i never posted here before, just doing it for fun x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 21.81 fps, 3905.08 kb/s encoded 1442 frames, 21.86 fps, 3905.08 kb/s encoded 1442 frames, 21.14 fps, 3905.08 kb/s encoded 1442 frames, 21.21 fps, 3905.08 kb/s encoded 1442 frames, 5.57 fps, 3942.92 kb/s encoded 1442 frames, 5.33 fps, 3942.92 kb/s encoded 1442 frames, 5.23 fps, 3942.92 kb/s encoded 1442 frames, 5.18 fps, 3942.92 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 24.40 fps, 3889.96 kb/s encoded 1442 frames, 23.49 fps, 3889.96 kb/s encoded 1442 frames, 23.11 fps, 3889.96 kb/s encoded 1442 frames, 23.25 fps, 3889.96 kb/s encoded 1442 frames, 5.89 fps, 3953.35 kb/s encoded 1442 frames, 5.75 fps, 3953.35 kb/s encoded 1442 frames, 5.83 fps, 3953.35 kb/s encoded 1442 frames, 5.81 fps, 3953.35 kb/s wow, my laptop is slow System Details -------------- Name Intel Mobile Core 2 Duo T7200 Codename Merom Specification Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz Core Stepping B2 Technology 65 nm Stock frequency 2000 MHz Core Speed 1664.3 MHz (10.0 x 166.4 MHz) FID range 6.0x - 12.0x Northbridge Intel i945PM rev. 03 Southbridge Intel 82801GHM (ICH7-M/U) rev. A1 CAS# 4.0 RAS# to CAS# 4 RAS# Precharge 4 Cycle Time (tRAS) 12 Memory Frequency 332.9 MHz (1:2) Memory Type DDR2 Memory Size 3328 MBytes Channels Dual Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7600) Its Windows 7 btw. max VID 1.363 V Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 479 mPGA (platform ID = 5h) Temperature sensor 0 95°C (202°F) [0x5] (core #0) Temperature sensor 1 94°C (201°F) [0x6] (core #1) Temperature sensor 0 96°C (204°F) [0x60] (GPU Core) oh shyt i can cook eggs with my laptop
Time to update x264 build I think it's time to update the x264 build in the benchmark. There have been huge improvements since r819, the "new" version in the benchmark. Builds now are >r1200. I tweaked the VB script for the benchmark and ran it with Sharktooth's r1181 build (32-bit) and see a 25% increase in encoding speed on first pass and 21% increase in speed on second pass over the r819 build. I'm on a Core 2 Duo, so that increase does not even include the Nehalem optimizations that began with r1019. Let me know if you want the tweaked VB script. I didn't change much, just removed a number of switches that are deprecated.
My 1st post on this forum, results for my OC q6600 9x333 (3ghz) x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 60.13 fps, 3904.67 kb/s encoded 1442 frames, 61.19 fps, 3904.67 kb/s encoded 1442 frames, 61.51 fps, 3904.67 kb/s encoded 1442 frames, 61.03 fps, 3904.67 kb/s encoded 1442 frames, 17.17 fps, 3952.97 kb/s encoded 1442 frames, 17.26 fps, 3952.97 kb/s encoded 1442 frames, 17.20 fps, 3952.97 kb/s encoded 1442 frames, 17.21 fps, 3952.97 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 66.00 fps, 3891.41 kb/s encoded 1442 frames, 65.88 fps, 3891.41 kb/s encoded 1442 frames, 65.98 fps, 3891.41 kb/s encoded 1442 frames, 66.04 fps, 3891.41 kb/s encoded 1442 frames, 19.06 fps, 3962.86 kb/s encoded 1442 frames, 19.06 fps, 3962.87 kb/s encoded 1442 frames, 19.10 fps, 3962.86 kb/s encoded 1442 frames, 19.07 fps, 3962.86 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3082.1 MHz (9.0 x 342.5 MHz) FID range 6.0x - 9.0x Northbridge Intel X38 rev. 01 Southbridge Intel 82801IR (ICH9R) rev. 02 CAS# 5.0 RAS# to CAS# 5 RAS# Precharge 5 Cycle Time (tRAS) 18 Command Rate 2T Memory Frequency 410.9 MHz (5:6) Memory Type DDR2 Memory Size 6142 MBytes Channels Dual (Symmetric) Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001) max VID 1.275 V Voltage sensor 0 1.18 Volts [0x4A] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package Socket 775 LGA (platform ID = 4h) Temperature sensor 0 42°C (107°F) [0x2A] (TMPIN0) Temperature sensor 1 63°C (145°F) [0x3F] (TMPIN1) Temperature sensor 2 -54°C (-66°F) [0xC9] (TMPIN2) Temperature sensor 0 73°C (163°F) [0x1B] (core #0) Temperature sensor 1 70°C (157°F) [0x1E] (core #1) Temperature sensor 2 69°C (156°F) [0x1F] (core #2) Temperature sensor 3 68°C (154°F) [0x20] (core #3) Temperature sensor 0 53°C (127°F) [0x35] (GPU Core)
955BE @ 3.8 on air x264 HD BENCHMARK RESULTS Please copy/paste everything below the line into the forum post to report your data ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 82.83 fps, 3905.42 kb/s encoded 1442 frames, 82.75 fps, 3905.42 kb/s encoded 1442 frames, 82.61 fps, 3905.42 kb/s encoded 1442 frames, 84.42 fps, 3905.42 kb/s encoded 1442 frames, 20.75 fps, 3952.85 kb/s encoded 1442 frames, 20.83 fps, 3952.85 kb/s encoded 1442 frames, 20.87 fps, 3952.85 kb/s encoded 1442 frames, 20.85 fps, 3952.85 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 86.39 fps, 3891.55 kb/s encoded 1442 frames, 86.31 fps, 3891.55 kb/s encoded 1442 frames, 84.65 fps, 3889.35 kb/s encoded 1442 frames, 86.55 fps, 3889.41 kb/s encoded 1442 frames, 22.33 fps, 3963.43 kb/s encoded 1442 frames, 22.33 fps, 3963.44 kb/s encoded 1442 frames, 22.32 fps, 3963.51 kb/s encoded 1442 frames, 22.35 fps, 3962.39 kb/s System Details -------------- Name AMD Phenom Codename Deneb Specification AMD Phenom(tm) II X4 955 Processor Core Stepping Technology 45 nm Core Speed 3816.6 MHz (19.0 x 200.9 MHz) Northbridge AMD 780G rev. 00 Southbridge ATI SB700 rev. 00 CAS# 9.0 RAS# to CAS# 9 RAS# Precharge 9 Cycle Time (tRAS) 24 Command Rate 2T Memory Frequency 803.5 MHz (1:4) Memory Type DDR3 Memory Size 3584 MBytes Channels Dual (Unganged) Windows Version Microsoft Windows Vista (6.1) (Build 7600) Voltage sensor 0 1.47 Volts [0x5C] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 27°C (80°F) [0x1B] (TMPIN0) Temperature sensor 1 47°C (116°F) [0x2F] (TMPIN1) Temperature sensor 2 44°C (111°F) [0x2C] (TMPIN2) Temperature sensor 0 48°C (118°F) [0x180] (core #0) Temperature sensor 1 48°C (118°F) [0x180] (core #1) Temperature sensor 3 48°C (118°F) [0x180] (core #3) Temperature sensor 2 48°C (118°F) [0x180] (core #2)
Results for x264.exe v0.58.747 encoded 1442 frames, 74.97 fps, 3904.67 kb/s encoded 1442 frames, 72.78 fps, 3904.67 kb/s encoded 1442 frames, 76.14 fps, 3904.67 kb/s encoded 1442 frames, 76.58 fps, 3904.67 kb/s encoded 1442 frames, 18.54 fps, 3952.97 kb/s encoded 1442 frames, 18.40 fps, 3952.97 kb/s encoded 1442 frames, 18.56 fps, 3952.97 kb/s encoded 1442 frames, 18.59 fps, 3952.97 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 78.67 fps, 3889.34 kb/s encoded 1442 frames, 78.40 fps, 3887.24 kb/s encoded 1442 frames, 78.60 fps, 3889.34 kb/s encoded 1442 frames, 78.54 fps, 3889.34 kb/s encoded 1442 frames, 20.11 fps, 3962.75 kb/s encoded 1442 frames, 20.11 fps, 3963.56 kb/s encoded 1442 frames, 20.09 fps, 3962.75 kb/s encoded 1442 frames, 20.03 fps, 3962.75 kb/s System Details -------------- Name AMD Phenom Codename Deneb Specification AMD Phenom(tm) II X4 945 Processor Core Stepping Technology 45 nm Stock frequency 3000 MHz Core Speed 3420.1 MHz (15.0 x 228.0 MHz) FID range 5.0x - 15.0x Northbridge ATI RD770 rev. 00 Southbridge ATI SB700 rev. 00 CAS# 7.0 RAS# to CAS# 7 RAS# Precharge 7 Cycle Time (tRAS) 20 Command Rate 1T Memory Frequency 760.0 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual (Unganged) Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7600) max VID 1.275 V Voltage sensor 0 1.30 Volts [0x51] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature sensor 0 34°C (93°F) [0x22] (TMPIN0) Temperature sensor 1 51°C (123°F) [0x33] (TMPIN1) Temperature sensor 2 80°C (175°F) [0x50] (TMPIN2) Temperature sensor 0 0°C (32°F) [0x0] (core #0) Temperature sensor 1 0°C (32°F) [0x0] (core #1) Temperature sensor 3 0°C (32°F) [0x0] (core #3) Temperature sensor 2 0°C (32°F) [0x0] (core #2) Temperature sensor 0 38°C (100°F) [0x26] (GPU Core)
Considering today's wide open availability (more or less) of the new Core i5 and i7 CPUs (the i5 750 and the i7 860 and 870), I was hoping that the x264 HD encoding benchmark would definitely be getting an update. The most recent build(s) of x264 show great strides in the optimization and tuning for Core i5/i7 architecture and, because graysky's "baby" is being used by many websites in their reviews of these new CPUs (Anand's review, for one, and several others), the problem is they're offering up results that are not showing the accurate performance of these processors using the latest builds. In other words, the i5/i7 can easily lay the smackdown on any Core 2 Quads out there (and I could care less about AMD hardware, sorry), but I most certainly do want to see accurate results using this benchmark. If the changes made to the scripts by AmazingRando can be put into action, along with the very latest build(s) of x264 - and hey, while you're at it, why not update the benchmark to even offer the option of using the x264 64 bit builds as well to show even better performance - then you'll have some very very happy campers out here. I joined to make this post primarily as I frequent another forum most of the time, but while I'm here I want to thank graysky for his efforts in creating this very popular benchmark. I intend to be building an x264 crunching monster later this year, probably a dual Xeon (Nehalem based) beast with 24GB of DDR3 triple channel RAM so, I'm very interested in seeing just what the i7 (and also the i5 for comparison) tuned/optimized x264 builds can do. Thanks, and have fun, always... ps I'm on an E7300 currently, does about ~24 fps with the 1st pass, ~6 fps second pass so, believe me, I'm damned interested in having a monster than can crank out far far faster encoding times. pss I had asked another member to run some benchmarks on his i7 920 @ 4 GHz with 12GB of DDR3 1600 working in triple channel mode, here are the results he shared: Results for x264.exe v0.58.747 encoded 1442 frames, 97.37 fps, 3904.94 kb/s encoded 1442 frames, 98.82 fps, 3904.94 kb/s encoded 1442 frames, 96.12 fps, 3904.94 kb/s encoded 1442 frames, 96.71 fps, 3904.94 kb/s encoded 1442 frames, 33.88 fps, 3974.08 kb/s encoded 1442 frames, 33.73 fps, 3974.08 kb/s encoded 1442 frames, 33.58 fps, 3974.08 kb/s encoded 1442 frames, 33.77 fps, 3974.08 kb/s System Details -------------- Name Intel Processor Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Engineering Sample) Core Stepping Technology 45 nm Core Speed 3999.6 MHz (20.0 x 200.0 MHz) Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Frequency 1600.0 MHz () Memory Type DDR3 Memory Size 12280 MBytes Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 2 (Build 6002) max VID 0.825 V Voltage sensor 0 1.25 Volts [0x9C] (CPU VCORE) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package Socket 1366 LGA (platform ID = 1h) Temperature sensor 0 31°C (87°F) [0x1F] (SYSTIN) Temperature sensor 1 56°C (132°F) [0x70] (CPUTIN) Temperature sensor 2 9°C (48°F) [0x12] (AUXTIN) Temperature sensor 0 69°C (156°F) [0x24] (core #0) Temperature sensor 1 67°C (152°F) [0x26] (core #1) Temperature sensor 2 69°C (156°F) [0x24] (core #2) Temperature sensor 3 60°C (139°F) [0x2D] (core #3) Temperature sensor 0 36°C (96°F) [0x24] (GPU Core) Now that's what I'm talkin' about... And if we get an updated benchmark with the newer builds (and potentially an x264 build test as well) those should go higher... who knows how high.
It would be much appreciated that's for sure, and would end up translating back into traffic for this site obviously as people would spread the word (folks like me) about the updated version. And I'm just itchin' to see what those optimizations/tunings translate to in terms of increased encoding framerates, as we all would be. Thanks...
Older Opteron Setup Results for x264.exe v0.58.747 encoded 1442 frames, 54.42 fps, 3904.94 kb/s encoded 1442 frames, 54.54 fps, 3904.94 kb/s encoded 1442 frames, 54.51 fps, 3904.94 kb/s encoded 1442 frames, 54.54 fps, 3904.94 kb/s encoded 1442 frames, 22.55 fps, 3974.08 kb/s encoded 1442 frames, 22.61 fps, 3974.08 kb/s encoded 1442 frames, 22.50 fps, 3974.08 kb/s encoded 1442 frames, 22.46 fps, 3974.08 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 53.13 fps, 3895.56 kb/s encoded 1442 frames, 53.75 fps, 3895.56 kb/s encoded 1442 frames, 53.69 fps, 3895.56 kb/s encoded 1442 frames, 53.69 fps, 3895.56 kb/s encoded 1442 frames, 23.85 fps, 3981.22 kb/s encoded 1442 frames, 24.22 fps, 3981.30 kb/s encoded 1442 frames, 24.20 fps, 3981.22 kb/s encoded 1442 frames, 24.19 fps, 3981.22 kb/s System Details -------------- Name AMD Opteron 2352 Name AMD Opteron 2352 Codename Barcelona Codename Barcelona Specification Quad-Core AMD Opteron(tm) Processor 2352 Specification Quad-Core AMD Opteron(tm) Processor 2352 Core Stepping DR-B3 Core Stepping DR-B3 Technology 65 nm Technology 65 nm Stock frequency 2100 MHz Stock frequency 2100 MHz Core Speed 2110.8 MHz (10.5 x 201.0 MHz) Core Speed 2110.8 MHz (10.5 x 201.0 MHz) FID range 5.0x - 10.5x FID range 5.0x - 10.5x Northbridge NVIDIA nForce Pro 3600 rev. A2 Southbridge NVIDIA nForce Pro 3600 rev. A3 CAS# 6.0 RAS# to CAS# 6 RAS# Precharge 6 Cycle Time (tRAS) 18 Command Rate 1T Memory Frequency 402.1 MHz (1:2) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual (Unganged) Windows Version Microsoft Windows Vista (6.0) Enterprise Edition (Full) Service Pack 2 (Build 6002) max VID 1.250 V max VID 1.250 V Voltage sensor 0 1.54 Volts [0x60] (CPU VCore) Number of processors 2 Number of threads 8 Number of threads 4 (max 4) Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket F (1207) Package Type 0x0 Package Socket F (1207) Package Type 0x0 Temperature sensor 0 47°C (116°F) [0x2F] (TMPIN0) Temperature sensor 1 23°C (72°F) [0x2D] (TMPIN1) Temperature sensor 2 15°C (58°F) [0x1E] (TMPIN2) Temperature sensor 0 41°C (104°F) [0x144] (core #0) Temperature sensor 1 41°C (104°F) [0x144] (core #1) Temperature sensor 2 41°C (104°F) [0x144] (core #2) Temperature sensor 3 40°C (103°F) [0x140] (core #3) Temperature sensor 0 45°C (112°F) [0x168] (core #0) Temperature sensor 1 45°C (112°F) [0x168] (core #1) Temperature sensor 2 45°C (112°F) [0x168] (core #2) Temperature sensor 3 45°C (112°F) [0x168] (core #3)
Xeon W3520 without HT: ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 66.57 fps, 3904.62 kb/s encoded 1442 frames, 69.05 fps, 3904.62 kb/s encoded 1442 frames, 69.47 fps, 3904.62 kb/s encoded 1442 frames, 69.72 fps, 3904.62 kb/s encoded 1442 frames, 18.77 fps, 3953.18 kb/s encoded 1442 frames, 18.68 fps, 3953.18 kb/s encoded 1442 frames, 18.72 fps, 3953.18 kb/s encoded 1442 frames, 18.56 fps, 3953.18 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 74.92 fps, 3889.34 kb/s encoded 1442 frames, 75.47 fps, 3889.34 kb/s encoded 1442 frames, 75.22 fps, 3889.34 kb/s encoded 1442 frames, 74.73 fps, 3889.34 kb/s encoded 1442 frames, 21.07 fps, 3962.75 kb/s encoded 1442 frames, 21.01 fps, 3962.75 kb/s encoded 1442 frames, 21.03 fps, 3962.76 kb/s encoded 1442 frames, 20.98 fps, 3962.75 kb/s System Details -------------- Core Stepping D0 Stock frequency 2666 MHz Core Speed 2800.1 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 533.3 MHz (2:8) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 1 (Build 6001) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 78°C (172°F) [0x16] (Core #0) Temperature 1 77°C (170°F) [0x17] (Core #1) Temperature 2 77°C (170°F) [0x17] (Core #2) Temperature 3 77°C (170°F) [0x17] (Core #3) Temperature 0 50°C (121°F) (GPU Core) with HT: Results for x264.exe v0.58.747 encoded 1442 frames, 65.05 fps, 3904.94 kb/s encoded 1442 frames, 70.19 fps, 3904.94 kb/s encoded 1442 frames, 68.93 fps, 3904.94 kb/s encoded 1442 frames, 69.45 fps, 3904.94 kb/s encoded 1442 frames, 23.34 fps, 3974.08 kb/s encoded 1442 frames, 23.71 fps, 3974.08 kb/s encoded 1442 frames, 23.70 fps, 3974.08 kb/s encoded 1442 frames, 23.59 fps, 3974.08 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 74.07 fps, 3895.56 kb/s encoded 1442 frames, 71.21 fps, 3895.98 kb/s encoded 1442 frames, 73.30 fps, 3895.56 kb/s encoded 1442 frames, 73.48 fps, 3895.56 kb/s encoded 1442 frames, 25.88 fps, 3981.22 kb/s encoded 1442 frames, 26.49 fps, 3981.22 kb/s encoded 1442 frames, 26.37 fps, 3981.30 kb/s encoded 1442 frames, 26.17 fps, 3981.22 kb/s System Details -------------- Core Stepping D0 Stock frequency 2666 MHz Core Speed 2800.2 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 533.4 MHz (2:8) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 1 (Build 6001) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 82°C (179°F) [0x12] (Core #0) Temperature 1 80°C (175°F) [0x14] (Core #1) Temperature 2 78°C (172°F) [0x16] (Core #2) Temperature 3 81°C (177°F) [0x13] (Core #3) Temperature 0 51°C (123°F) (GPU Core) Xeon E5530 without HT: ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 60.93 fps, 3905.23 kb/s encoded 1442 frames, 63.74 fps, 3905.23 kb/s encoded 1442 frames, 63.63 fps, 3905.23 kb/s encoded 1442 frames, 63.63 fps, 3905.23 kb/s encoded 1442 frames, 16.83 fps, 3952.94 kb/s encoded 1442 frames, 17.11 fps, 3952.94 kb/s encoded 1442 frames, 16.99 fps, 3952.94 kb/s encoded 1442 frames, 16.77 fps, 3952.94 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 68.43 fps, 3891.41 kb/s encoded 1442 frames, 68.47 fps, 3891.41 kb/s encoded 1442 frames, 68.02 fps, 3891.41 kb/s encoded 1442 frames, 68.52 fps, 3891.41 kb/s encoded 1442 frames, 19.17 fps, 3962.86 kb/s encoded 1442 frames, 19.19 fps, 3962.86 kb/s encoded 1442 frames, 19.14 fps, 3962.87 kb/s encoded 1442 frames, 19.27 fps, 3962.86 kb/s System Details -------------- Core Stepping D0 Stock frequency 2400 MHz Core Speed 2533.3 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 533.3 MHz (2:8) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 1 (Build 6001) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 64°C (147°F) [0x21] (Core #0) Temperature 1 65°C (148°F) [0x20] (Core #1) Temperature 2 65°C (148°F) [0x20] (Core #2) Temperature 3 64°C (147°F) [0x21] (Core #3) Temperature 0 40°C (103°F) (GPU Core) Xeon E5530 with HT: ^^^^^^^^^^^^^^^^^^ Results for x264.exe v0.58.747 encoded 1442 frames, 56.91 fps, 3904.94 kb/s encoded 1442 frames, 64.89 fps, 3904.94 kb/s encoded 1442 frames, 65.35 fps, 3904.94 kb/s encoded 1442 frames, 64.80 fps, 3904.94 kb/s encoded 1442 frames, 21.33 fps, 3974.08 kb/s encoded 1442 frames, 21.59 fps, 3974.08 kb/s encoded 1442 frames, 21.64 fps, 3974.08 kb/s encoded 1442 frames, 21.49 fps, 3974.08 kb/s Results for x264.exe v0.59.819M encoded 1442 frames, 67.50 fps, 3895.56 kb/s encoded 1442 frames, 65.49 fps, 3895.56 kb/s encoded 1442 frames, 66.23 fps, 3895.56 kb/s encoded 1442 frames, 66.70 fps, 3895.56 kb/s encoded 1442 frames, 24.11 fps, 3981.30 kb/s encoded 1442 frames, 24.11 fps, 3981.30 kb/s encoded 1442 frames, 24.01 fps, 3981.22 kb/s encoded 1442 frames, 24.07 fps, 3981.22 kb/s System Details -------------- Core Stepping D0 Stock frequency 2400 MHz Core Speed 2533.4 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 533.4 MHz (2:8) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 1 (Build 6001) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 71°C (159°F) [0x1A] (Core #0) Temperature 1 71°C (159°F) [0x1A] (Core #1) Temperature 2 71°C (159°F) [0x1A] (Core #2) Temperature 3 70°C (157°F) [0x1B] (Core #3) Temperature 0 41°C (105°F) (GPU Core)
Guys! The new x264 Benchmark 3.0 has arrived! Check it out here - Tech ARP - x264 HD Benchmark Ver. 3.0
Thanks for the submission but this is the wrong thread, Phyrstorm. Moving your post to http://forums.techarp.com/reviews-articles/25637-x264-hd-benchmark-3-0-a-15.html#post356660
XP 1090T Overclocked Results As Follows.. ---------- RUN1PASS1.LOG encoded 1749 frames, 235.02 fps, 1851.14 kb/s ---------- RUN2PASS1.LOG encoded 1749 frames, 235.02 fps, 1851.14 kb/s ---------- RUN3PASS1.LOG encoded 1749 frames, 232.12 fps, 1851.14 kb/s ---------- RUN4PASS1.LOG encoded 1749 frames, 232.09 fps, 1851.14 kb/s ---------- RUN5PASS1.LOG encoded 1749 frames, 232.12 fps, 1851.14 kb/s ---------- RUN1PASS2.LOG encoded 1749 frames, 80.89 fps, 1832.71 kb/s ---------- RUN2PASS2.LOG encoded 1749 frames, 81.12 fps, 1831.76 kb/s ---------- RUN3PASS2.LOG encoded 1749 frames, 80.36 fps, 1831.77 kb/s ---------- RUN4PASS2.LOG encoded 1749 frames, 81.18 fps, 1831.77 kb/s ---------- RUN5PASS2.LOG encoded 1749 frames, 80.93 fps, 1831.78 kb/s All 6 Cores Overclocked to 3750 Mhz, Main Bus Set to 210 Mhz. What program can we use to get system specifications outputted to a txt file? *** CPU Details *** -------------------------------------------------------------------------------- Physical Processors: 1 Logical Processors: 6 Processor Vendor: AMD Processor Name: AMD Phenom(tm) II X6 1090T Processor Additional Name: x86 Family 16 Model 10 Stepping 0 Popular Name: Phenom II X6 1090T Processor Frequency: 3750 Mhz
@ Ayakano : Why did you delete your results? @ cnmcdee : Can you tell us your memory speed? We used CPU-Z to output to the text file.
Thanks, but most of the credit goes to graysky. BTW, I'm going to move your post to the correct thread - http://forums.techarp.com/reviews-a...chmark-3-0-a-40.html#post359953?postcount=391
I just moved your post to the correct thread (http://forums.techarp.com/reviews-a...hmark-3-0-a-44.html#post360849?postcount=431), Salty.
phenom B50 x3 @ 3.79ghz Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 101.26 fps, 3910.12 kb/s encoded 1442 frames, 101.84 fps, 3910.14 kb/s encoded 1442 frames, 101.76 fps, 3910.14 kb/s encoded 1442 frames, 102.20 fps, 3910.14 kb/s Pass 2 ------ encoded 1442 frames, 18.24 fps, 3962.65 kb/s encoded 1442 frames, 18.25 fps, 3962.53 kb/s encoded 1442 frames, 18.22 fps, 3962.66 kb/s encoded 1442 frames, 18.25 fps, 3962.64 kb/s System Details -------------- Name AMD Phenom II X4 Codename Deneb Specification AMD Phenom(tm) II X4 B50 Processor Core Stepping RB-C2 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Core Speed 3791.1 MHz Northbridge AMD 790X rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 892.0 MHz (1:4) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 3 Number of threads 3 (max 3) L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 36°C (96°F) [0x24] (System) Temperature 1 47°C (116°F) [0x2F] (CPU)
