oridinary camera can liao mah... go and scan.. if ur house no scanner... go to a cyber and scan haha !!
RM1.50 for cyber cafe scan per scan. Hmm... what do you all think about placing a fan beside the harddisk? Is it enough cooling or more are needed?
Normal HDD dun generate a lot of heat anyways.... but if u really want... then 1 is enuf.... I actually have one on my main drive..... it actually is cooler than my secondary one ...... but the benefits r unknown... Probably longer lifetime?
heh. u sure normal HDD don't generate that much heat? it's not hot like the processor, but 40c is still hot enough. hold on i'll post my pic instead.
many people casing is messy because of the power cable to HDD, CDROM, how to solve this ?? my case is very neat adi but still cant solve the power wire problem
the wires makes it messy... haha... ur mind must be very creative in order to make it tidy... or esle... cut off all the wire and it would be tidy... but there is a risk that u won't be able to run ur comp anymore HAHA !!
well.. i cant.. cant bend here bend there + risking that my equipment will not get the power.. .. esp. my stupid floppy..
If the inside of your case is untidy....put the cover on.like closing cupboard door.cant see,doesn'tmatter
notice my wires? it's only 2 wires from the PSU with 2 4pin connector on each. i have 1xHDD 2xCDROM 1xVGA 2xBlower 1xCPUfan 2xTempProbe to connect to. i think it'll be les mess once i get a new PSU. btw the rounded cables help air flow a lot.
of coz i plug them in properly... i guess lousy connectors.. sometimes my fan will not work .. hahahah... bcoz of that ... then .. my connector on my HD really sux.. its kinda loose.. i had to bend the pins down to make it tighter with the power conenctor...
goldfries... I do wonder... wat HS are u using ? seems kinda nice HS u got there... haha... greeny colour..
Clever boy Brian. damn ur good......really. not just on this post. NeoSquall, go do your homework. it's obvious you've not read ARP Reviews.
