convert Ati X700 Pro into a FireGL card
Discussion in 'Overclocking, Cooling & Modding' started by riosup, Nov 2, 2005.
  1. riosup
    riosup Newbie
    Hi,
    I have an Ati X700 Pro (Gigabyte - GV-RX70P128D-SP) – PCI-E and I want to “convert” into a FireGL card. I made this with my last card (an Ati 9600 Pro – AGP) and I had good results on graphic programs (CAD) where OpenGL is important. I tried now with FtrrFireGL and seems it won’t work. Could tell me somebody a solution?
    Thanks’.
  2. Max_87
    Max_87 huehuehue
    I don't think it is possible because RivaTuner's patch script only have hacks for FireGL X1, X2, X3, T1 & Z1 which are equivalent to 9700, 9800, X800, 9600 & 9500. Therefore it is impossible to softmod X700 to FireGL V5000 unless Unwinder (creator of RivaTuner) does something to the patch scripts :mrgreen: hope that helps.
    Anyway, check out the updated guide http://www.rojakpot.com/showarticle.aspx?artno=105&pgno=0
    Edit: not unless you hardmod your X700! :mrgreen:
  3. riosup
    riosup Newbie
    Thanks'. I'll look for future release of RivaTuner (but I preferred FreeFireGL ... :)).
    Thanks' anyway.
  4. SimpleCad
    SimpleCad Newbie
