Ok, Two of my old v-cards. Guess what brand/models,,, You get rep if you guess correct! The fan went bad on one,,, Hence my "mod". It cools better then the old fan. I wonder if it's worth oc'n.?.
Okay, looks like the one with the fan is a Visiontek GeForce2 GTS while the one without the fan is the MSI GeForce2 MX 400.
GeForce2 GTS for sure. It has twice the number of pixel pipelines and usually comes with DDR SDRAM which gives it twice the memory bandwidth of the GeForce2 MX.
Ok,,, I picked up another vintage v-card. Anyone can guess what kind??? Could be some rep in it for you...
Unknown motherboard Here are some pictures of this unknown brand of motherboard in this rig I picked up. The one thing I know is that it has the same chipset as my abit kt7ar. With it's 900mhz thunderbird and a ge-force two GTS it manages 65 FPS@1024/768 on q-3 max detail/settings.
Nope. The ram chips have the words M-PLUS printed on them. Never heard of them b4. TNT... Hahaha,,, Getting warm!
