Before this, everything works fine. My card auto goes into 2D mode when idle and into 3D performance when I playing games. After installed some basic program and Vista update. When boot into Vista, the clock speed is always running at 648MHZ even idle. I try to restart comp and still the same and you can't DC or OC it. The only thing you can control is the fan speed. I am running on Vista Ultimate X64 and using the latest driver from Nvidia. Please help and sorry for my ENG. Thanks. HWM BlackBox 1.02 Saturday, March 07, 2009 11:16:32 AM CPU # 1 ------------------------- Manufacturer : Intel Model : Intel Core 2 Duo E8400 Package : Socket 775 LGA Processor ID : BFEBFBFF0001067A Version : Model 7, Stepping 10 Revision : E0- 5898 Instructions : MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Codename : Wolfdale Core : 2 Thread : 1 Technology : 45 nm Address Width : 64 Bit Data Width : 64 Bit Maximum Speed : 3,000.00 MHz Current Speed : 1,970.76 MHz Speed (O/C) Rate : % 65.69 Multiplier : 6.0 x Bus Speed : 328.48 MHz FSB : 1,313.91 MHz L1 Code Cache : 2 x 32.00 KB L1 Data Cache : 2 x 32.00 KB L2 Cache : 6.00 MB L3 Cache : - Physical Memory ------------------------- Module Count : 2 Empty Slots : 2 Total Size : 4.00 GB Channels : - Memory Type : DDR2 Frequency : 394.15 MHz FSBRAM : 5 : 6 Speed (O/C) Rate : % 98.54 CAS Latency : 5.0 RAS - CAS Delay : 5 RAS Precharge : 5 Cycle Time : 18 Bank Cycle Time : - Command Rate : 2T Module # 1 ------------------------- Modul Slot : DIMM0 Manufacturer : Kingston Week / Year : 00 / 00 Part Number : 2G-UDIMM Serial : - Size : 2.00 GB Memory Type : DDR2 Band Width : PC2-6400 Maximum Speed : 400 MHz Data Width : 64 Bit Profil # 1 : 200 MHz - 3.0 - 3 - 3 - 9 - 12 - 1.8 V Profil # 2 : 266 MHz - 4.0 - 4 - 4 - 12 - 16 - 1.8 V Profil # 3 : 400 MHz - 5.0 - 5 - 5 - 18 - 24 - 1.8 V Module # 2 ------------------------- Modul Slot : DIMM2 Manufacturer : Kingston Week / Year : 00 / 00 Part Number : 2G-UDIMM Serial : - Size : 2.00 GB Memory Type : DDR2 Band Width : PC2-6400 Maximum Speed : 400 MHz Data Width : 64 Bit Profil # 1 : 200 MHz - 3.0 - 3 - 3 - 9 - 12 - 1.8 V Profil # 2 : 266 MHz - 4.0 - 4 - 4 - 12 - 16 - 1.8 V Profil # 3 : 400 MHz - 5.0 - 5 - 5 - 18 - 24 - 1.8 V Mainboard ------------------------- Manufacturer : Asus Model : P5Q-Pro North Bridge : Intel P45/P43 A3 South Bridge : Intel 82801JR (ICH10R) 00 PCI-E Slot (x16) : 2 PCI-E Slot (x8) : - PCI-E Slot (x4) : - PCI-E Slot (x1) : 2 PCI Slot : 2 AGP Slot : - BIOS ------------------------- Manufacturer : American Megatrends Inc. Version : 1501 Date : 11/04/2008 VGA # 1 ------------------------- Model : NVIDIA GeForce GTX 285 Graphic Memory : 1 GB Driver : nv_GT2x 7.15.11.8208 Disc # 1 ------------------------- Model : ST380817AS ATA Device Media Type : 3.42 Firmware : 75 GB Size : 1 Partition Partition : IDE Interface : Fixed Hard Disk Media Disc # 2 ------------------------- Model : WDC WD2000JS-00MHB0 ATA Device Media Type : 02.01C03 Firmware : 186 GB Size : 1 Partition Partition : IDE Interface : Fixed Hard Disk Media Disc # 3 ------------------------- Model : WDC WD16 00BEVS-22VAT0 USB Device Media Type : 1A11 Firmware : 149 GB Size : 2 Partition Partition : USB Interface : External Hard Disk Media Windows ------------------------- Windows : Microsoft® Windows Vista™ Ultimate 64-bit Version : 6.0.6001 Service Pack 1 Product ID : 89587-OEM-7332132-00031 Performance ------------------------- System Rate : 5.8 Processor Rate : 5.7 Memory Rate : 5.9 Graphics Rate : 5.9 Video Encoding Rate : 5.9 3D / Game Rate : 5.9 Hard Disc Rate : 5.2 Processor Performance ------------------------- Compression Type 1 : 156.40 MB/s Compression Type 2 : 425.42 MB/s Encryption Type 1 : 98.05 MB/s Encryption Type 1 : 729.24 MB/s DirectShow Encoding : 5.10 s Memory Performance ------------------------- Bandwidth : 6,389.60 MB/s Graphics Performance ------------------------- Memory Bandwidth : 59,897.20 MB/s Video Decode : 0.71 s Alpha FSP : 591.46 F/s ALU FPS : 869.95 F/s Texture FPS : 907.39 F/s Hard Disc Performance ------------------------- Avg Throughput : 47.82 MB/s
Did you install the NVIDIA Control Panel? See this guide for instructions on downloading and installing it - Tech ARP - NVIDIA GeForce GTX 295 Overclocking Guide
