2000W psu
Discussion in 'General Hardware' started by PowerSlide, Jan 8, 2007.
  1. PowerSlide
    PowerSlide Just Started
  2. peaz
    2000W???? quad SLI rig?
  3. jamotto
    jamotto Newbie
    :faint:
    New 50 amp circuit breaker and maybe new wiring too.
  4. sunsetbay
    sunsetbay Newbie
    how much would the electrical bill be?? :doh:
  5. Max_87
    Max_87 huehuehue
    I doubt it's going to be able to fit into most of the cases :haha:
  6. Chai
    It doesn't really matter. PSU will only supply what's needed to your system. I think PSU efficiency is more important if you are worried about electric bill.
    150A on 12V! :faint:
  7. Adrian Wong
    LOL! Will need to redo the electrical wiring if you want to support so much current on a single wire. :D
  8. jamotto
    jamotto Newbie
    use OOOO AWG gauge wire :wicked:
  9. peti1212
    peti1212 Newbie
    Nice power supply, but I think it is useless right now. Who would make build a computer that needs more than 1000W's :confused:
  10. ChampionLLY
    ChampionLLY News Writer
    holy cow... that's more than enough for overclocking quad-R600 + quad-core
  11. Chai
    Quad R600? Unless it only 1 PCI-E connector per card... :haha:
  12. ChampionLLY
    wad do u mean?
    i'll expect those cards to come with a 4pin-molex-->PCIe converter
  13. zy
    zy zynine.com Staff Member
    ermmm .. i think you will trip the fuse without even fully utilising the power of the PSU :mrgreen:
  14. Chai
    Then you will need extra 8 more Molex connectors for 4 PCIe connectors!!! Assuming R600 will using 2 PCIe per card like the 8800GTX.
  15. ZuePhok
    ZuePhok Just Started
    lets use it to cook pizzaaaaaaaaaaa
  16. Olle P
    Olle P Newbie
    Think two CPUs and two graphic cards...
    Think adding water cooling to those...
    Think using high power peltier boosted water blocks...
    There you have it! The peltier elements alone will use about 100A on the 12V line.
    /Olle
  17. ChampionLLY
    i dun get u...
    wad i get fr my past asus 78gtx, 79gt is a
    molex-male<->PCIe<->molex-female connectors
    u would den need all the 4 PCIe power from the psu + 4 converters
  18. Chai
    The converter that I used to have was molex-male<->PCIe<->molex-male, which means it draws a lot of power from a single molex-male connector, which is why it splits up by using 2 molex-male.
  19. ChampionLLY
    eh... i think mine is male male pcie too leh.. oops
    u sure that's the purpose of splitting em up?
    ppl usually suggest u plug one of em instead of both..
    i never understand the purpose of having 2 males...
  20. Chai
    The purpose is the reduce the load on single cable.
