prescott is real hot..need good cooling for me..although i dun own one i think 2.4C is great..coz it can really overclock..if u dun overclock get a higher mhz one's...
My personal experience with 2.4C: I overclocked it to 3G (FSB 200->250) and it works well on an Abit IS7 (Intel 865PE). Of course I had to raise the voltage from 1.525V to 1.575V (the Northwood family si rated for 1.500 - 1.550 V). I also tried it for 266 MHz FSB (~3.2G), but memtest gives me errors (even with memory at 177MHz). But i don't know if it's the processor (probably the cache) or chipset(865). I would go for the chipset since further increasing the processor voltage makes no difference. The first time I put it to 3G, I ran a test: recompressing a DIVX/MP3 AVI (to DIVX/MP3). At stock voltage, it froze after 2 minutes. After raising core voltage to 1.550V (maximum spec), it froze after 7 minutes. After further raising to 1.575V (next possible step for my MB), it finished recompressing the movie after 2 hours. But there is one thing you should know: All processors (all frequencies from one family) are built on the same production line. They are marked I believe after a thermal test (well, it is a test). So a 2.4C is hotter than a 3.0C at the same frequency. After all, I got to 3G, but I raised the voltage over specifications (which directly affects power consumption/heat). So I don't know how much you can overclock the FSB. But I think you can go to 250MHz on any Intel chipset. I also think that any Northwood can handle 3.2GHz with proper voltage and cooler.
i guess 2.4C overclocks better than 2.6C .. but not all processors will overclock the same.. it depends on some luck i guess.. i only manage to push to 235 FSB .. heat issue..
mine 2.8E can clock to about 3.5..dats 250mhz X 14 but need good cooling..mine temp kept to about 33C idle n 40C load cooled by xp-120 n a 145cfm fan
