Ok I did two runs each of 3Dmark03 and 05, one with my 6600GTs at stock settings, and one with a 5%oc, which is as much as I'm comfortable with at stockcooling. Here is the first run. The second run. Clock settings, ram timings, ect... The stock clocks on my 6600GTs are 500mhz gpu clock, and 1000mhz memory clock. Not a huge leap with the overclock, however it was only a small increase. Once I have better cooling and it is a little safer to push the cards I think that I can get those scores up a bit higher.
Ooo, just noticed this thread. I have a severe lack of screenshots and Futuremark's website is really slow at the moment so I'll contribute my results later
Ok...6600GT results: 05 - http://service.futuremark.com/compare?3dm05=1441006 I'm not done yet, GPU block coming this week 03 - 10731 6800GT... 03 - 14076 http://service.futuremark.com/compare?2k3=4374744 05 - 6023 X800XT PE... 05 - 6022 with the card at 575/610 on stock cooling, P4 2.4B @ 3.1GHz.
i've OCed my S64 to 2.2ghz (275) and X800GT to 599 / 545 and i only get like 20k for 3dm01 10k for 3dm03 3.5k for 3dm05 CPU bottleneck i guess.........hrmrmr.
