Uh... you haven't answered my question yet. I can connect my Access point to the DSL600EU modem right? And what's the best budget access point with 4 ports switch combo only?
Because you won't need to use WEP! I did a quick test and posted the results in the forums some time ago. I wonder where it is...
Yes, you should be able to do that. As for the "best" budget access point, heh... I think they are all about the same. Perhaps you should try going for access points from more renown companies like Linksys?
Yes. I am going to get one soon. But how to connect 'em-ah? There's only ONE port at the back of the access point. Should I connect the router modem first to the WAP using the Ethernet cable. Then again, where is another connection from the modem to my computer?
Hehe.. You just connect the modem to the access point. That's it. Your computers connect to the access points via WiFi.
I know, I know. But then the WAP has only one port to the modem. Then how about the modem to the computer?? Of course, if you connect the modem to the WAP they'll be hanging like that without a connection to the comp. Oooooh.
Modem to the computer??? Why would the modem be connected to the computer unless you have a USB model??? You just connect the phone line from the phone outlet to the modem. And connect the modem to the WAP using the LAN cable. That's it.
hope im not late for this. it is all depend on ur router only, AP shud be ok being using linksys router for almost one yr.....it is very not stable, sometime in 6hrs time of using, i need to restart the router for 6 times, equal to the router down each hour...that is the most i can take, normal it just down 2-3 times per day, fine, i go and restart. But tat day really cant take it anymore, straight away i go and order the D-Link router, now already using it for 2week, nv down b4.
