Okay guys... I've downloaded CoolBits Plus recently (never knew there was such a thing ) In the extra tab... I see my SBA (Sideband Addressing) is enabled by default, but the FW (Fast Write) is greyed out? Meaning disabled? What gives... Is this supposed to be like that or ...?
Then most probably your card doesn't work with Fast Write, or stability issue with FW on, so the drivers disabled the feature.
if u really want to enable them. try using powerstrip from http://www.entechtaiwan.com/ps.htm Powerstrip should be able to force FW and SBA to be enabled
LOL! I've tried Powerstrip, it crashed my 9100 instantly! So if it doesn't allow you to enable, you better not try it.
