ok in the guide it says not to do this on the new pcb that has the 360 core and uses the 9800 xt pcb, but my card is a 360 core and used the old pcb http://forums.rojakpot.com/showthread.php?p=255026#post255026 it looks like the same card used in the 9800pro volt mod guide. so which one do i use?? the 9800pro guide or 9800xt guide??
If it's using the same PCB and the same voltage regulators, then it is okay to use the 9800Pro (old PCB) guide, doesn't matter whether it's R350 or R360
ok, i got up to 470 mhz, then i went too far with the voltage, cause now when ever i load up a game all the textures shick and jive like mad. viewing desktop it runs normal but as soon as i go 3D, . X850 here i come!!! p.s. anyone know how to fix a 9800
