 kb/s encoded 1442 frames, 16.43 fps, 3952.85 kb/s encoded 1442 frames, 16.35 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 66.55 fps, 3891.55 kb/s encoded 1442 frames, 66.84 fps, 3891.55 kb/s encoded 1442 frames, 66.45 fps, 3891.55 kb/s encoded 1442 frames, 65.98 fps, 3891.55 kb/s encoded 1442 frames, 17.60 fps, 3963.44 kb/s encoded 1442 frames, 17.60 fps, 3963.43 kb/s encoded 1442 frames, 17.42 fps, 3963.43 kb/s encoded 1442 frames, 17.55 fps, 3963.42 kb/s System Details -------------- Name AMD Phenom II X4 940 Black Edition Codename Deneb Specification AMD Phenom(tm) II X4 940 Processor Core Stepping RB-C2 Technology 45 nm Core Speed 2999.9 MHz (15.0 x 200.0 MHz) Northbridge NVIDIA nForce 750a SLI SPP rev. A2 Southbridge NVIDIA nForce 750a SLI MCP rev. A2 CAS# 5.0 RAS# to CAS# 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 RAS# Precharge 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual (Unganged) Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7000) Voltage sensor 0 1.39 Volts [0x57] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 54°C (129°F) [0x36] (TMPIN0) Temperature sensor 1 40°C (103°F) [0x28] (TMPIN1) Temperature sensor 0 61°C (141°F) [0x1E8] (Core #0) Temperature sensor 1 61°C (141°F) [0x1E8] (Core #1) Temperature sensor 2 61°C (141°F) [0x1E8] (Core #2) Temperature sensor 3 61°C (141°F) [0x1E8] (Core #3) Temperature sensor 0 48°C (118°F) [0x30] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 15.54 fps, 3905.08 kb/s encoded 1442 frames, 15.63 fps, 3905.08 kb/s encoded 1442 frames, 15.62 fps, 3905.08 kb/s encoded 1442 frames, 15.01 fps, 3905.08 kb/s encoded 1442 frames, 3.55 fps, 3942.92 kb/s encoded 1442 frames, 3.56 fps, 3942.92 kb/s encoded 1442 frames, 3.54 fps, 3942.92 kb/s encoded 1442 frames, 3.49 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 16.04 fps, 3889.96 kb/s encoded 1442 frames, 16.18 fps, 3889.96 kb/s encoded 1442 frames, 16.24 fps, 3889.96 kb/s encoded 1442 frames, 15.94 fps, 3889.96 kb/s encoded 1442 frames, 3.72 fps, 3953.35 kb/s encoded 1442 frames, 3.71 fps, 3953.35 kb/s encoded 1442 frames, 3.73 fps, 3953.35 kb/s encoded 1442 frames, 3.71 fps, 3953.35 kb/s System Details -------------- Name AMD Athlon 64 X2 3200B Codename Specification AMD Athlon(tm) X2 Dual Core Processor 3250e Core Stepping DH-G2 Technology 65 nm Stock frequency 1500 MHz Core Speed 1500.1 MHz (7.5 x 200.0 MHz) Northbridge NVIDIA nForce 750a SLI SPP rev. A2 Southbridge NVIDIA nForce 750a SLI MCP rev. A2 CAS# 5.0 RAS# to CAS# 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 CAS# 3.0 4.0 5.0 RAS# to CAS# delay 3 4 5 RAS# Precharge 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 RAS# Precharge 3 4 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 300.0 MHz (CPU/5) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7000) max VID 1.050 V Voltage sensor 0 0.96 Volts [0x3C] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket AM2 (940) Temperature sensor 0 34°C (93°F) [0x22] (TMPIN0) Temperature sensor 1 36°C (96°F) [0x24] (TMPIN1) Temperature sensor 0 9°C (48°F) [0xE9] (Core #0) Temperature sensor 1 10°C (49°F) [0xEB] (Core #1) Temperature sensor 0 48°C (118°F) [0x30] (GPU Core)
results Results for x264.exe v0.58.747 encoded 1442 frames, 69.76 fps, 3905.42 kb/s encoded 1442 frames, 69.65 fps, 3905.42 kb/s encoded 1442 frames, 69.44 fps, 3905.42 kb/s encoded 1442 frames, 69.23 fps, 3905.42 kb/s encoded 1442 frames, 18.95 fps, 3952.85 kb/s encoded 1442 frames, 18.99 fps, 3952.85 kb/s encoded 1442 frames, 18.99 fps, 3952.85 kb/s encoded 1442 frames, 18.97 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 74.55 fps, 3888.41 kb/s encoded 1442 frames, 74.36 fps, 3886.48 kb/s encoded 1442 frames, 74.79 fps, 3889.26 kb/s encoded 1442 frames, 74.36 fps, 3891.55 kb/s encoded 1442 frames, 21.25 fps, 3963.25 kb/s encoded 1442 frames, 21.22 fps, 3963.36 kb/s encoded 1442 frames, 21.17 fps, 3962.51 kb/s encoded 1442 frames, 21.23 fps, 3963.43 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3342.8 MHz (9.0 x 371.4 MHz) FID range 6.0x - 9.0x Northbridge Intel i975X rev. C0 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# 4.0 RAS# to CAS# 4 RAS# Precharge 3 Cycle Time (tRAS) 5 Memory Frequency 464.3 MHz (4:5) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows XP x64 Professional Service Pack 2 (Build 3790) max VID 1.325 V Voltage sensor 0 1.38 Volts [0xAD] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 39°C (102°F) [0x27] (SYSTIN) Temperature sensor 1 37°C (98°F) [0x4A] (CPUTIN) Temperature sensor 2 7°C (43°F) [0xD] (AUXTIN) Temperature sensor 0 57°C (134°F) [0x2B] (core #0) Temperature sensor 1 54°C (129°F) [0x2E] (core #1) Temperature sensor 2 50°C (121°F) [0x32] (core #2) Temperature sensor 3 50°C (121°F) [0x32] (core #3)
Results for x264.exe v0.58.747 encoded 1442 frames, 72.96 fps, 3905.42 kb/s encoded 1442 frames, 71.82 fps, 3905.42 kb/s encoded 1442 frames, 71.49 fps, 3905.42 kb/s encoded 1442 frames, 71.44 fps, 3905.42 kb/s encoded 1442 frames, 17.86 fps, 3952.85 kb/s encoded 1442 frames, 17.90 fps, 3952.85 kb/s encoded 1442 frames, 17.92 fps, 3952.85 kb/s encoded 1442 frames, 17.83 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 72.44 fps, 3889.34 kb/s encoded 1442 frames, 74.48 fps, 3889.34 kb/s encoded 1442 frames, 74.55 fps, 3889.34 kb/s encoded 1442 frames, 73.54 fps, 3889.34 kb/s encoded 1442 frames, 19.13 fps, 3962.65 kb/s encoded 1442 frames, 19.16 fps, 3962.75 kb/s encoded 1442 frames, 19.11 fps, 3962.75 kb/s encoded 1442 frames, 19.17 fps, 3962.75 kb/s System Details -------------- Name AMD Phenom Codename Deneb Specification AMD Phenom(tm) II X4 920 Processor Core Stepping Technology 45 nm Stock frequency 2800 MHz Core Speed 3237.4 MHz (14.0 x 231.2 MHz) FID range 5.0x - 14.0x Northbridge NVIDIA ID0754 rev. A2 Southbridge NVIDIA ID075C rev. A2 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 462.5 MHz (1:2) Memory Type DDR2 Memory Size 3456 MBytes Channels Dual (Ganged) Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7100) max VID 1.350 V Voltage sensor 0 1.39 Volts [0x57] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 62°C (143°F) [0x3E] (TMPIN0) Temperature sensor 1 41°C (105°F) [0x29] (TMPIN1) Temperature sensor 0 61°C (140°F) [0x1E4] (core #0) Temperature sensor 1 61°C (140°F) [0x1E4] (core #1) Temperature sensor 2 61°C (140°F) [0x1E4] (core #2) Temperature sensor 3 60°C (140°F) [0x1E3] (core #3)
Grettings from Argentina Her my benchmark Results for x264.exe v0.58.747 encoded 1442 frames, 45.51 fps, 3906.89 kb/s encoded 1442 frames, 45.62 fps, 3906.89 kb/s encoded 1442 frames, 45.55 fps, 3906.89 kb/s encoded 1442 frames, 45.48 fps, 3906.89 kb/s encoded 1442 frames, 10.25 fps, 3944.00 kb/s encoded 1442 frames, 10.27 fps, 3944.00 kb/s encoded 1442 frames, 10.31 fps, 3944.00 kb/s encoded 1442 frames, 10.23 fps, 3944.00 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 47.57 fps, 3887.35 kb/s encoded 1442 frames, 47.52 fps, 3886.62 kb/s encoded 1442 frames, 47.28 fps, 3888.09 kb/s encoded 1442 frames, 47.62 fps, 3885.68 kb/s encoded 1442 frames, 11.07 fps, 3957.71 kb/s encoded 1442 frames, 11.08 fps, 3957.72 kb/s encoded 1442 frames, 11.08 fps, 3957.37 kb/s encoded 1442 frames, 11.11 fps, 3957.24 kb/s System Details -------------- Name AMD Phenom Codename Deneb Specification AMD Phenom(tm) II X3 710 Processor Core Stepping Technology 45 nm Stock frequency 2600 MHz Core Speed 2612.2 MHz (13.0 x 200.9 MHz) FID range 5.0x - 13.0x Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 401.9 MHz (1:2) Memory Type DDR2 Memory Size 1792 MBytes Channels Dual (Ganged) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.325 V Voltage sensor 0 1.38 Volts [0x56] (CPU VCORE) Number of processors 1 Number of threads 3 Number of threads 3 (max 3) L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 58°C (136°F) [0x3A] (TMPIN0) Temperature sensor 1 35°C (94°F) [0x23] (TMPIN1) Temperature sensor 0 49°C (120°F) [0x18B] (core #0) Temperature sensor 1 50°C (121°F) [0x18C] (core #1) Temperature sensor 2 50°C (121°F) [0x18C] (core #2)
Results for x264.exe v0.58.747 encoded 1442 frames, 71.03 fps, 3905.42 kb/s encoded 1442 frames, 71.78 fps, 3905.42 kb/s encoded 1442 frames, 71.09 fps, 3905.42 kb/s encoded 1442 frames, 71.28 fps, 3905.42 kb/s encoded 1442 frames, 20.74 fps, 3952.85 kb/s encoded 1442 frames, 20.73 fps, 3952.85 kb/s encoded 1442 frames, 20.71 fps, 3952.85 kb/s encoded 1442 frames, 20.71 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 77.50 fps, 3891.55 kb/s encoded 1442 frames, 77.34 fps, 3891.55 kb/s encoded 1442 frames, 78.19 fps, 3891.55 kb/s encoded 1442 frames, 77.34 fps, 3891.55 kb/s encoded 1442 frames, 23.12 fps, 3963.43 kb/s encoded 1442 frames, 23.08 fps, 3963.43 kb/s encoded 1442 frames, 23.22 fps, 3963.43 kb/s encoded 1442 frames, 23.17 fps, 3963.43 kb/s System Details -------------- Name Intel Core 2 Quad Q9450 Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz Core Stepping C1 Technology 45 nm Stock frequency 2666 MHz Core Speed 3600.1 MHz (8.0 x 450.0 MHz) FID range 6.0x - 8.0x Northbridge Intel P45 rev. A2 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 15 Command Rate 2T Memory Frequency 450.0 MHz (1:1) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.250 V Voltage sensor 0 1.26 Volts [0x9D] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 27°C (80°F) [0x1B] (SYSTIN) Temperature sensor 1 38°C (100°F) [0x4C] (CPUTIN) Temperature sensor 2 25°C (76°F) [0x32] (AUXTIN) Temperature sensor 0 63°C (145°F) [0x2A] (core #0) Temperature sensor 1 58°C (136°F) [0x2F] (core #1) Temperature sensor 2 59°C (138°F) [0x2E] (core #2) Temperature sensor 3 61°C (141°F) [0x2C] (core #3) Temperature sensor 0 47°C (115°F) [0x2E] (GPU Core)
Results for x264.exe v0.58.747 encoded 1442 frames, 24.38 fps, 3905.08 kb/s encoded 1442 frames, 24.47 fps, 3905.08 kb/s encoded 1442 frames, 24.63 fps, 3905.08 kb/s encoded 1442 frames, 24.64 fps, 3905.08 kb/s encoded 1442 frames, 6.13 fps, 3942.92 kb/s encoded 1442 frames, 6.14 fps, 3942.92 kb/s encoded 1442 frames, 6.14 fps, 3942.92 kb/s encoded 1442 frames, 6.20 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 27.24 fps, 3889.96 kb/s encoded 1442 frames, 27.24 fps, 3889.96 kb/s encoded 1442 frames, 27.19 fps, 3889.96 kb/s encoded 1442 frames, 27.30 fps, 3889.96 kb/s encoded 1442 frames, 6.90 fps, 3953.35 kb/s encoded 1442 frames, 6.92 fps, 3953.35 kb/s encoded 1442 frames, 6.83 fps, 3953.35 kb/s encoded 1442 frames, 6.83 fps, 3953.35 kb/s System Details -------------- Name Intel Core 2 Duo E4500 Codename Conroe Specification Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz Core Stepping M0 Technology 65 nm Stock frequency 2200 MHz Core Speed 2206.9 MHz (11.0 x 200.6 MHz) FID range 6.0x - 11.0x Northbridge Intel P965/G965 rev. C2 Southbridge Intel 82801HB/HR (ICH8/R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 401.3 MHz (1:2) Memory Type DDR2 Memory Size 2024 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 1 (Build 6001) max VID 1.325 V Voltage sensor 0 1.26 Volts [0x9E] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 0h) Temperature sensor 0 45°C (112°F) [0x2D] (SYSTIN) Temperature sensor 1 51°C (122°F) [0x65] (CPUTIN) Temperature sensor 0 56°C (132°F) [0x1D] (core #0) Temperature sensor 1 57°C (134°F) [0x1C] (core #1)
Results Results for x264.exe v0.58.747 encoded 1442 frames, 46.35 fps, 3904.62 kb/s encoded 1442 frames, 45.94 fps, 3904.62 kb/s encoded 1442 frames, 47.18 fps, 3904.62 kb/s encoded 1442 frames, 45.82 fps, 3904.62 kb/s encoded 1442 frames, 12.67 fps, 3953.18 kb/s encoded 1442 frames, 13.62 fps, 3953.18 kb/s encoded 1442 frames, 13.60 fps, 3953.18 kb/s encoded 1442 frames, 13.64 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 49.54 fps, 3886.70 kb/s encoded 1442 frames, 48.70 fps, 3888.58 kb/s encoded 1442 frames, 49.19 fps, 3889.36 kb/s encoded 1442 frames, 47.72 fps, 3889.68 kb/s encoded 1442 frames, 15.31 fps, 3963.67 kb/s encoded 1442 frames, 15.25 fps, 3963.52 kb/s encoded 1442 frames, 15.24 fps, 3962.81 kb/s encoded 1442 frames, 15.27 fps, 3962.71 kb/s System Details -------------- Name Intel Core 2 Quad Q9450 Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz Core Stepping R0 Technology 45 nm Stock frequency 2666 MHz Core Speed 2668.6 MHz (8.0 x 333.6 MHz) FID range 6.0x - 8.0x Northbridge NVIDIA GeForce 7100 rev. A2 Southbridge NVIDIA nForce 630i rev. A2 CAS# 6.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 17 Command Rate 2T Memory Frequency 400.3 MHz (5:6) Memory Type DDR2 Memory Size 1920 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) max VID 1.213 V Voltage sensor 0 1.39 Volts [0x57] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 44°C (111°F) [0x2C] (TMPIN0) Temperature sensor 1 37°C (98°F) [0x25] (TMPIN1) Temperature sensor 2 37°C (98°F) [0x25] (TMPIN2) Temperature sensor 0 56°C (132°F) [0x31] (core #0) Temperature sensor 1 45°C (112°F) [0x3C] (core #1) Temperature sensor 2 49°C (120°F) [0x38] (core #2) Temperature sensor 3 49°C (120°F) [0x38] (core #3)
Results for x264.exe v0.58.747 encoded 1442 frames, 88.24 fps, 3905.42 kb/s encoded 1442 frames, 91.82 fps, 3905.42 kb/s encoded 1442 frames, 91.99 fps, 3905.42 kb/s encoded 1442 frames, 92.72 fps, 3905.42 kb/s encoded 1442 frames, 24.99 fps, 3952.85 kb/s encoded 1442 frames, 25.05 fps, 3952.85 kb/s encoded 1442 frames, 24.98 fps, 3952.85 kb/s encoded 1442 frames, 24.96 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 97.05 fps, 3891.55 kb/s encoded 1442 frames, 98.25 fps, 3891.55 kb/s encoded 1442 frames, 98.39 fps, 3891.55 kb/s encoded 1442 frames, 98.25 fps, 3891.55 kb/s encoded 1442 frames, 27.55 fps, 3963.44 kb/s encoded 1442 frames, 27.87 fps, 3963.43 kb/s encoded 1442 frames, 27.82 fps, 3963.44 kb/s encoded 1442 frames, 27.69 fps, 3963.43 kb/s System Details -------------- Name Intel Processor Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Engineering Sample) (Why does it detect it as an ES??) Core Stepping Technology 45 nm Core Speed 3800.0 MHz (20.0 x 190.0 MHz) Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Frequency 1520.0 MHz () Memory Type DDR3 Memory Size 6142 MBytes Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 2 (Build 6002) max VID 0.825 V Voltage sensor 0 1.30 Volts [0x51] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package Socket 1366 LGA (platform ID = 1h) Temperature sensor 0 49°C (120°F) [0x31] (TMPIN0) Temperature sensor 1 51°C (123°F) [0x33] (TMPIN1) Temperature sensor 2 60°C (139°F) [0x3C] (TMPIN2) Temperature sensor 0 69°C (156°F) [0x24] (core #0) Temperature sensor 1 66°C (150°F) [0x27] (core #1) Temperature sensor 2 70°C (157°F) [0x23] (core #2) Temperature sensor 3 67°C (152°F) [0x26] (core #3) Temperature sensor 0 63°C (145°F) [0x3F] (GPU Core)
Intel(R) Xeon(R) CPU W5580 @ 3.20GHz (Engineering Sample) Benchmark For Xeon W5580 @ 3.20GHz Results for x264.exe v0.58.747 encoded 1442 frames, 70.72 fps, 3903.07 kb/s encoded 1442 frames, 68.72 fps, 3903.07 kb/s encoded 1442 frames, 71.65 fps, 3903.07 kb/s encoded 1442 frames, 69.34 fps, 3903.07 kb/s encoded 1442 frames, 55.10 fps, 3997.54 kb/s encoded 1442 frames, 54.58 fps, 3997.54 kb/s encoded 1442 frames, 54.80 fps, 3997.54 kb/s encoded 1442 frames, 54.45 fps, 3997.54 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 71.21 fps, 3896.15 kb/s encoded 1442 frames, 73.30 fps, 3894.16 kb/s encoded 1442 frames, 71.16 fps, 3896.46 kb/s encoded 1442 frames, 76.21 fps, 3893.35 kb/s encoded 1442 frames, 60.88 fps, 4002.12 kb/s encoded 1442 frames, 60.72 fps, 4002.56 kb/s encoded 1442 frames, 61.12 fps, 4001.04 kb/s encoded 1442 frames, 59.89 fps, 4002.57 kb/s System Details -------------- Name Intel Processor Name Intel Processor Codename Bloomfield Codename Bloomfield Specification Intel(R) Xeon(R) CPU W5580 @ 3.20GHz (Engineering Sample) Specification Intel(R) Xeon(R) CPU W5580 @ 3.20GHz (Engineering Sample) Core Stepping Core Stepping Technology 45 nm Technology 45 nm Stock frequency 3200 MHz Stock frequency 3200 MHz Core Speed 3333.3 MHz (25.0 x 133.3 MHz) Core Speed 3333.3 MHz (25.0 x 133.3 MHz) Northbridge Intel ID3403 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Frequency 1066.7 MHz () Memory Type DDR3 Memory Size 8130 MBytes Windows Version Microsoft Windows Server 2003 Enterprise Edition Service Pack 1 (Build 3790) max VID 0.825 V max VID 0.825 V Number of processors 2 Number of threads 16 Number of threads 8 (max 16) Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package Socket 1366 LGA (platform ID = 0h) Package Socket 1366 LGA (platform ID = 0h) Temperature sensor 0 90°C (193°F) [0xF] (core #0) Temperature sensor 1 89°C (192°F) [0x10] (core #1) Temperature sensor 2 87°C (188°F) [0x12] (core #2) Temperature sensor 3 87°C (188°F) [0x12] (core #3) Temperature sensor 0 81°C (177°F) [0x18] (core #0) Temperature sensor 1 80°C (175°F) [0x19] (core #1) Temperature sensor 2 81°C (177°F) [0x18] (core #2) Temperature sensor 3 78°C (172°F) [0x1B] (core #3)
Results for x264.exe v0.58.747 encoded 1442 frames, 82.03 fps, 3904.94 kb/s encoded 1442 frames, 80.39 fps, 3904.94 kb/s encoded 1442 frames, 82.25 fps, 3904.94 kb/s encoded 1442 frames, 82.32 fps, 3904.94 kb/s encoded 1442 frames, 28.25 fps, 3974.08 kb/s encoded 1442 frames, 28.31 fps, 3974.08 kb/s encoded 1442 frames, 28.28 fps, 3974.08 kb/s encoded 1442 frames, 28.30 fps, 3974.08 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 87.39 fps, 3895.56 kb/s encoded 1442 frames, 86.82 fps, 3895.56 kb/s encoded 1442 frames, 86.82 fps, 3895.56 kb/s encoded 1442 frames, 86.33 fps, 3895.56 kb/s encoded 1442 frames, 31.57 fps, 3981.22 kb/s encoded 1442 frames, 31.47 fps, 3981.30 kb/s encoded 1442 frames, 31.54 fps, 3981.30 kb/s encoded 1442 frames, 31.58 fps, 3981.22 kb/s System Details -------------- Name Intel Processor Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Engineering Sample) Core Stepping Technology 45 nm Core Speed 3311.7 MHz (20.0 x 165.6 MHz) Northbridge Intel ID3400 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Frequency 1324.7 MHz () Memory Type DDR3 Memory Size 6136 MBytes Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 2 (Build 6002) max VID 0.825 V Voltage sensor 0 3.30 Volts [0xCE] (+3.3V) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package Socket 1366 LGA (platform ID = 1h)
Pentium D (Core 2 Duo) E5200 STOCK Results for x264.exe v0.58.747 encoded 1442 frames, 27.63 fps, 3905.08 kb/s encoded 1442 frames, 27.78 fps, 3905.08 kb/s encoded 1442 frames, 27.88 fps, 3905.08 kb/s encoded 1442 frames, 27.90 fps, 3905.08 kb/s encoded 1442 frames, 7.33 fps, 3942.92 kb/s encoded 1442 frames, 7.36 fps, 3942.92 kb/s encoded 1442 frames, 7.33 fps, 3942.92 kb/s encoded 1442 frames, 7.28 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 31.12 fps, 3889.96 kb/s encoded 1442 frames, 31.08 fps, 3889.96 kb/s encoded 1442 frames, 31.22 fps, 3889.96 kb/s encoded 1442 frames, 31.18 fps, 3889.96 kb/s encoded 1442 frames, 8.22 fps, 3953.35 kb/s encoded 1442 frames, 8.22 fps, 3953.35 kb/s encoded 1442 frames, 8.16 fps, 3953.35 kb/s encoded 1442 frames, 8.22 fps, 3953.35 kb/s System Details -------------- Name Intel Pentium Codename Wolfdale Specification Pentium(R) Dual-Core CPU E5200 @ 2.50GHz Core Stepping Technology 45 nm Stock frequency 2500 MHz Core Speed 2520.6 MHz (12.5 x 201.6 MHz) FID range 6.0x - 12.5x Northbridge Intel P45 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 403.3 MHz (1:2) Memory Type DDR3 Memory Size 3966 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7600) max VID 1.288 V Voltage sensor 0 1.23 Volts [0x9A] (CPU VCORE) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 0h) Temperature sensor 0 36°C (96°F) [0x24] (SYSTIN) Temperature sensor 1 42°C (107°F) [0x54] (CPUTIN) Temperature sensor 2 32°C (89°F) [0x40] (AUXTIN) Temperature sensor 0 47°C (116°F) [0x3A] (core #0) Temperature sensor 1 37°C (98°F) [0x44] (core #1)
