Buffalo 1066Mhz DDR2 waste of money or?
Discussion in 'General Hardware' started by generalRage1982hrv, Jul 29, 2008.
  1. generalRage1982hrv
    hi guys
    i have geted this ddr and i have problems
    i dont know why but ddr just dont wanna work on 1066 LOL
    we have tested it on Gigabyte x38 and Amd 770, abit & my asus mbo p35, x38
    and we had same problem
    ddr2 modules just dont wanna work at 1066Mhz speed on any voltage
    all mother boards set it up on 800Mhz and when we try to set it up at 1066 system just hangs on :boohoo:
    it dont wanna boot
    what do you guys say on Buffalo 1066Mhz ddr moduls ?
  2. Mac Daddy
    If its DDR1066 it should run at the rated speed especially at the default voltage rating :think:
  3. Chai
    Running at stock timings?
  4. generalRage1982hrv
    well it is on defoult but cant run on 1066
  5. zy
    zy zynine.com Staff Member
    set the timing manually? :think:
  6. generalRage1982hrv
    well i told that i tryd everything
    and i have tryd on different mbos
  7. Chai
    Some of these modules might only work on certain chipsets. Check with the manufacturer if they are tested to work on which board. If not, ask for a replacement.
  8. generalRage1982hrv
    i have geted their mail and it seams that ddr is f***** up
  9. Adrian Wong
    Actually, there's no official JEDEC spec on DDR2-1066. Hence, all 1066 MHz DDR2 memory modules are not certified for use on any DDR2 motherboard, unless specifically tested and certified to work on certain motherboards.
    You have to check with the motherboard manufacturer if they actually tested the Buffalo 1066 MHz DDR2 memory and certified it would work with the motherboard. Otherwise, it's really a matter of luck. :(
  10. generalRage1982hrv
    bro i have done that and i have spoken with some Buffalo guy from US
    and he told me it can happen that there was something wrong in that modules
    and he told me that Buffalo is support large numbers of mother boards but if you know me better you would know that i have allready orderd other modules well lets say OCZ Reaper 2x2Gb 1066 uhhhhh yeah and after small fight i geted discount uhhh ehehhehehehhe
  11. g0tanks
    g0tanks Newbie
  12. Chai
