Looking at possibly OC'ing my system and would like to start at a good stable point to begin with. If anyone has a simular setup, could you shoot me your BIOS settings? I especially need to verify my ram timings.. Every time i would get to the point in installation for the Video drivers, it would hose the system. Cosair's forum helped, the bios didnt seem to do the "auto" settings very well.. Info is in my sig.. I'm also using windows XP 64-bit if that helps also.. Thanx !
Errr... The optimal setting for each system varies according to the components used as well as the user's requirements. I suggest you consult our BIOS Optimization Guide - http://www.rojakpot.com/bog.aspx.
