Hi Adrian, I have a setting int he bios called EIST , should i enable or disable this? I heard that enabled can cause bsod`s? i am using an intel e8400 and i am running at stock speeds. Also plug and play O/S set to no NO correct? thx in advanced
Tech ARP - Reducing The Power Consumption Of Overclocked PCs Rev. 2.0 You can follow this article, even though it's meant for overclocked processors, but it explains the purpose of EIST and the results.
